Question about Frigidaire Washing Machines
Frigidaire model gleh1642fso washer will not rotate
Will not rotate
2 Suggested Answers
SOURCE: our washer dryer model GLEH1642FSO will not
sounds like the motor needs new bushes, same thing happened to me last yr, regards paul
Posted on Feb 13, 2010
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
Error code E58
If you have a front-load washer that was manufactured by Frigidaire, the E58 error indicates high current on the motor. This could mean that the motor is bad, the bearings that the tub spins on are bad, or a problem with the speed control board. To test this, you'll need to access the motor and tub area of the washer. Unplug the power before opening the washer. Take the belt off the motor pulley and check if it spins freely. If it doesn't, then replace the drive motor. If it does spin freely, check if the large pulley on the tub spins freely. If that doesn't rotate, you'll need to replace the outer tub and spin basket in order to replace the failed bearings. If the pulley rotates easily, you'll need to check the motor windings. If the resistance is between 4-6 Ohms, the speed control board is probably faulty. If the resistance is not in the correct range, the motor is bad and needs to be replaced.
A Frigidaire washer technical data sheet is available here: http://manuals.frigidaire.com/prodinfo_pdf/webster/134542000.pdf .
If your washer is under warranty, contact the manufacturer. If you add a comment with the model number of your washer, I may be able to provide a source for the parts.
I hope this helps.
Apr 27, 2016 | Washing Machines
Clean tub options keeps blinking on affinity frigidaire fafs4474lwo model
Hello Jodi, thank you for your post!
Your Frigidaire washer (FAFS4474LW0) will automatically prompt you to run the CLEAN WASHER cycle typically every 50 cycles. If you wish to begin the cycle, press SELECT when prompted. This maintenance cycle uses hot water and two rinses to remove residue that may cause odor. For best results, I recommend to use the CLEAN WASHER cycle once a month
You may press the CANCEL button to manually perform the cycle at another time if you prefer. You can do this by following these directions:
    ·Rotate cycle knob to Rinse & Spin
    ·Then press the CLEAN WASHER option button
    ·The LCD screen will display "SYSTEM CLEAN"
    Hope this helps! - Z
Jul 19, 2014 | Frigidaire Fafs4474lw Affinity 3.81 Cu Ft...
How to balance a frigidaire washer?
Hello - Are you speaking about being balance without the leveling legs? Is the unit located on complete level ground? Or is the washer tub loose and unable to move? If you are referring to the drum, try rotating it manually when it is turned. If you notice that the drum is not balanced and cannot rotate freely, I would suggest contacting a professional so they can move forward accurately. Washer may possibly have a faulty bearing, unbalance drum or pulley issue.
Dec 06, 2012 | Frigidaire Washing Machines
Frigidaire front load washer model LTF7000ES0 got out of balance with a heavy pillow and we had to stop it. Now it won't do anything. Everytime I start it, the door light comes on as usual, then a
Check to see if the door sags at all and doesn't line up correctly with the door latch. Then check to see if the drum wobbles when you rotate it yourself when not in use.
Jul 30, 2012 | Frigidaire ATF6000ES Front Load Washer
Our washer dryer model GLEH1642FSO will not
Feb 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Washer Model #WILL-1 - won't spin or pump out water
Can you access the location of you motor?
try to open the back and unscrew the cover and see if you can see the motor, try to start it but don't get near to much just enought to see if it is moving or not.
if it still running and rotating see the belt maybe it is too loose or maybe it is to tight,
But if it just humming, turn it off and unplug, see if you can rotate the motor with your hand, if you can then you'll need a starting capacitor, you got to buy one and install.
But if it is hard to turn even without a load, then you'll need to bring your motor to a service center to check for the bushing and shafting and lubrication.
your motor winding is still ok since you heard a humming sound, that problem would be the mechanical part.
Nov 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer won't spin, belt looks good, makes noise
Don't have much experience on Frigidaire. Is the motor a brush type, capacitor type or one of those new DC types? If it's got brushes and they are ok, then I would say your armature is up the creek. If it's a capacitor type (unlikely) then the capacitor is most likely duff. If it's the new DC type it could be a lot of things, most likely the module which breaksdown and passes an AC component in the motor supply which make the motor tremble but not rotate
Nov 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Front Load Washer FWFB9100ES1
Diagnostic Test:
The diagnostic test is performed by using the Program Knob. To START THE TEST:
• On non-digital display models, turn the Program Knob to start position, Drain/Spin.
• On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that
can be rotated 360°, turn the Program Knob to start position, Drain/Spin.
• Press Pause Cancel to turn off LEDs.
• Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then
release buttons.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Washing Machine Model 975FS2
all wsher have bearings which hold the drum centrally if these are worn than the machine will make a noise and get louder on spin and will only get worse sometimes cheaper to replace washer than it is to fix your bearings sorry m8
Aug 11, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
