Question about Comfort Zone CZQTV1 Electric Heater
Comfort zone thermostat control knob - Comfort Zone CZQTV1 Electric Heater
2 Suggested Answers
SOURCE: how do you turn on
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
Posted on Jan 14, 2011
I have a comfort zone infared heater the buttons will not work can power it on and off can control speed but nothing else
The thermostat may be fried inside. Try having it replaced at a Electronics store like Radio Shack or a YouTube tutorial video may provide you with the process of replacing the thermostat. The part should be fairly cheap.
Apr 27, 2016 | Comfort Zone Heating & Cooling
I have a Carrier Comfort Zone II with 2 controlled zones. The floor with just the sensor controls perfectly. I set that zone at 75 and it stays at 75. The other zone has the actual thermostat. If I se
Sounds to me like a bad damper or a bad zone panel. Turn tstat off and call for cooling on zone 2. Then see if your still getting cool air to zone 1.( where the main tstat is)
Jul 15, 2017 | Heating & Cooling
Why does a CCC2 thermostat continually kick on and off even though the set temperature has been reached?
Double check your batteries in both the outside and inside units changing the outside ones FIRST before you change to reset the inside batteries, IF you have two separate units. If this doesn't help, it could be the control switch/relay for your interior unit. Please go to your browsers information line and type in DOMETIC CORPORATION.COM AND SEARCH FOR YOUR SPECIFIC THERMOSTAT by entering your CCC2 Comfort Control Center 2 information. They should have a help section at this website.
I hope this helps. Check to see if its still under warranty.
Jul 07, 2014 | DOMETIC CORPORATION Dometic CCC2 Comfort...
I turn the heater....it displays A04..and then it shuts off.
Comfort Zone heaters do not have a display board, they only had thermostat knobs.
Is it possible that you have a different model of heater?
Dec 23, 2010 | Comfort Zone Pool & Spa
We recently had Marley Double line break interrupter Thermostats installed as we could not turn our old thermostats "off". The lowest setting was 5'F. The heaters are in our cottage and when we...
Hi zone controlled thermostats are controlled normally by a master control stat that is wired ( linked ) to each zone. If you had them installed, they should have left you with the sequence of operation to explain to you how these stats work, and what to check in case of light trouble shooting? This I would insist on getting from them.Yes, I am sure they will click as each one is energized, but like I have said on all commercial heating and cooling thermostats that are zone controlled, even on a residential application, they came with a master control that sensed the temperature in that area where the zone covered, and the master received a signal to shut off the zone and automatically checked the other zones to see if they were calling for heat or cooling and would control the zone as needed. It doesn't make sense to me to have lets say 6 zones you are covering in the area of your cottage all alone like a thermostat.The click would be that it is either turning on the heat, or turning it off. This would be OK I assume, if they are controlling the heat and shutting the heaters off when you want them off, to save on your heating bill, but a programmable thermostat would do the exact same thing as the zone controllers, as these are used in office buildings, and for controlling hot water valves and dampers in the ceiling, as they have zone sensors located around the building to sense the temperature and send it back to a main controller. The zones are called slaves to this controller.I have never heard of this brand, most controllers for zone control are Johnston, Honeywell, Barber Coleman. I'm sure they are good, but I will need to find the sequence of operation, which I will get right on now. Hopefully, I can find out. If not, go back to the installer to get the paper work he should have left you explaining all to you and showing you the schematic on how they are arranged and operated either alone, or together. It just sounds to me like they are a digital sensor that senses the temperature, and maybe preset, or is adjustable inside for a certain comfort temperature, just like a programmable thermostat would do in this case. Please do what you can, and rate me on this, as I know you will be kind, but without a main control, I sincerely believe you are back where you started.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Industrial, Commercial, & Residential Contractor
Oct 28, 2010 | Heating & Cooling
How do you turn on a comfort zone cz7007? has a knob that turns up to 7 and 2 red switches right next to each other.
Sep 24, 2010 | Comfort Zone CZ7007 Oil Filled Electric...
The Carrier comfort zone thermostst displays the
Go to panal and reset control. Small reset button on control board. Let me know if it clears.James
Oct 12, 2009 | Carrier 38CKC042 Air Conditioner
Carrier Comfort Zone II Smart Control in one zone frequently cycles unit (every 20-30 minutes) even when temperature in the room does not change significantly and the indicated thermostat temperature does...
sounds like your zone control tstat needs calabrated or maybe replaced,in owners manual there should be a section on calibration if not you may have to replace it
Sep 09, 2009 | Heating & Cooling
Comfort Zone CZQTV1 Electric Heater Logo
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
