Question about Kenmore Elite 45986 Front Load Washer
110.45087 400 How do I get to the CCU? I have had a F05 error. I need to find the CCU to check the connections etc... Where is it located?
  • jimm Nov 07, 2012
    Ok I found the CCU now where is the Temp. Sensor located?
jsrock516
  • 5911 Answers
SOURCE: F05 Error Code on Kenmore Elite HE3T Washer Model 11044932200
First of all, make sure you unplug the washer before making any measures, and make sure you unplug any connectors from the CCU, so you aren't reading parallel paths. Isolate the components you wish to test from the CCU or you may get inaccurate readings.
The reading across the heating element terminal should read 15 ohms. Make sure you aren't grounding your probe against the case, or you will get improper readings.
The NTC will read approximately what you have at room temperature. Was the connector plugged in before you began troubleshooting? A common problem is the connector falling off and generating the error code.
As far as the connector plug on the CCU is concerned, plug layouts can differ between models. Make sure you have the correct connector plug to the NTC. You may have to hand over hand it to find it. Unplug the connector at the CCU and leave it plugged in to the NTC. Perform a resistance check across the PLUG terminals. You should get the same readings as you mentioned before if the plug and wires are good. This not checks the resistance of the NTC, but also proves continuity of the wires.
Doublecheck your readings and let me know what you have. I would like to rule out a CCU problem. It is not common for this error code. I hope this helps you.
Posted on Sep 05, 2008
jmgldsmth
  • 1889 Answers
SOURCE: f05 error duet washer
this is a water temperature sensor error check the: water temperature sensor, heating element and, element relay
Posted on Jun 10, 2009
localwonder
  • 6784 Answers
SOURCE: F11 Code Error
Hi. this is a Serial communication error
This will occur when the Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Most cases, it will be a fualty wiring harness
Posted on Jul 13, 2009
jsrock516
  • 5911 Answers
SOURCE: F05 error
"F5" is a Temperature sensor (NTC) error. The following link explains:
http://www.fixya.com/support/r3608669-f05_error_code
The NTC, or temperature sensor, is located under the bottom front of the wash tub. It is a small square black plug between the heating element terminals. In many cases the connector plug comes loose and simply needs to be reconnected.
If the NTC is defective, a replacement can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The average cost is about $10. You can view an image of the part here:
http://www.appliancepartspros.com/part_details.aspx?part_id=3128829&pn_=8181705
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on Mar 23, 2010
blueextc3221
  • 15935 Answers
SOURCE: F05 error
"F05" is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge. HINT: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check. Readings will be as follows:
Temperature Meter Reading
32°F (0°C) 35.9 K ohms
86°F (30°C) 9.7 K ohms
104°F (40°C) 6.6 K ohms
122°F (50°C) 4.6 K ohms
140°F (60°C) 3.2 K ohms
158°F (70°C) 2.3 K ohms
203°F (95°C) 1 K ohms
Roughly...around 9K ohms at room temperature if I'm reading the chart correctly. Take readings as listed and also double check the connector to make sure it is not oxidized. Try cleaning the plug and reconnecting to see if the error code goes away. If not, you will probably have to replace the sensor. If the sensor checks good, take a reading across the heating element terminals. It should indicate about 15 ohms.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
F05 error
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Tip
F05 Error Code
This advice is for Whirlpool Duet and Kenmore Elite model FRONT LOADERS displaying the “F05” Error Code.
Lastly, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
I hope this information if found to be helpful.
on Dec 09, 2009 | Washing Machines
Tip
F05 Error Code on Whirlpool Duet & Kenmore Elite Front Loader Washing Machines
I hope this information if found to be helpful. If you have questions, or need assistance locating parts, please click on the following link and use the “ASK ME” feature for a quicker response.
http://www.fixya.com/users/jsrock516
on May 28, 2008 | Kenmore Elite 45986 Front Load Washer
What does the error code F05 mean on the he 4t front-loading washer?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
May 13, 2010 | Kenmore Elite 45986 Front Load Washer
Washing machine beeping and flashing code F05
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Apr 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an error f05 on hotpoint w960, i have taken the pump off and cleaned, now i need to reset the pressure switch but can't find it
Hello Sir,
You got the right way. Error F05 is an error which comes when the pressure switch is full jammed and clogged. You just need to completely clean it. To locate the pressure switch, try to locate a round switch which is more or less 4-5 inches. It has numerous connections and found mainly under the top cover.
Thank you Sir,
Have a nice day.
Jan 13, 2010 | Washing Machines
Washer is leaking tremendous amounts of water. also it is giving 2 codes F05 and FH
F05 error is an indication of a water temperature sensor (NTC) error, or Heating Circuit failure. Check the Water Temperature Sensor and check connections to the Water Temperature Sensor. To access, you will have to UNPLUG your washer and remove the lower access panel under the door. The panel comes off by removing the screws under the bottom edge.
Suggestion: If you place a block of wood under each front foot of the washer, it will make access to the screws much easier. If the panel sticks, a tap on the sides will knock it free. The panel will drop down then come off. The sensor (NTC) is located at the base of the wash tub in the front on the heating element. This will be a small square shaped plug between the heating element terminals. Unplug the wire harness and take a resistance check.
The ideal readings should be
Finally, remove the washer top panel by removing the three screws holding the panel in place in the rear. Once the screws are removed, slide the panel back then off. Locate the Central Control Unit (CCU) directly behind the wash tub. Take a resistance check at the Heating Element Solenoid by removing connector 9 from the CCU (this is the second connector from the RIGHT as facing from the front). A reading across test points 1 & 2 should also read 15 ohms.
God Bless
Jul 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What is the F05 error code for on my Kenmore elite he 4t washer
Jun 16, 2009 | Kenmore 44932 Front Load Washer
F05 error duet washer
Jun 09, 2009 | Kenmore Elite 45986 Front Load Washer
My Whirlpool Duet front load washer has code f05 and not working
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
60 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
