I have a HP dv6500 laptop and when i turm it on it shuts off and turns back on every 3 seconds.Just before that happend my DVD/CD rom wouldnt read a week earlier. I can keep it on when I push my B button but nothing comes up. Any ideas?
  • 7,627 Answers
Is the fan dirty/dusty is there sufficent air flow? Try a Cold-Restart, unplug AC cord, remove battery, hold down on/off button for 10 seconda, replace battery, plug into AC outlet, start normally. if that fails Try a system restore/recovery. That's a start. It sounds like a hardware issue, the shut off issue. The DVD/CD sounds like a driver issue. Thouroghly clean the fans, get more air flow, use a laptop cooler if necessary, Restore/recoery if necessary.
Posted on Nov 05, 2012
thinstatic
  • 50 Answers
SOURCE: hp pavillion dv1000 cd rom drive
memphisrains -
Sounds as though you may need to reinstall the driver for the laptop's cdrom drive. The easiest way I've found to do this is to download it directly from the manufacturer's web site; In your case, look here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-31831-1&lc=en&cc=us&dlc=en&product=435618&os=228&lang=en
Download the file to your desktop (file name is sp30367.exe), and run the installation to reinstall & update the DVD/CD-ROM drivers.
Hope this helps!
-thinstatic
Posted on Jun 12, 2008
graysand
  • 558 Answers
SOURCE: Power light shuts off after only 3 seconds
First remove power from the computer before attempting to remove any internal device.Remove the battery the memory and the power supply.Press the power button and hold for twenty seconds.Once done replace the removed items and try again.If no go try removing the memory only if your computer beeps then you have bad memory,try one stick at a time.Failing this *********** board is bad.
Good Luck
Posted on Sep 05, 2009
ginko
  • 19396 Answers
SOURCE: HP laptop dvd player can read DVD but not CD
The lens is causing the problem. Simplifying a bit, on a DVD unit, the same lens must "focus" on a laser beam reflected by the disk. CD and DVD reflect laser beams on different frequencies.
A scratched or dirty lens may be able to read DVD and not CDs.
Try first cleaning the lens with a CD cleaner product. you can also try cleaning the lens with isopropyl alcohol and cotton stub, be aware that there is risk to make situation worse using this technique. If you put too much force on lens , the optical drive may not work at all afterward.
If that does not work, rather than replacing the lens, on a laptop you replace the optical drive alltoghether.
Posted on Sep 16, 2009
  • 133 Answers
SOURCE: HP DV6500 Won't turn on.
motherboard is on the way out.. get anoher laptop as it is probably more cost effective than trying to have a new board fitted!
Posted on Jan 01, 2010
SOURCE: Hp laptop turns on for 3 seconds then shuts off
hi
you have problem with your bettery
try to remove bettery from your laptop then conect direct with charger then try to on
hope fully problem with bettery only
Posted on Jul 21, 2010
Hp dvd rw drive ds8a1h driver
Check device manger and see if it is listed, if not reboot and see if you can enter bios setup, see if it is listed. If it is not, replace the drive
May 24, 2013 | HEWLETT-PACKARD Hewlett Packard Techno...
Cd/dvd cannot read cd content in some cds
If your laptop is still on guarantee, return it ,but if its expired ,then replace DVD ROM.I once came across this problem ,but it was on emachines D620 ,replacing DVD ROM solved the problem.
Feb 06, 2013 | HEWLETT-PACKARD HP ProBook 4520s Notebook
My hp pavilion dv6500 won't boot up. When the power button is depressed, the power light, dvd light, and all other lights near the keyboard come on for a split second, then shut back off The screen never...
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
Sep 19, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
Remove the optical drive on dv6500
There is probably a screw or two on the bottom side of the laptop that you need to remove.
Hope this helps.
Have a good day and good luck.
Nov 20, 2009 | HP Pavilion DV6500Z Notebook
Cd drive hp pavilion dv6500
1/ look on bios, first harddrive second optical device should be there. 2/ clean it by cleaner 3/ if not work change it.
Nov 04, 2009 | E-Machines emachines (emachinees) CD-ROM...
Hp CD\DVD rom not reading CDs, but is reading DVDs?
cd/dvd rom is probably not working ,try using a lense cleaner disc if that doesn't work it's cheap enough to just install a new drive DVD/Rw as they are about £20.00 new.
Jul 30, 2009 | HP Computers & Internet
CD-ROM cANT BE READ
Hi
sometimes DVD/CD drive become dirty of dust falling into leses.
Try This first !
Prepare 1 Cotton buds (clean one)
1 ply of tissue
1)Dip i side of it to Pure SWAN ALCOHOL or cleaning pure alcohol
2)touch 3 second of cotton bud to tissue (this to ensure excessive alcohol absorbed to tissue)
3) eject your cdrom drive
4) use cotton bud, scroll /rub/ twist the bud onto the shiny lens, be careful not over excessive force over the lenses.
5) rub again with dry bud.
TRY read your discs
Good luck
Please rate me if you happy with the results
Jan 05, 2009 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
