Question about Water Heaters
Richmond Model 6G40-36F1 hot water heater manual
  • 744 Answers
SOURCE: pilot light on water heater goes out frequently
Check the following:
See if your heater has a pilot gas adjustment valve. It should be on the gas control valve somewhere. Not all heaters have these. It will be a screw on the valve that can be turned.
Make sure the thermocouple sensing bulb is squarely in the pilot flame and also check that the fitting where the other end of the thermocouple connects to the main gas valve is tight.
Check the pilot gas orifice (where the pilot gas comes out) for carbon build up - you may need to remove the pilot gas line and thermocouple assembly to get to this. This problem is pretty common.
Check the gas pressure to the heater. Run the hot water in the dwelling until the hot water heater starts. Check the flame on the main burner and see what color it is - it should be blue with possibly some yellow-tipped flames. If not, there could be a problem with the gas pressure at the heater or venting. If the heater has a gas pressure regulator, it may be out of adjustment or defective.
Finally, and this isn't very common, the pilot light can be extinguished if there is a draft problem, usually associated with an issue with the flue pipe venting system for the heater or another nearby gas consuming appliance.
Posted on Dec 31, 2009
Testimonial: "thank you. will try these suggestions tomorrow. really appreciate it."
robocop
  • 90 Answers
SOURCE: need reset code for hot water talk
Go to www.richmondwaterheaters.com and see if they can assist you with it. Just click on residential products on the left side of the page.
Posted on Jan 22, 2009
  • 74 Answers
SOURCE: water heater not heating it's a richmond water heater
Now change the thermostats........this is the only other thing it could possibly be.
Posted on Apr 27, 2009
SOURCE: need reset code for richmond
I am poting this here hopefully it will help someone else. I have a richmond 40 gallon power vent water heater and it was not working. It was flashing 2-3 on the LED. I used this procedure and it started up..
you can reset the control by unplugging the blower during start up, leave unplugged for at least 5 seconds, plug back in and within 30 seconds cycle temp control from hot to low 6 times.
Posted on Apr 13, 2010
SOURCE: i have a richmond gas hot water heater model
lock out code....turn off unit for 1 minute (unplug) press both arrows and hold for 5-10 sec... then enter L R L L ... R L R R...that should reset it.
Posted on Jul 25, 2010
Is the Richmond 6g40-34pf hot water heater a model with or without powervent
According to photos listed for that specific model... it is NOT power vent.
It is ordinary atmospheric gas water heater with 3" vent pipe
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
Water Heater Timers Save Money
Mar 04, 2015 | Water Water Heaters
Richmond powervent model 6G40PV-40F Lockout 4-2 blink. What's wrong. What do I replace to fix?
1) Rheem-Richmond does not post service manuals:
Copy following link to identify service manual by type of gas control valve:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
2) For lockout, the air intake might be clogged or combustion parts dirty, causing overheating which will break TRD glass vial. Gas control may need to be replaced. Reset gas control by rotating knob to lowest temp for at least 6 seconds.
3) Call Rheem or local service tech.
Mar 10, 2013 | Water Heaters
I have a recently installed richmond water heater. When the shower is running and someone turns the faucet on in the kitchen the water gets drastically colder in the shower. We didnt have that problem with...
Which type Richmond water heater?
Is this a tankless water heater or tank-type?
Tankless are notorious for 'cold water sandwich' under exact conditions you describe. You might need tankless with larger BTU burner.
Don't install a tankless.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If you have tank-type water heater, then I suspect a clog in the hot water line, or single-handle faucet cartridge in show is going bad.
Same problems can contribute to tankless problems.
http://waterheatertimer.org/Low-hot-water-pressure.html
Aug 06, 2012 | Rheem Richmond
I have a richmond power vent water heater model number 6G40POW-40F.It will run for 2 min then shut itself off then restart and do the same thing all over.Then 2 lights come on and it wont run. Any help...
Fastest way to solve water heater problem is call plumber or service technician.
Open following link for typical error codes for intellivent gas valve found on newer Richmond/Rhemm power-vent gas water heaters:
http://waterheatertimer.org/pdf/Intelli-vent-gas-valve2.pdf
http://waterheatertimer.org/pdf/Intellivent-service-manual.pdf
There is no 100% sure way for novice to repair gas water heater.
This is because electrical parts have to ohm-tested using information from service manual that is typically not sent with new water heater.
Also parts have to be cleaned. The gas pressure checked, air in gas line removed, burner tubes and pilot tube and combustion chamber cleaned, burner parts inspected for problems, air intake cleaned, exhaust vent tested.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Best way for do-it-yourselfer to solve water heater problems is to learn as much as possible about specific model by reading product manual that comes with new heater.
The manual will show error codes.
Then keep up with yearly service recommendations shown in manual.
Aug 03, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I GET NO HOT WATER
needs drop tube or full replacement
Jul 27, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Need reset code for hot water talk
Jan 17, 2009 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Water Heaters Logo
2,923 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
