Question about Dymo LabelWriter 400 Turbo Thermal Printer
How to get ip address on a Dymo Label Printer?
  • 14 Answers
SOURCE: DYMO DUO LABELWRITER
The labels have a 2 yr warranty, so contact Dymo customer support and if they can't help you return the printer to the retailer you purchased from for a new printer. The Dymo LabelWriter DUO is an expensive printer that Dymo stands behind.
Posted on Mar 24, 2008
  • 7 Answers
SOURCE: We just purchased a DYMO
Your dymo labelwriter came with an add-in for word. just highlight the addresses you want to print, click the little label printer icon in the toolbar and it'll do the rest
Posted on Dec 31, 2008
  • 7 Answers
SOURCE: dymo label 400 turbo.
It doesn't use ink so that's not the problem. more than likely it's one of 2 things. 1. you created a custom label layout and the text is just over the edge of it's printable area. Therefore, only hal of it prints. #2 Your using the wrong size label template on the software. make sure that the size you have loaded in your label printer matches the template shown size for size, inch for inch. The printer doesn't know (or care) what label you have showing on your software. It only knows what's loaded in your printer. So for example, if you have a shipping label on the software and put text to the bottom og it, it won;t print if you have an address label laoded in the printer.
SOURCE: dymo label point 200
Dymo website, Support Tab:
http://global.dymo.com/enUS/TechSupport/default.html
Drop down box and select your product.
Print out you instruction manual.
Posted on May 11, 2009
cns assoc
  • 677 Answers
SOURCE: NEED INSTRUCTIONS ON HOW TO OPERATE DYMO LABEL
Found on WEB
http://static.fixya.com/Manuals/D/Dymo/LtrTg_QX50_T_F0D7A12F6AFDB0376043F6C9CD5E15F9.pdf
Posted on Nov 12, 2009
How do i transport the address book from old computer windows xp to new computer vista
The easiest way would be to identify the location and the file your Dymo printer uses to store its address. Copy the File to a USB memory stick, copy the File on the USB stick to your your new computer, and when you start up your Dymo printing utility open the copied file as your default address library.
The problem you may run into can be caused by different versions of the Dymo printing utility. You may be forced (using the Dymo printing utility) to export the address book on the XP computer and then import the address book on the Vista computer. The picture below outlines this procedure using Dymo printing utility v.8
Also, if you have created any custom label designs you will want to transfer them as well
Jan 17, 2014 | Dymo LabelWriter 310 Printer
How do I import addresses from excel to my Dymo LabelWriter 4XL Thermal Label Printer?
You first need to install DYMO Label. If you already have installed it, click Address Book > Import to import addresses.
^CM
Sep 05, 2013 | Zebra TLP 2844-Z Thermal Label Printer
Paper "30252 address" is not supported
Here is the fix for Win7 provided by Dymo tech support:
1. goto Devices and Printers
2. select Dymo Label Writer
3. On the top where you see Print Server Properties, open it and find "30252 address"
4. delete "30252"
5. delete Dymo Label Writer printer
6. disconnect USB cable and then power to Dymo printer
7. connect power and then USB cable back to Dymo printer
8. reboot PC
9. try printing label again.
Jan 31, 2013 | Dymo LabelWriter Thermal Printer
Windows vista and dymo labelwriter 450
Here is how to upgrade the software:
1. disconnect the printer and make sure you log in as an administrator. If you need to, back up your contacts: Address Book > Export;
2. uninstall everything that says DYMO (Start > Control Panel > Uninstall) and re-start the computer (back up whatever should be saved);
3. install the latest Windows updates;
4. install DYMO Label 8.5.0: see the download link below(I suggest right-clicking the downloaded file and running it as administrator);
5. connect the printer directly to the computer only when prompted;
7. only use DYMO-made rolls - black stripes on the back, the logo and article number should be there.
tinyurl.com/dymolabel850pc
Also, please go to Start > Devices and printers > right-click the printer > Printer properties > Ports > clear Enable bidirectional support > OK.
^CM
Jan 07, 2013 | Dymo ® LabelWriter® 450 Series PC...
This is the error message when openning the Dymo Software on Server 2008. We have openned this same softare successfully on other 2008 Severs. Exception EPrinter in module Labels.DLL at 0000643E6
http://global.dymo.com/enGB/Troubleshooting/LabelWriter_320.html
From this site.
    • The error message: "Exception Eprinter in module LABELS.DLL at ...." is displayed.
      or
      The error message: "Access violation at address ... in module DYMOLBL.EXE" is displayedA. This problem can occur when DLS 7.x was installed over DLS 6.x, without first uninstalling DLS 6.x.
      Solution:
      Delete the file Dymolbl.ENG.
      DLS will still work, however, all default settings will be incorrect.
      The settings will need to be set correctly.
      On the DLS menubar, click Preferences and set the preferences as desired.
      The default values are:
      Default label file folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Label Files"
      Default address book folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Address Books"
      Default clipart folder should be set to "C:\Documents and Settings\All Users\Shared Documents\DYMO Label\Clipart"
      B. An incorrect printer has been selected in the DYMO software.
      Solution:
      1. Start the DYMO Software.
      2. Click on File and point to Change printer.
      3. Click the LabelWriter model connected to the PC (e.g. Dymo Turbo)
      C. Occasionally, double-clicking the print command button in the list manager is not handled properly by the software.
      Solution:
      Single-click the print command button.
      D. An incorrect driver has been installed.
      Solution:
      Run the DYMO Driver Uninstaller
      Restart the PC and install the correct driver.
      To remove and reinstall the printer driver:
      1. On the Windows taskbar, click Start, point to Settings and click Printers (& Faxes).
      The printers window is displayed.
      2. Double-click the LabelWriter icon and delete any documents waiting to be printed.
      3. Close all programs.
      4. On the Windows taskbar, right-click on Start and click Explore.
      Windows Explorer is started.
      5. Double-click the file C:/Program Files/DYMO Label/Support Files/LW Remove.exe
      6. Unplug the LabelWriter's USB connection from the back of pc and click OK.
      7. Choose Select all and then remove.
      Once the driver has disappeared from the printers dialog box, click Close.
      Restart the PC.
      8. When Windows has restarted, on the Windows taskbar, click Start, point to Programs, point to DYMO Label and click Uninstall DYMO Label.
      9. Reconnect the LabelWriter to the computer and reinstall both driver and software.
Jun 16, 2009 | Dymo LabelWriter 400 Turbo Thermal Printer
We just purchased a DYMO 400 label printer and I am trying to set it up so that we can print existing labels to it. We have hundreds of word documents formated to print labels on 8.5x11 label sheets. Each...
Dec 30, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo label 400 turbo.
THERE MUST BE PROBLEM IN THE INK OF THE PRINTER CHANGE THE INK N U WIL NOT FACE IT AGAIN
May 24, 2008 | Dymo LabelWriter 400 Thermal Printer
Feb 16, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Dymo LabelWriter 400 Turbo Thermal Printer Logo
292 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
