Question about Mitsubishi WS-65513 65" Rear Projection HDTV
MITSUBISHI WD-65732 WON'T START UP
TRIED RESET BUTTON. TV WILL START TO TURN ON, SOLID GREEN LIGHT WILL GO ON FOR ABOUT 15 SECONDS OR SO, I HEAR THE NORMAL WHIRRING STARTUP SOUNDS AND THEN THE TV GOES DEAD AND THE GREEN LIGHT SHUTS OFF.
  • 25 Answers
IF YOUR LUCKY YOU MAY HAVE A BAD GROUND ON ONE OF YOUR VISUAL INPUT CABLES.TRY ,THE COAX,THEN THE YELLOW 480,THEN THE RGB 1080 AND OR THE DVI.SEE IF YOU CAN AT LEAST GET AUDIO GOING ,IF NOT ,THE REPAIR DUDE WILL START WITH YOUR CAPS ,SOUNDS LIKE THE FIRST ON YOUR STARTER IS OK BUT THERE IS OTHERS THAT START YOUR GUNS (VISUAL) AND THEN THERE IS OTHERS THAt kick on your transformer audio.I hope for your sake
you have a short in a audio or vid and its stoping you from cooking somthing.,Use your nose and touch ,look for a new or old fire ,if you see a punch of circuits laying horzontal and smell theres a good change there connectrs melted and the weightt of the cap or resistor,or transistor bent the soft melting metal. FIRST CHECK YOUR WIRES IF YOU HAVE JUST ONE LITTLE THREAD CROSSING IN TO THE OTHER SIDE YOU MY AS WELL BRING SID BARRETT BACK WITH FLOYD .A LOT OF REPAIR MEN DONT LIKE WORKING ON THESE MONSTERS YOU WILL HAVE TO HAVE SOMTHING MORE THEN BEER AND OR MONEY PERHAPS ONE OF YOUR CHILDERN MAY DO IT.
FIND SOMONE CRAZY ENOUGH TO WORK ON IT.
Posted on Feb 08, 2009
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
Mitsubishi WD-73733 green blinking light will not turn on.
This is know as the blinkling light of death. You can get parts - just google TV Repair Kits
Mar 26, 2012 | Mitsubishi WD-73733 73" HDTV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
How do I reset my mitsubishi diamond tv? The green timer light is flashing.... I can't get the tv to come on.
If the light continues to flash with no picture and you still get sound, your bulb is out. Though it could be any number of issues. To reset a Mitsubishi, hold the power button down for approx. 10-15 seconds until you hear a faint click.
Jan 11, 2011 | Mitsubishi Diamond WD-65831 65" Projection...
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
My 2 1/2 yr old Mitsubishi 65 inch DLP will not turn on.E code 12
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
May 01, 2009 | Mitsubishi WD-65732 65" Projection HDTV
My Mitsubishi 65 inch DLP will not turn on. I tried to turn it on last night and the tv seemed to power up but no picture was present. I tried to reset, and the same thing happened. I pressed the Menu...
looked up owners manual that was a waste of time, hmm the number one issue on this type of set is issues with the lamp. How old is it? Has it ever been replaced? Sometimes a visual inspection of lamp can fool you, but typically as they age a milky haze develops on the lamps glass or if it popped the lamp will be shatttered inside. Can't hurt to check it. make sure set is unplugged first just to be safe.
Apr 30, 2009 | Mitsubishi WD-65732 65" Projection HDTV
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
212 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
