Question about Bosch Dishwashers
How to remove kickplate on Bosch dishwasher? No power, won't run.
  • suze riley Nov 07, 2012
    our dishwasher is totally without power - although the breaker is fine - maybe mice have chewed through the wiring underneath? I want to remove the kickplate but the bolts seem to be neither screws or philips. Is there a special key?!
  • 42 Answers
SOURCE: bosch dishwasher
sounds like your control module has failed . module not allowing voltage to the heating element
Posted on Dec 21, 2008
  • 85 Answers
SOURCE: I have a kenmore dishwasher but no kickplate. How
Hello cantrell_m,
Sears appliance parts can supply you with the part you need. You will need to provide the model #. Here is their phone # (800) 252-1698.
I hope this is helpful for you. Positive feedback for me is appreciated. Thank you! NormanZ
Posted on Jul 14, 2009
  • 10865 Answers
SOURCE: remove the top from free-standing-dishwasher bosch sgs43c12
hello martin - yes you can remove the top. And no, it will not harm the dishwasher funcion.
Posted on Aug 02, 2009
SOURCE: Bosch dishwasher shu43c07uc/14 dead
Control is available.
There was a recall on control modual because of fire dangers.
Call and get an auth number from Bosch 800 856-9226
Posted on Jul 28, 2010
  • 31 Answers
SOURCE: My VZ9996U1 built-in dishwasher won't lock &
sounds like the door latch is broken, turn off power to unit and remove in side of door, about 20 screws, at th etop of th edoor you will see the latch it will have several wires going to it, you may even find broken parts (PLASTIC ) you can order parts from here http://www.appliancepartspros.com/ they have very fast shipping you just need all the info on the machine
Posted on Jul 27, 2011
How do I install miele dishwasher toe kick?
Dishwasher Kickplate (part #00446633) - How To Replace ...
? 2:07
www.youtube.com/watch?v=8GJnHVlAx5Q
Mar 5, 2014 - Uploaded by AppliancePartsPros
Buy the new Dishwasher Kickplate 00446633 http://www.appliancepartspros.com/bosch-kickplate-446633 ...
Sep 26, 2015 | Miele Dishwashers
Remove the piece behind the kickplate
would that be a part of the frame , that is not removable ?
Feb 22, 2015 | Bosch Integra 800 SHX68M0xUC Dishwasher
Remove kick plate
Tip the unit back and put your hand under each side in turn underneath, the kickplate is held on via clips near each front foot (the retainer lug is part of the kickplate) this will release it. To reinstall offer the kickplate up under the door panel and give the bottom a push to relocate the clips.
Mar 19, 2013 | Bosch SMS68M02AU Dishwasher
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Bosch Dishwasher drain mechanism starts itself a few hours after a completed cycle and won't stop. I reset the dishwasher, but it remains unusable for a few days. If I turn on the dishwasher, th
this could mean there is water leak and it collects at the base of the dishwasher leading to moisture detection circuit tripping. when you leave it for a few days the water dries up and trip is removed. check door seals for leak most likely at the base of the door. turn power off when working on dishwasher.
Jul 18, 2012 | Bosch Dishwashers
Bosch Classixx Dishwasher won't Run
Well the issue sound as if it were the timing unit. Some times work some times doesn't is a common symptoms of a timing unit. If you get the panel off take the timing unit and have it checked.
Nov 22, 2017 | Dishwashers
The front door is falling off
I don't have a Bosch, but my Kitchenaid would not stay closed; the door would fall to the floor. There are cables that run along the sides of the machine that need to be replaced because one or both have snapped. Of course, your Bosch could be different. The tech manual is generally located behind the kickplate under the dishwasher; just unscrew the two screws to take off the kickplate.
Dec 05, 2010 | Bosch SHU9915UC Dishwasher
Apr 20, 2010 | Bosch Dishwashers
Our Bosch dishwasher will not turn on. It appears to have stopped in mid-cycle - there is water below the dish rack. The circuit breaker on the main electric panel was not tripped. Thanks, Paul
check the dishwasher electrical box connection. remove kickplate. box is on r/h side. remove cover. you will probably find the wires and marettes burnt. simply repair the wires. this happens from time to time if the connection is not the best. hope that helped
Aug 18, 2009 | Bosch SHV68 Built-in Dishwasher
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
