Question about Bosch DWM40L Miter Finder Digital Protractor/Angle Finder
Bosch DMW 40 L makes a clicking noise when it is on.
Noise starts when it is swithed on. Quits when it is switched off. Seems to read ok, but can't figure out what could be causing the noise. Noise seems to come from the pivot area.
SOURCE: Strange noise from my Bosch Dishwasher SHU66C02UC/14
my dishwasher started making a load noise last night found out it was the pump . It was a easy fix to access the pump you need to remove the outer side of the door and the bottom cover .then you can see the pump .to remove it you need to remove the clear hose in front of it .it just pulls out of the tank sealed by a o-ring move it out of the way next unplug the wires to the pump .then you will see a plastic clip on top the pump just push the clip and turn the pump clock wise about a half turn and pull it out replace new one make. sure you get all the water out off the bottom tray before running theres a swicth that will keep the pump running if leak
Posted on May 08, 2008
SOURCE: Squeaks from drum area during operation
We have a Bosch Nexxt dryer and it, too, squeaks during operation. We have not been able to find a permanent solution for this problem although we've had the repairman come out 3 times now. We have however found a temporary solution that lasts for about a week. We spray Static Guard (in an aerosol can) in the inside lining of the dryer... kind of in the lip of the front. (You shuld be able to feel it if you put your hand right inside the door.) We've just been spraying the static guard all the way around that area and the squeaking stops! Hope this works for y'all. May not be permanent but at least it stops the annoying sqeaking!
Posted on Jan 18, 2009
here2helpBSH
  • 27 Answers
SOURCE: Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Posted on Mar 19, 2009
  • 414 Answers
SOURCE: started making loud "clicking" noise
Blocked pump, open flap bottom right, drain off excess water manually and remove pump filter. Make sure you get right down and have a look in at the impellor and give it a turn to make sure its free to rotate. You'll probably find a coin, button etc that is catching the pump impellor. When you start a cycle the pump engages for a few seconds and then the w/m takes in water, so if something is stopping the impellor rotating the w/m will not start.
Best of luck
Posted on Jul 13, 2010
SOURCE: need bosch dishwasher manual
Try putting in your model number here to get access to documentation....
http://portal.bsh-partner.com/portal%28bD1lbiZjPTA2MA==%29/PORTALFRAME.HTM
Posted on Jun 02, 2012
2008 explorer starts with jump, shut off will not restart, clicking noise
clean battery posts and cable ends and make sure to tighten securely when done
Aug 31, 2014 | Ford Explorer Cars & Trucks
Snapping noise then quits
Not sure what model yours is, but sounds like you have a bad start capacitor that has dried up or swelled and "snapping" when making connection. If you can give me the Brand and model number I can see what capacitor you need.
May 12, 2014 | Dometic Rooftop RV Air Conditioner
My bosch clasixx wont start fills and drains ok but just clicks
Possible motor brushes, worst case scenario..motor fault. Put the dial to off, hold the start button whilst turning selector one click left to 30 easy care, turn the dial to 40 cotton (without going thru the off ie all the way round anti clockwise) press start. This will activate the motor test, if you get two lights flashing separated by a led that is off this is a motor fault. (Not necessarily the motor complete, also will indicate loss of contact in the brushes). If it is a model with a display it may show F05. Happy hunting.
Nov 21, 2011 | Bosch Washing Machines
When engine is started, heater door makes clicking noise for 20 seconds and quits. When engine is shut off, heater door makes clicking noise for 20 seconds and quits. Door makes clicking noise when heat is...
Your air temp control blend door actuator is failing, that is the part u call a heater door, it is a gear driven miniature drive, the gears are jumping teeth making the noise, it will stop working very soon.
Apr 24, 2009 | 1998 GMC Blazer
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
4JX1engine cut off and not starting
Its the oil ! 15/40 is too thick it should be 5/30 or 10/30 fully synthetic .
The woosh noise is ok just the erg flap coming open .
Oct 27, 2008 | 1999 Isuzu Trooper
Bosch DWM40L Miter Finder Digital Protractor/Angle Finder Logo
135 people viewed this question
Top Bosch Measuring Tools & Sensors Experts
Vuk B
JonSnell Electronic
JonSnell Electronic
Are you a Bosch Measuring Tool and Sensor Expert? Answer questions, earn points and help others
