Question about Acer Aspire 5252 5253 5336 5552 5736 5736g 5742 Lower Case 60.r4f02.002 Uma
Acer aspire 5253 power button broken due to hinge The left hinge behind the power button is broken. When I go to lift the cover of the aspire the hinge causes the laptop bottom and top to separate. i
Acer aspire 5253 power button broken due to hinge The left hinge behind the power button is broken. When I go to lift the cover of the aspire the hinge causes the laptop bottom and top to separate. i hesitate to pry it open?
3 Suggested Answers
  • 171 Answers
SOURCE: my laptot as started cracking near the left hand hinge
superglue it or epoxy it back together. that's about all you can do.
Posted on Feb 20, 2009
SD Tech
  • 14553 Answers
SOURCE: acer aspire 5253 power button broken due to hinge
Have a repair shop or person look at this---it may be fixable now but if you keep using it the issue may get worse.
Posted on Nov 06, 2012
Nov 05, 2012 | Acer Aspire 5532 15.6" Laptop Original...
Acer aspire 5253 error message no botable device after laptop was dropped on carpet
No bootable device suggests that your Acer Aspire hard disk may have been damaged when the computer was dropped.
You should try opening the cover on the base of the laptop where the hard drive is fitted and check to make sure that the drive is seated firmly and has not come loose with the drop. See the Acer Aspire 5253 Quick Start Guide for the location of the drive cover.
If reseating the drive does not help, then you would need to find any recovery discs that you may have made or received with the laptop plus need to buy and install a replacement hard drive.
Jan 10, 2012 | Acer Computers & Internet
Hi,, i just want to know how to replace a keyboard of acer aspire 6920, many thanks.
with the unit upside down, and the battery towards you.
remove all screws behind the battery, under the battery, and the ones to the immediate left and right. make note as they are different lengths and have to be put back in the same place. failing to do so will ruin your middle cover.Slide off the hinge caps, then flip the unit over and open like you are using it.gently lift the keyboard cover up and towards you slightly. then you will be able to lift the keyboard out.be careful to not disconnect the 2 cables on the middle cover.I do not recommend this to anyone as you can break it. However it's your toy, just don't cry if you break it.
Feb 20, 2010 | Acer Aspire 6920 Notebook PC
The cover broke at the left hinge, lifting it from the base
u could buy a new screen or mayby for a quick soluition u could super gule it but i got no other ideas
Jun 24, 2009 | Acer Aspire 3610 Notebook
Power Board Problem and Power Button Hinges Top Cover broken
It would be cheaper to have the power board repaired but the replacement is around $55 from ebay. I'd get a new moulding for it if its available or even if you got somthing plastic welded up.
http://cgi.ebay.com/Acer-Aspire-3050-3680-5050-Power-Board-w-dc-jack-usb_W0QQitemZ120415274982QQihZ002QQcategoryZ158887QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope this helps
May 06, 2009 | Acer Aspire 3680 Laptop
Were can i get a new lcd rear cover for my acer aspire 3610 as mine is broken at the left hinge
You will probably have to get one from a bone yard. Have you tried EBay?
Mar 17, 2009 | Acer Aspire 3610 Notebook
Hinge Problem
Acer Aspire 3020 / 5020 Series Service Guide
Download it, extract it, open it, scroll to page 49-62 for disassembly.
Nov 29, 2008 | Acer Aspire 3050-1733 Notebook
Acer aspire 3000
There are 3 screw behind the laptop, on the back of the screen hinges. Remove them then open the laptop, and with your finger nails, lift the power cover closest to the screen, it will then raise and you will be able to remove the keyboard.
Jul 26, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 5252 5253 5336 5552 5736 5736g 5742 Lower Case 60.r4f02.002 Uma Logo
117 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
