Question about Toshiba Satellite Computers & Internet
Looking for location of coin cell battery Toshiba L300-19F
Can somebody please tell me where the coin cell is located on the motherboard. I have to reset the CMOS because the BIOS is corrupted.
  • Toshiba Master
  • 7,627 Answers
SOURCE: toshiba A135-S4527 cmos battery dead
I found where the cmos battery is located. By the Toshiba tech support website , it's next to the PCMCIA Slot, just behind it. To get to it, Take off LCD, keyboard, top palmrest, hard drive, battery, memory, top power cover,switch board, modem, network. and some others. Too many to describe here. Items to remove not in order.
I Have the service manual downloaded already.
Let me Know
comier957
Posted on Aug 10, 2008
aayushik
  • 59 Answers
SOURCE: How to reset BIOS password - Toshiba Satellite 1605 CDS
you dont have to take the battery off, just unplug the cmos connector which looks like a stereo wiring harness.
Posted on Nov 14, 2008
  • 13 Answers
SOURCE: want to replace cmos battery in Toshiba Satellite A10
On Toshiba laptops you hit the ESC key as soon as you turn it on & then you
are given the option to hit the F1 key to enter bios.
As to the cmos battery, they couldn't have hidden it better if it was the Queen's diamond!
It is near the bottom of the laptop on the right side, almost directly beneath the pause/break key.
Problem is, you have to disassemble the entire laptop to get at it!
Disassembly instructions for the Satellite A10 are here
http://www.irisvista.com/tech/laptops/ToshibaA15/SatelliteA15_laptop_disassembly_1.htm
Best of luck
Barb
Posted on Mar 03, 2009
SOURCE: Trying to locate the cmos battery for Toshiba Satellite L25-S121 laptop?
On the Toshiba Satellite L25 S1217 Laptop, the battery is indeed to the left of the wifi card. I was having a problem with a bios password and had spent a considerable amount of time looking. However Instead of taking the whole laptop apart, I removed the wireless card and used a precision flathead to maneuver the connector out of it's socket. after a few seconds I booted the laptop, with the battery still disconnected , and no password prompt! using the same screw driver, I was able to get the connector back into it's socket, and put the wireless card back in. it runs fine now. the trick is to only pull the connector out only enough so that it's not making the connection, if you pull it too far you will have a tougher time guiding it back into the socket. I hope this helps a lot of people with the same problem.
Posted on Apr 30, 2009
  • 13 Answers
SOURCE: Dell C610 battery cmos/bios
The removal and replacement instructions can be found in the dell service documents available at support.dell.com. You can look it up by service tag or model number. But in short, the procedures are. 1. Remove the hard drive, then remove the keyboard. The keyboard is removed by removing the 5 screws on the bottom of the laptop marked with a "K" beside them. Then the keyboard can be removed. be careful not to tear the ribbon cable, and you do not have to remove the ribbon cable. The battery will be in the center of the opening, it will have a white plug that plugs into the keyboard. Contrary to Ayyasam's recomendations above, it is not necessary to remove "all" the screws on the bottom, nor is it necessary to remove the bottom of the laptop. It should be a 5 minute project. Again for any Dell item, the factory repair manuals are available online, and have exact instructions including pictures and diagrams.
Happy Computing
Daver56
Posted on Nov 05, 2009
Bios password reset for toshiba tecra a8
Locate the coin cell battery on the motherboard (that may be tough) if it's not easily accessible and remove it for a few minutes. This will erase the bios password. You will have to reset the time and date after you reboot.
Sep 03, 2017 | Toshiba Computers & Internet
I changed the battery on my D630 and lost the date & time. I assume the cmos battery is bad. Where is it located on a D630 and what is the battery #?
CMOS Coin-cell is located under the keyboard. You have to remove the hinges cover and keyboard to access the coin -cell
Please study the following two links giving clear instructions about changing the coin-cell battery of Dell D630.
http://laptop-disassembled.com/latitude-d630/how-to-replace-the-coin-cell-battery-on-a-dell-latitude-d630/
http://support.dell.com/support/edocs/systems/latd630/en/SM_EN/coincell.htm#wp1113924
Let me know if any clarification is needed. Hope this helps!!
CreativeTECH
Nov 19, 2010 | Dell Latitude D630 Notebook
How to change cmos battery
Locate your CMOS battery
cmos.gifOpen the computer case and find the battery on the computer motherboard, verify that it will be accessible and that it can be removed. Most computers today use a coin cell CMOS battery as shown in the image to the right.
If you are unable to locate your CMOS battery you will need to refer to your motherboard or computer documentation and/or contact your computer manufacturer for additional assistance in locating it.
Obtain battery information
Unfortunately, most manufacturers will not list the exact type and model of your CMOS battery; therefore, once you have located the battery, write down all information about the battery (Voltage, chemistry, wiring, and packaging). If possible, remove the battery and take it to the location you plan on purchasing a new battery from.
Additional buying information can be found on our battery buying tips page.
Removing the battery
Caution: While in the computer make sure you're aware of Electro Static Discharge (ESD), your computer is off, and that you're properly grounding yourself. Especially before removing the battery.
If you're computer is using a coin cell battery similar to the above example picture. Removing the battery is relatively simple. Simply use your fingers to grab on the edge of the battery and pull it up and out of the container holding it. Some motherboards have a clip holding the battery down. If your computer has this clip you may need to use one had to move the clip up and the other hand to pull the battery out.
Unfortunately, not all CMOS batteries are removable; some manufactures will only allow a replacement battery to be added. If you're not using a coin cell battery and are not able to determine how to remove it refer to your motherboard or computer documentation and/or contact your computer manufacturer for additional assistance in removing the battery or how to insert a new replacement battery.
Users with computers that do not have removable batteries only options to install a new battery will most likely also need to set a jumper when adding the new battery into their computer.
Insert the new battery
Once you have purchased a new battery, remove the old battery (as instructed above) and replace it with the new battery.
Enter CMOS values
Once the battery is replaced turn on the computer and enter all values back into CMOS or set the values back to the default settings. Additional information about getting the values back to default can be found on document CH000970.
After the values have all been entered make sure to save the settings before exiting. Many CMOS setups allow you to press a key (such as F10) to save values and exit all in one action.
If after following all the above steps you continue to experience the same error when your computer starts and/or your computer is still unable to keep the stored values it's likely that you're experiencing a more serious issues. Most likely causes are bad power supply or bad motherboard.
May 30, 2010 | Toshiba Satellite A60 Notebook
Trying to get the backup battery out but cant find it need help to tell me where it is
Once you remove most of the casing to your notebook and gain access to the motherboard look around the corners and all over it. There will be a button batter about the size of a quarter or smaller on the motherboard. It may be sitting in a socket designed for the button cell battery or it may be wrapped in black shrink tape and plugged into the motherboard by red and black wires.
Jan 09, 2010 | Computers & Internet
Bios password forgotten on toshiba 2180cdt please help
Remove the battery, open the chassis and locate the internal backup battery (size of a small coin), disconnect it and let it stay disconnected for 24-48 hours.
Reassemble and you are ready to go!
Apr 19, 2009 | Toshiba Satellite 2180CDT Notebook
CMOS Battery location on samsung vm8000
cmos battery is underneath. Take off fan cover. remove fan screws x 4. Then lift black cloth on right hand side. You will see the offender. Lift the battery from the left hand side gently with a small flat head screw driver....
Dec 10, 2008 | Samsung Computers & Internet
Bios password screen popped up, will not reset
the battery is located on the motherboard inside the laptop, if you are not familiar with opening a laptop, i suggest you let somebody with experience do it.
Dec 04, 2008 | Toshiba Satellite A135-S4527 Notebook
Lost system password
Only way to remove a BIOS password on any computer is to remove all power sources from the motherboard so its memory can be cleared.
First, remove the main battery from the laptop. Then you must locate and find the little coin cell battery (It looks like a watch battery) on the laptop and remove it for about a minute or so. Then you can replace them in the opposite order.
Your coin cell battery is in a bay on the bottom of your computer. Enjoy!
1. Before removing the coin battery:
2. Locate the memory module cover on the bottom of the system.
exmem01.jpg 3. Use a Phillips screwdriver to remove the two screws securing the cover.
4. Lift and remove the cover from the system.
5. Locate the coin battery.
6. Use a fingernail (or small flathead screwdriver, if necessary) to release the battery ZIF connector.
exmem08.jpg 7. Remove the battery from the chassis.
8. Reverse the previous steps to replace the coin battery.
May 06, 2008 | Dell Latitude C400 Notebook
Lost password for my packard bell easynote
Unfortunately, some laptop coin cell batteries are difficult to locate, or require an in depth dissection of the laptop to get to them. Without the model of the laptop, I cannot tell you how to get to it.
Apr 24, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
174 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
