Question about Nixon Manual NIX0031 Wrist Watch
Tighten wristband of the Nixon Watch , remove links
Hi, we just got a Nixon watch and need to remove some links to tighten the watch band. Any suggestions? thanks.
  • Anonymous Mar 21, 2014
    I need to set the time but it has the under water features
  • 2,334 Answers
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 05, 2009
    New Friend:
There is a very very way to do it. I simply use one needle and a Leather-man (heavy pain with plyers) . first you must remove one existing pin to open up the strap. To do so simply find a needle and use it to gently hammer out an existing pin. (look inside the wrist to find the correct way to hammer.) Then simply add how ever many sections, or remove visa-versa. One added, simply gently hammer new pin in. (I just my closed leather-man as a hammer. took me 2 minutes
Posted on Jan 15, 2013
You should take the watch to a local jeweler / watch repair shop in your area that deals with that brand. If not, contact Nixon by this link-
Aug 23, 2016 | Nixon Watches Mens The Graduate SS Watch...
Remove watchband from citizen black eagle watch
they will be pins like the ones in this video you will need to push them out with a punch the size of the hole,normal watch bands are spring loaded bars.
Jan 19, 2013 | Watches
How do I make the watch band smaller?
to adjust the size of your chocolate!
most watches with linked wristbands require the links removing.(small pins to b e pushed out) the type with the chain links usually have a clamp to release to slide the clasp up the band. the instructions should be with the watch manual. or ask a jeweler to help.
please post pictures if need more help so i can see the design
Nov 09, 2011 | Calvin Klein Ck Small Minimal Golf...
I need a new watch band for my Nixon Scout watch
Try contacting a Nixon service center.
You can locate your nearest service center by going to their web site "" and filling in your details.
Mar 02, 2010 | Watches
Lookn for the wristband for the venture
Follow this link: Scroll down and read HOW DO I GET NEW BAND. Rate me, please.
Feb 16, 2010 | Nixon Venture Dial / Stainless Steel Band...
Add link to the wrist band on my Nixon "The Player" watch?
you can find a exper in you real life or in the watch shop..
Dec 28, 2009 | Nixon Player NIX0003 Wrist Watch
Versace watch ( wristband)
Same place where you bought the watch, mate, same place where you bought the watch. Surely the watch is a Versage but the wrist band can be any band you can find at any good watchmaker of jeweller. ;)
Sep 23, 2009 | Versace 27473-008-00 Wrist Watch
Hi Terena,
You're not a numpty! :O
Just go here:
MouseOver 'Support' and click 'User Manual', choose your model and follow the instructions to set your watch.
Hope this helps!
Chris (ziraffa)
Dec 26, 2008 | Nixon Key Men's Watch - Gunmetal Dial -...
Relic Watch Band Removal
If there are holes where the band connects to the watch and you are unable to push the spring bar out. There may be a bar connecting the band to the watch. Those are harder to push out.You might have to use a tool & hammer it with a gavel. Hope this helps
Mar 04, 2008 | Watches
Nixon Watch band
I tried the hammer plyer thing way back but took a bunch of time and stress, then I took it into a skate shop where they sold nixon watches and they had an actual tool supplied by nixon and all the **** needed to do the job.
Jul 01, 2007 | Nixon El Dorado NIX0010 Wrist Watch
Nixon Manual NIX0031 Wrist Watch Logo
26,196 people viewed this question
Top Nixon Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Nixon Watch Expert? Answer questions, earn points and help others
