Question about E-Machines T6528 PC Desktop
Hi I have installed a new hard drive but i dont know how to get the volume on
    Novelist:
    Scholar:
  • 72 Answers
Need way more information, Gill.
I'm going to go out on a limb and paraphrase your problem as:
You installed a new hard drive, reloaded the operating system and Windows (XP?) loads, but you have no volume control and hear no sounds from the speaker.
If I have guessed correctly, then you probably need to load the sound card driver.
If I have missed the boat, please submit your problem in more detail beginning with a detailed description of the problem, the operating system, how long ago this happened and what happened that may have contributed to the problem.
Visiting the e-machine website should get you to the support page with sound card drivers.
If you can't find it, let me know.
Honest1abe
Posted on Jan 05, 2009
To whom it may concern. im looking to reboot my acer 6935 but i dont know what way to do it, i dont have the recovery disc. could you please help. thanking you.. brian o' connell
This procedure will work usually unless there has been an alterations to the originally installed OS on the Acer. On recent Acer computers they have a hidden volume on the disk labeled PQService.
This volume is for restoring the computer to the factory settings in same condition as purchased new. It will erase everything currently on the main hard drive.
Step 1: Backup everything that is important to you, on a disk or separate hard drive.
This includes any documents, pictures and application installers.
Step 2: Reboot the system and press ALT-F10 during the POST to start the Acer eRecovery Management and reinstall the operating system.
Step 3: Select Restore system to factory default.
Step 4: The wizard will lead you through formatting the designated drive and installing the operating system from the computer hard drive to the designated drive.
Jul 20, 2011 | Acer Computers & Internet
What to do after installing a new hard drive?
Download and install the drivers from support.dell.com
Install them in this order
http://www.fixya.com/support/r4432358-proper_order_install_drivers_dell
Apr 04, 2010 | Dell Dimension 2400 PC Desktop
I dont know wat to put in volume label cause i cannot formta it!
you do not require to put anything in the volume label infact there must be a check box under the volume lable box uncheck it and try.
if the problem persists simply put any label keeping in mind it dose not match your existing drive label.
thank you.
Mar 31, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Wanting to use as slave hard drive
hi ronrayhall,
I installed a maxtor hard drive, and they are shipped with a default of cable select. If you have this hard drive you dont need to change the jumpers. You do need to make sure however your original hard drive is also on cable select.
If you dont have a maxtor, alot of manuf. print the jumper settings on the hard drive, if not you might have to find the install instructions on the web for that drive. There is a good listing of Jumper settings at this website if its easier for you than searching the web. http://drivejumper.com/
ariluvsfixya
Aug 28, 2008 | Quantum HD Fireball CX 6.4 GB (CR64A461)...
Not working
if your on vista you need a special driver
Aug 17, 2008 | Western Digital Elements powered by WD 320...
Problem Installing XP
you can go to your BIOS system set up and select the right sequence if you prefere HDD first then CD-ROM,
depends on your manufacturers settitng pls press F2 or F10 immediately upon start up then you will be prompted to enter password, ( if you know ) then scroll down until you see the booting sequence, dont forget to save this and end your system set up
goodluck
Aug 06, 2008 | Sony PCG-TR3A Notebook
Installation off New hard drive
First tell me where you are going to install this hard disk whether to be primary or secondary disk and what is your pc configuration.
Old bios does not support large volume hard disk so you have to make it partitioned with the help of a new pc and then try to install the xp or use some third party utility to format and partition the hard disk (use or download part.exe) then make a bootable cd or floppy with Windows98 or XP then run this utility
Jul 04, 2008 | Acer Aspire 3100-1405 Notebook
New hard drive(s) in Dell4500s
You would have to contact dell for the OS disk.
I dont think you can install the hard disk in place of floppy drive. An external Hard disk would be a better option.
May 04, 2008 | Dell Dimension 4500S PC Desktop
Newby
Hi There OceanStar Thank You For Your Post
Best Solution Reboot The Computer With A New Install On Windows And See How You Go It Could Also Be A Faulty Hard Drive Try Installing A New Windows And See How You Go If Not Try Installing A New Hard Drive
Hope This Helps And Remember If You Get Time To Please Rate Me If his Helped :)
Thank You
FixYa
Jan 12, 2008 | Computers & Internet
HDD2188 cannot display its volume
Hi, You might need to format them. Right click on MY COMPUTER, select MANAGE. Go to DISK MANAGEMENT, then to the right pane of the window, go to the usb drive and format each partition. This is only if your hard drive is new and has no data. If it has data, then it's a different problem and solution altogether. Thanks, Lolita
Jul 09, 2007 | Toshiba (HDD2188) 80 GB Hard Drive
E-Machines T6528 PC Desktop Logo
37 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
