No Sound from TV Speakers.
I don't have any other equipment connected to the TV except cable TV signal.
  • Rob getz Nov 05, 2012
    Go into the menu on  the tv, Your internals speakers probally are turned off.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Check in menu the speakers are not OFF or set to External----failing that and no box in use you have a audio problem in the set.
Posted on Nov 06, 2012
SOURCE: connecting lg tv to two external speakers
Yes,
depending on how many speaker you intend to run will determine the type of amp you will need.  Set the output on the source unit to optical out.   Connect the optical cable to the amp.  Connect the speakers to amp.  turn them all on and select the iput of the source unit on the amp and enjoy.
good luck
chachig
Posted on Feb 11, 2009
SOURCE: I lose Audio from internal speakers Vizio
This issue is actually caused by my cable box. Access the audio SETTINGS on Hand held Cable Remote, and turn on the HDMI and or "Digital Audio Out" option. found on 'more' settings list. This should fix the issue. I had assumed the Cable companeis 'Boot' would have installed this feature during its initialization.
Posted on Dec 20, 2009
  • 8457 Answers
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Posted on Apr 07, 2010
  • 304 Answers
SOURCE: Samsung UN55B8000 Audio out - 3.5mm connection not working
Try a firmware update from Samsung. If that does not work, replaced the Main bd.
Posted on Apr 16, 2010
eagle338
  • 4889 Answers
SOURCE: I BOUGHT A HOME THEATRE
Instead of hooking up each component to the hometheater seperately there is an easier way. Disconnect all connections between the components and home theater . Just make sure they are connected to the tv properly. Take the optical cable and connect it from the optical audio out of the tv to the optical audio in of the home theater. This way whatever audio on the tv will play through the home theater. If the hometheater does not have an optical in you can also use a stereo audio to stereo audio(3.5mm) connected from the headphones jack of the tv to the 3.5mm jack on the hometheater. I use this setup for my hometheater system and it works perfecty and most importantly makes things less complicated.
Posted on Jun 23, 2011
How do I connect my receiver so that the sound comes from my speakers????
Please read the manual. You should connect speakers to the speaker output of the receiver, or amplifier. You connect the TV with a receiver through a HDMI cable. Depending what would be the source from that you take the output and the place the signal is going to there you should use the input. Don't connect anything without 100% certainty it is correct. You could damage the whole equipment when connected the wrong way around.
Dec 28, 2014 | Samsung 50" Uhd 4K Smart Hdtv
Im trying to hook my insignia flat screan tv to my mitsubishi M-VR900 recevier the tv has plug for audio out and recevier has a tv audio in red/whit plug and i have 2 speakers i have on the front spearker...
Go into the onscreen menu of your TV, find and select the audio options. Make sure the audio out on the TV is enabled (this might be an automatic feature and might not be displayed -it depends on your TV model). Next make sure your receiver is working and (if it is so equipped) make sure your speaker switch is enabled.
Make sure all of your cables are working. You can do this by switching out the cables one at a time for ones you know are good.
Make sure no headphones are plugged into your receiver or the TV -this usually turns off your audio signal to any speakers.
Your TV remote may be equipped to control the volume output of the external audio out signal. Some TVs automatically turn off the internal speakers when you hookup or select an external audio output. turn up the volume on both (your TV and the Mitsubishi).
Does the Mitsubishi work on other sources (DVD, radio etc...)?
Remember to double check your cable connections -audio OUT from the TV to audio IN into the Mitsubishi. Reversed connections can damage your TV and amplifier electronics.
What model is your Insignia? Some are equipped with digital outputs which, if your receiver is so equipped as well, can send surround sound (home theatre) signals to your receiver. These can be orange-colored rca jacks or optical jacks. They do not send analog audio signals.
Once all the cables are double-checked, (double-check your speaker connections!), turn on your receiver, TV and signal source (cable, satellite DVD etc...), bring the volume control (both on the Mitsubishi and the TV) up to nominal levels. You should hear sound.
One more thing:
Make sure your speakers work. You can try them on another amp or simply touch the speaker terminals with a 9-volt battery (the speakers should move in or out depending on the 'phase' of the connection).
Hope that helps.
Nov 26, 2011 | Audio Players & Recorders
No sound
Make sure that you do not have the TV muted and the volume isn't at the lowest setting. If there is still no sound look behind the TV to see if anything is plugged into the sound out. Having something plugged into the sound out sometimes turns off the sound in the TV's built in speakers. Also go into the sound settings and double check that the internal speakers are not disabled, or that the tv is not set to audio out only. Next make sure that you have the audio cables correctly connected, or if you are using HDMI, there are no audio cables to worry about. Make sure the sound cables are also connected correctly to the device that the signal is coming from. If you did all that, check to see if your device is outputting sound in the first place. Go into the settings on your device to see if the sound is disabled, and that the output you are using is the one being used for sound output. If all of these steps don't work you should take your TV into a repair shop to be fixed.
Jul 28, 2011 | Televison & Video
Suddenly yesterday this equipment stopped producing any sound. Not even on the TUNER option. Usually it receives sound from a satellite receiver also. Now it is mute. It is connected to a pair of JBL H-F...
Hi,sorry for my dumb question...is your receiver 's "MUTE" switch is ON or OFF ? because your description relates directly to this feature..if it is on make sure you switch it OFF but before doing this pls make the volume minumum..
if problem continues pls let me know for further help..
Hope this helps!..if more help requires pls let me know.
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 18, 2011 | Audio Players & Recorders
I cannot get sound from my sony tv (ldl 40bx420) to play through my strdh520 .....my blue ray sony bdp s580 sends a nice signal through it to the speakers.....I have tried every tip in the manual to try to...
Depends on your sources and connections. If you have Cable Box, DSS, FIOS, etc. Audio would be from Coaxial or Digital Optical from the respective source. You would need to check the Audio settings on the Cable Box, DSS, etc. If you are using Cable or off-air, direct from the TV, it would be connected from the analog audio (rca) or Digital Optical output from the TV and The Audio out setting on the TV should be set to Fixed. On the Sony Receiver, make sure all inputs in settings menu for audio are set to auto. Hope this helps, if you still have a problem, post a reply/comment with any other equipment you have connected between TV & Receiver
Jun 27, 2011 | Sony STRDH520
Where do the cables go for pic and sound
You can find the manual here if you need a copy.
This system was sold with speakers and connecting cables. One cable connects from the main unit to the subwoofer. The rest of the speakers supplied with the system plug into the subwoofer with their special connecting cables. If you don't have the subwoofer and satellite speakers along with the cables, you can't get sound out of this system. There is no built-in amplifier and no way to connect speakers otherwise.
The video connection to your monitor or TV is from the rear panel on the main unit. You can use an s-video cable, composite video (a single cable with RCA plugs) or component video (3 RCA cables), depending on the inputs supplied on the TV. Component video gives best performance if the TV supports it.
Jun 21, 2011 | Philips HTS3440/37 System
I have this receiver hooked up to a Vizio LED tv and a Vizio Blue Ray using HDMI cables. The surround sound works from the speakers while watching a dvd (HDMI -1 connection) but I have no surround sound...
AV cables don't pass surround sound through, they are pretty much just left and right stereo. You need to turn pro logic on on the reciever to "pretend" to play surround. The better option of course would be to use a digital signal like another HDMI cable or digital optical audio from the cable box, if thats what your using.
Jun 16, 2011 | Yamaha RXV467 Receiver
No sound when HLN5065WX/XAA is turned ON. No sound from the TV speakers or from my home entertainment system. Does the TV have a sound card? Can it be replaced? Any ideas. Thanks
f you are using Cable, DSS, or FIOS, etc, check the audio output from the box in Audio settings menu. make sure you don't have "Bitstream" selected most common audio connections are PCM (digital optical) Coaxial (single audio RCA) or HDMI with audio passthru. If those settings are correct, check the Audio settings on the TV and on the AV equipments Audio input. If you still have an issue, post a reply/comment listing all your equipment's model #'s and I can help you further.
Jun 14, 2011 | Samsung Televison & Video
Hi, I bought recently a new 5.1 Surround Sound System Logitech X-530 and want to connect it to our new LCD LG 32LD450 HD TV. The LG TV has apart from all Digital, Optical and RCA Connections as well one...
You can't connect the speakers to your TV. I doesn't have any audio output available, just inputs. Those are for connecting the audio from sources like DVD players, and they go in to the TV's sound system. But there's no way of getting the sound out except through the set's internal speakers. The surround system you got is great for a computer, but it's not what you need for TV use.
The only solution I can offer is the suggestion that you invest in a home theater receiver. You can get decent basic systems with the receiver (often with DVD/audio CD playback capability built in) and surround speakers at reasonable prices. Then you use that to drive the speakers, and use the TV just as a video monitor. Then you will have surround sound.
Jun 01, 2011 | Logitech X-530 Computer Speakers
Can't get picture after connecting to receiver nad speakers
Sounds like something got confused in the re-wiring...if the TV signal from cable doesn't involve a box, then the co-ax should go straight to the "cable in" or "RF in" on the TV, and the sound equipment gets connected to output ports on the TV. Otherwise, try bypassing the video connections on receiver or whatever and go directly to TV...My surround sound has video in and out, but I've never used them, it doesn't matter.
Feb 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Open Questions:
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
