Question about Lands Phones
We lost the instructions that came with 5 handset cordless phone can we get another?
Is one available on line?
  • kakima Nov 05, 2012
    What make and model phone?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Lands Phones Master
  • 102,366 Answers
You may download a copy of the KX-TG6641 manual here.
Posted on Nov 05, 2012
SOURCE: Dual Maxus 5.8GHz Handset Cordless Phone
Worked great! Thanks!
Posted on Jan 26, 2008
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
Posted on Jul 06, 2008
SOURCE: Panasonic cordless handsets all say line in use
I had the same problem. Something makes the phone's memory get "stuck."  Take the battery out of the phone for a minute and then put it back. Then unplug the phone and plug in again. You need to do this with all extensions. The problem goes away.
Posted on Jan 12, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
SOURCE: Uniden DSS7955 Cordless phone problems
I had the same problem!
What you need to do is hold the "end" and "#" key for 5 sec, which will deregister the headset then all you would have to do is place it back in the base for it to registered again.
Posted on May 06, 2009
BOUGHT REFURBUSHED HANDSET ON LINE. cannot GET IT TO REGISTER USING THE MANUAL. TRIED INSTRUCTIONS WITH HANDSET AND ORIGINAL MANUAL. CANNOT GET INTO MENUE ON HANDSET. JUST SAYS DID NOT RETGISTER.
I hope this helps. If memory serves, when I had this unit you need to register Handset # 1. All of the other handsets should fall into sync, once this is completed. Check your manual to see if there is anything similar to my hunch. Good Luck! Have a great day.
Aug 30, 2015 | Uniden Dect1588-5 Corded And Cordless...
Base el5200 will not reconize new hand set
To deregister the new handsets from their old bases and re-register
them to your base, try this for each new handset...
1. When the new handset says "Connecting..." and goes nowhere
else, enter *331734 [menu] and it will soon beep and display
"Not registered"
2. To register the new handset to your base: on the base press
the "Handset Locator" button and hold it until the "in use" light
comes on ( ~ 4 seconds ), then release the button and set the
new handset into the base phone cradle. After ~ 30 seconds
it will beep and display its "Handset #" (next in sequence).
3: Note: the base has a limit to how many handsets it can handle,
I believe it is five handsets maximum for the EL52300.
If your system was fully populated ( ie, a handset is already # 5 )
you will have to clear all the handsets from the base and
re-register them in sequence ( it is the only way to 'rescue' the
places occupied by the lost handsets ).
To clear the base of all registrations:
1. Press and hold the the "Handset Locator" button until the
"in use" light lights and then starts to blink ( ~ 10 seconds ),
release the button -- then press it again briefly while the "in use"
light is still blinking.
2. The base will beep and all handsets will display
"Not Registered"
3. Follow the instructions above for each handset in turn: press
"Handset Locator" ~ 4sec ( in-use light on ), set handset into
the base cradle, etc.
The manual is available from: www.manualslib.com
but does not describe these procedures.
Good luck !
Mar 01, 2013 | AT&T ATT EL52500 DECT 6.0 5-Handset...
Increase number of rings
You can select the desired ringer patterns of the base unit and cordless
handsets. 4 patterns are available for each line. Your phone comes from
the factory set to pattern 1. Programming must be carried out
separately for the base unit and cordless handset(s).
Make sure that the base unit/cordless handset is in the standby mode.
Base Unit Handset
4 Enter the desired pattern using
the dialing buttons ((1) to (4)) for
each line. To move to another
line, press H or I.
• Each time you select a pattern, it
rings.
5 Press (ENTER).
• A beep sounds.
• To return to the standby mode,
press (EXIT).
1 Press (FUNCTION).
2 Press or until the arrow
points to "Ringer setting",
and press H.
3 Press or until the arrow
points to "Ringer pattern",
and press H.
• The current settings are displayed.
Ringer pattern
L1 L2 L3 L4
1 1 1 1
Feb 20, 2011 | Panasonic KX-TG4000B 4-LIne Multi-Handset...
Hi There.. Lost instructions..wanted to know how to change the handset setting/line settings.. want to change handset to different base ?? Hopefully you can assist? Thanks
First, you need to de-register the handset from the current base. Then register it to the new base. On the handset, press Menu then navigate (up/down arrows) to Handset Settings and press OK. Next navigate to Registration and press OK.
For deregistration: navigate to Deregister then press 3 3 5 . Then select which handset to deregister (1-6) (the handset number will flash when it is selected) and press OK. Select Yes and then OK. When the deregistration is complete, press OFF.
For registrations, navigate to HS Registration then press OK. Then move to the base and press and hold the Locator button until the registration tone starts. If all the handset ring, press the locator button to stop the response and start over. Within a minute and a half of the registration tone starting, press OK on the handset and wait until a beep sounds and the symbol on the screen stops flashing.
The user's manual is available here: http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones/Expandable-Systems/Operating-Instructions/model.KX-TG1033S.O#ts . It's in the tab marked Operating Instructions. This will provide additional setting information.
I hope this helps.
Nov 29, 2010 | Panasonic KX-TG1033S Cordless Phone
I have the swatch cordless II phone with base station however I have lost the instruction manual for the base station and therefore cannot register the handset with the base station. Has anyone got a...
To register a handset with Cordless 2 base: Keep pressing call button [loudspeaker icon] on base for 5sec. then press [right pointing arrow in a diamond] twice. Then 9 0 1 then the system PIN if required. Choose internal number 1 to 6 for this handset and then the designation of the base station A=2, B=5, C=8, D=0, followed by [right pointing arrow in a diamond].
Hope that helps!
Jan 17, 2010 | Lands Phones
I just purchased a #43-143 corded/5.8ghz cordless phone - phone has a basephone and a hand phone. We do not need the answering machine as we have one on another phone in the office - can we disengage the...
The instructions are on page 76 of the user booklet: Press the answer on/off button, which is that little button with the circle and line through the top of the circle. Then press the line 1 or line 2 button. Then it should announce "Answering system is off".
By the way, Radio Shack has discontinued this model and additional handsets are not available. However, the handsets are the same as the Uniden TCX905, which are available.
Dec 31, 2009 | Radio Shack Lands Phones
How to connect multiple phones to voip adapter? Only line 1 is available for connection.
Have you tried using a 5 or 8 port switch to see if this will allow u to have 8 or 5 more phones available ...they do make a 25 switch if you want to add 25 phones
Sep 18, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
I have lost the instruction manual - is there an online version?
Hi
here is a downloadable version of the instruction manual...
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=CORDLESS_PHONES_CA&sct=DECT_PHONES_SU&grp=PHONES_GR&session=20090426060330_93.97.209.201&ctn=TD6626/BB051P&mid=Link_UserManuals&hlt=Link_UserManuals
Regarding using the base on its own, I cannot see why not if you have all the working buttons to control functions you need on it.
If you are going to use other phones with this please take into account REN values on your line. Most lines will support upto and including 4 REN value. Nearly all phones will have a REN value of 1. So ideally only have a maximum of 4 phones (may get away with 5 if you are near an exchange?)
Hope that helps?
Apr 26, 2009 | Philips Zenia Voice Cordless Phone
Handset has message Out of Range even though it is fully charged on on the handset.
The handsets are reading out of range because they have lost connection with the base. This happens mostly during peak power demands or power outages, but can also happen when the phone is unplugged for any amount of time. This can also cause, at times, the answering machine to stop picking up calls. To remedy this issue, reset the phone system. Please follow the instructions below:
To reset the phone:
1. Disconnect the power adapter, phone line, and remove all batteries from the base and all handsets. Leave it disconnected for 30 seconds to reset the base.
2. Place the batteries in the handsets first and then plug in the power adapter and phone line. Do not place the batteries back in the base yet.
3. Put the handset in the charge cradle.
4. It may take up to 1 minute for the "Out of Range" to clear from the display.
5. Once the "Out of Range" is cleared from the handset place the back up batteries back into the base.
Sep 08, 2008 | Motorola Mobility SD4502 Cordless...
Lands Phones Logo
43 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
