Question about Kenmore HE3 7.0 cu. ft. Super Capacity Electric Dryer
Won't heat up - Kenmore HE3 7.0 cu. ft. Super Capacity Electric Dryer
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 10, 2012
Replaced coils & igniter but dryer won't heat. Tested all thermostats and they read good. Can't see if the igniter is glowing or not.
check psu to ignitor and the main burner valve sets and resets
you can do this manualy by removing the thermocouple and testing the burners does it try to strike??? and doesnt burn or does the burner try to come on then go out if it wont strike perhaps the door catch isnt right you dont give a make model etc details so its hard to even guess,,,?
Dec 20, 2014 | Dryers
Was frozen now thawed w/ new fuel filter still won't start
Fuel pump may have ailed this time.. You need to have fuel pump checked.
Jan 31, 2013 | 2000 Ford Explorer Eddie Bauer
I have a montgomery wards furnace model srm54013a. won't shut off, keeps putting out heat
SOUNDS LIKE A BAD THERMOSTAT OR THE RED & WHITE WIRES IN BACK OF STAT ARE TOUCHING ONE ANOTHER COMPLETING THE CALL FOR HEAT.
Dec 25, 2012 | Heating & Cooling
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace
4.open heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective
6.fan or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 | Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
My dryer is tumbling & blowing & all the cycles seem to work but it won't heat.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Frigidaire AEQ8000FG Dryer
I want to add a quart of LUCAS synthetic tranny fluid, into my 2000 Alero, would that hurt.
I wouldn't put anything in your trans but the correct fluid
If you want to believe all the advertizing & other advice,
go ahead
I once owned a trans repair shop & never used any
of those products.
Obviously there was a reason
Just like putting injector cleaner in your gas tank
12 oz in 18 gallons of fuel, Won't do a thing
You WILL NOT FIX ANY trans problems changing
fluid or adding anything. Simple won't work.
Fluids are for heat removal,so how would they do
anything else?
Jul 29, 2011 | 2000 Oldsmobile Alero
Rider loses power after mowing for 30 - 45 minutes. Gets to a point, it won't climb a small incline. Engine sounds good & the deck runs fine. Just won't go.
Hi, the hydrostatic drive is most likely over heating. Remove the battery and battery carrier, from here you can clean all grass and debris from the hydro cooling fins and fan. Hope this helps, regards Phil.
Jun 01, 2011 | John Deere Garden
Kenmore HE3 7.0 cu. ft. Super Capacity Electric Dryer Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
