Question about Texas Instruments Ti Nspire Cx Cas Graph Calc Tch N3cas/C
Why does the TI-nspire not give complete graphs of cube root and other franctional power functions?
Since upgrading to the latest version of the CX OS, I can no longer graph functions like the cube root and have it display both branches.
  • escher26
    escher26 Nov 07, 2012
    So, I switched it to real mode from rectangular and no longer had the problem. That should not matter, nor should it fix the issue, but it did. And no, I had not restricted the domain or any other such thing, also, as this was the version running on my laptop, low battery was not an issue either. Thank you for the feedback. :)
  • Texas Instru... Master
  • 7,993 Answers
I do not see why it would do that. Maybe you restricted the domain to positive values of the independent variable.
Anyway, my CX CAS has the latest OS version and it draws cube root for positive and negative values of x.
By the way the cube root is made up of one branch only, not 2 like the square root.
Here is a screen capture.
Why does the TI-nspire not give complete graphs of - 11_7_2012_1_19_42_am.png
Posted on Nov 07, 2012
5 Suggested Answers
SOURCE: Graphing radical functions
I have a TI-89 Titanium and I have experienced the same problem. HERE IS HOW TO FIX IT:
Goto " MODE " and scroll down the options until you get to
" COMPLEX FORMAT " change that option to " RECTANGULAR " and press ENTER until you exit out of the " MODE " screen. (very important that you press ' enter ' until you exit because if you don't, it will not save your changes. )
Posted on Mar 15, 2009
  • 7993 Answers
SOURCE: Graph a cubed root fuction on ti-89
Here it is
[Diamond][Y=] enter y1=(2-X)^(1/3)
[Diamond][GRAPH]
Hope you liked the graph
Posted on Sep 04, 2009
  • 1833 Answers
SOURCE: my TI-nspire isn't graphing correctly.
According to your problem, first check the battery status or replace the battery. It may occur for battery. You need a software and firmware update for this calculator. Reinstallation of software and an update of firmware will solve your problem.
Posted on Jun 16, 2011
  • 262 Answers
SOURCE: I have a TI-89 Titanium.
For example y=x^(1/3)-x+1. Type this function and then graphing it!
See captured images
Posted on Dec 07, 2011
When graphing in documents my TI nspire cas cx is stuck in relation mode instead of function. How do I reset this?
How about starting a new document, or adding a new page, or just turning the machine off without saving?
Sep 24, 2016 | Texas Instruments TI-Nspire CX CAS...
My Calculator is saying operating system not found. Install OS now. How do I install Os?
To transfer the operating system to the handheld, connect your handheld and computer with a USB Connection Cable and use TI-Nspire™ Teacher Software with TI-SmartView™ or TI?Nspire CX Student Software (Windows® / Mac®).
This is the link that will download the OS (it's free) to your computer:
http://tinyurl.com/nrkpy3e
Aug 12, 2015 | Texas Instruments TI-Nspire CX Graphing...
Ti-nspire cx CAS gives answer in degrees even though it is in radians mode.
When you set some configuration parameter you must scroll down the setup until you reach the OK button. Press the OK button to validate.
Oct 09, 2014 | Texas Instruments TI-Nspire CX CAS...
TI-nspire cx changing from degrees to radians
Press Documents Settings. On line angle select radians, AND validate the change by moving the cursor on the OK button, and pressing it.
Jun 12, 2014 | Texas Instruments TI-Nspire CX CAS...
Ti nspire cx screen is really dim.
Recharge the battery and see what happens.. Could also be that the autodim feature is fixed to the lowest value (30 s).
Apr 01, 2014 | Texas Instruments TI-Nspire CX Graphing...
Ti-Nspire gives me coordinates in radians when my mode is set to degrees.
That is a round-about way to solve cos(x)=0.543 by graphing. Use the inverse function of the cosine arccos or cos^-1
If cos(x)=0.543 then x=arccos(0.543)
To graph a trigonometric function it is more natural to use the radian as the unit. However in geometry it is more common to use the degree. To solve an equation like x=arccos(0.543) where you want the answer to be degree, change the document settings to make the default angle unit the degree.
Make the graphing angle unit the degree and set that as default by selecting Make Default and press Enter.
Dec 15, 2013 | Texas Instruments TI-Nspire CX Graphing...
How to get the ti nspire cx to give square root answers
You can not achieve this with the Ti-nspire cx. Only the CAS version will give the square root form. On the CAS there is an option in the settings called "EXACT" under calculation mode. The cx does not have this mode.
Jan 09, 2013 | Texas Instruments TI-Nspire Graphic...
I have a TI-89 Titanium. How do I graph a function containing a cubed root?
See captured images
Sep 14, 2011 | Texas Instruments TI-89 Calculator
Texas Instruments Ti Nspire Cx Cas Graph Calc Tch N3cas/C Logo
862 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
