Question about iLO DVDR05 DVD Recorder
Tray will not open
My problem is the tray will not open. what I found when I opened the case was the arm that comes up to engage the media was very sticky. there is a ring that is glued on to the arm and the ring was very sticky. what was happening is the media was stuck to the arm and therefore the tray could not come out of the unit. when I pulled the media off of that arm, then the tray opened with no problem. I used some alcohol and q-tip to clean the sticky off of the ring and the media. so far the unit is working other then that problem. I think that it is a heat problem that caused the sticky to ooze thru the ring and onto the media. I was wondering if anyone experienced this problem.
Actually the ring is like a mylar ring that is glue onto the hub. it seems that the sticky that holds the ring on has gotten on the top of the ring and is sticking to the media or to the top assembly that the media is pressed onto to spin
Posted on May 23, 2007
    Problem Solver:
  • 6 Answers
The ring if I understand right is the hub that's pressed on the motor shaft. The solution is to replace the hub/motor assembly because of it's very critical distance of the hub on the motor shaft it's best with the factory replacement complete like that. technician:Tim Rasch
Posted on May 22, 2007
  • Tim Rasch May 23, 2007
    Another answer is if it's the hub on the clamp assembly on top of the dvd, just order this part from the factory instead of the hub/motor assembly.
    Technician: Tim Rasch
How can I open the casing for my Archos platinum?
Did you try the iFixit dod come site? there they open (not close) most modern electronic equipment. Lots of things can't be put together, because lots of apparatus, are glued together and can be opened, but can't be closed, without the correct glue to sticky tape (sometimes you have complete glue sets)
I always warn people, only seeing how it must be done, won't teach you the right skills to do it yourself.
Success
Oct 20, 2014 | Audio Players & Recorders
My tray will not open
Follow this steps:
1. turn on XBOX2. connect any media via usb (iphone, mobile phone, mp3 players, ipod, etc)3. start playing any music in your iphone or mobile phone that is connected via XBOX4. once music is playing, try to press the open button for the tray, it should work, if in case not, try to press the small hole beside the disc tray and the tray should open.
Dec 26, 2011 | Microsoft Xbox 360 Console
I have a ge quietpower 3 dishwasher. Lately it has stopped cleaning the dishes. Sometimes the dispenser tray doesn't open. Sometimes it does open and the soap pac hasn't disolved.
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Jun 10, 2011 | Maytag Dishwasher
Th cd are getting stuck in my gpx kccd6316dt, I
Is it still under warrenty?
Either it is worn out or it has a manufacturing defect.
Mar 24, 2010 | GPX KCCD6316DT Shelf System
Cd tray is stuck in open position on my HP computer
In Some Cases The Button May Be Stuck In Causeing It To Keep Pushing It Open In Other Cases The Arm May Just Be Stuck To Extending The Tray Out. I Recommend Seeking A Computer Technician If You Do Not Know Anything About Computer Componants
May 12, 2009 | HP Computers & Internet
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Noise coming from DVD player and it will not work
This is due to the mechanics inside the DVD-RW being out of place.  If you open the DVD-RW (take both the top and bottom cover off and take the CD tray out) you will see the white plastic guide that guides 2 arms as the laser mechanism lowers and raises.  One of these 2 arms is out of place and need to be pushed back in.  Also, check for a crack in the black plastic on the arms....this usually causes the arms to slip out of place.  If a crack is found, simply super glue it tigether.
Jan 27, 2009 | RCA DRC8030N
Playback problem with Samsung HT-TZ315
your case open /close tray unit having problem
1.disasample the tray unit and reasample it 2.also check tension of belts and clean tray unit properly
2. check for any physical damage "s
try all the above you solve the problem.
Oct 15, 2008 | Electronics - Others
Liteon DVD Player LVW-5115GHC+ Disk Tray stuck
The tray is either broken, or off track. You may be able to get it back on track by opening the cover and checking it out, but unplug it first, and only try this if warrantee is over and you're feeling brave...
Jan 27, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Tray will not open
My ILO was doing the same thing, then it stopped doing it. It then suddenly would not recognize any media. I opened up the case and found it is using a dvd lite-on recorder. I had this old pc laying around with a gigabyte dvd recorder in it. For a test, I unplugged the lite-on and plugged in the gigabyte recorder. On power up, it seemed to work fine. After recording 3 DVD's I modified the case to accept the hew recorder. ** problems since, its not pretty, but it was easy to get the unit functional again.
Jan 13, 2008 | iLO DVDR04
iLO DVDR05 DVD Recorder Logo
62 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
