Question about Sony PlayStation 2 (PS2) Console
Video problem Hey i made a mistake. I changed the video settings from component to RGB and now the screen is black. I still have sound. Is there any way i can fix this?
    Scholar:
  • 97 Answers
1) start up your ps2 with no game in the tray
2) press Down once, then X to enter the system config
3) press Down three more times, then X again
4) press Left once, then X again
Source: http://www.opentechsupport.net/forum/showthread.php?t=38330
Posted on Jan 05, 2009
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
By mistake, I selected RGB connection while setting up in sony DVD NS730P. Now the screen goes blank means output switched from DVD component connection to RGB port. How to return back to DVD componeent...
Please press the DISPLAY when the player is in stop mode.
The Control Menu appears.
Press the up/down arrow to select SETUP, then press ENTER.
Press the up/down arrow to select the RESET and then select Yes from following message.
Press ENTER.
It will reset the player.
Jan 13, 2011 | Sony DVP-NS730P DVD Player
PS3 no picture problem..
Try using RGB cables and unplug the HDMI cable from the PS3, then while the PS3 is off, hold down the power button/sensor on the PS3 untill you hear a beep or a few beeps. This will force the PS3 to automatically detect the TV/cable resolution settings. Hope this works.
Aug 25, 2009 | Sony PlayStation® 3 (80GB) Console
No video output caused by OSD change
Leave cables conected to tv as they are but connect L73 to TV with a scart lead, then switch TV av to the one used by the scart lead and hey presto you'll be able to change back to the progressive setting ( component cables ).
Once this is done just remve the scart leads and bobs ur uncle your back in business.
Hope this helps. Earl
Apr 05, 2009 | NAD L73 DVD Player
Another question about maxent plasma monitor
Yes problem is repairable sounds like the mainboard (video) needs replacement because the rgb is part of this board along with the rest of your inputs this should fix your problem. There are some models where rgb is seperate but not many I will need the model number of your Maxent to be of further help.
Sep 09, 2008 | Televison & Video
My Hyundai DVD player plays DVD's in Black and White or in a greenish tinit. Freeview, videos all okay. Any ideas?
On the DVD Player, there maybe somewhere where you can change the output to the television (Scart) from RGB to Component or Composite-mode.
RGB causes some displays which cannot handle the RGB signals to black and white.
I hope this fixes your problem.
Finally, some TVs designed for PAL cannot handle NTSC discs played through them. It causes the display to also go Black and White. If this is the case there is nothing you can do except change the display/TV.
Don forget to rate.
Mar 17, 2008 | Hyundai ImageQuest DVD 320 A DVD Player
PS2 RGB SETTING
You need to get either an a/v or s-video cable and plug that into your tv and ps2 and start it up. you should be able to see the menu then and switch it back.
Dec 26, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
111 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
