Question about Refrigerators
Wont switch fan speed - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 06, 2012
Why won`t the fan of my venmar range hood turn off?
Sounds like you may need to replace the fan switch. The fact that it wont turn off and that it only works on low speed supports that switch is broken.
Apr 24, 2014 | Venmar Kitchen Ranges
Blower fan not working
The resistor bank is bad for slow speeds, the switch is bad for high speed. In your test, you have voltage, but the switch wont carry the amps, to run high speed. Open circuits will not blow fuses. Replace both switch and resistor bank for all speeds. Make sure to clean leaves and trash from fan housing and see if fan spins freely.
May 17, 2017 | Cars & Trucks
I have a dimmer switch installed and it wont work with the celing fan
Your question has two switches and 1 dimmer.
The fan switch works.
The light switch works.
The dimmer does not. What is the dimmer connected to?
Dimmers typically will not control fan speed unless they are rated to do that.
Do you have a 3-way switching where two switches control same light, and you installed the dimmer in place of 3-way switch?
Sep 06, 2012 | Westinghouse Contempra Trio 42" Ceiling...
95 Buick Lesabre fan motor wont run Have power to fan when fan switch is off and in low speed & medium but goes of whe put in high speed help
you need to look at the blower motor resister some times when they burn out it jumps to the other terminals
Jul 07, 2012 | Cars & Trucks
MY CAR BEEN LEAKING COOLENT AND NOW THE HEATER FAN ONLY WORKS ON 4 SPEED 123 WONT COME ON
leaking coolant has nothing to do w/heater fan. maybe just bad switch. check fan switch.do need to fix coolant leak to.
Nov 24, 2010 | 2000 Ford Focus
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
First 2 speeds of the fan wont work for heater
sounds like the switch and is fairly easy to remove and replace the switch ..
Sep 07, 2009 | 1999 Ford Expedition
Holden rodeo 98' 4wd petrol v6
We had a similar problem . The resistor was burnt out, ( Can be fixed with a soldering iron) bit the fan was jammed . I aplied wd40 and slowly worked it by hand and it finally started to work again.. Saved me a rsisitor cost and a fan replacement. Good luck, Joe
Jul 22, 2009 | 1998 Isuzu Rodeo
Ac problem
do you mean the fan speed?there is a resistor block that needs replacing that controls the speed or the fan is no good. connect the blower fan to 12 volts after unplugging it,and see if it works properly
Jul 13, 2009 | 1989 Ford Mustang
Fan wont work on 1 2 speed
sounds like either the spd. control resister or the spd control switch. The switch is what you handle, on the dash and the resister is on the blower box.
Jun 11, 2009 | 2002 Chevrolet Impala
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
