Question about ASUS A7N8X-E Deluxe : ATX Socket A FSB400 DDR400 AGP8x SATA/RAID Wi-Fi w/audio 2xGb-LAN USB IEEE1394 Motherboard
Will xw4300 accept compaq S6200cl hard drive - ASUS A7N8X-E Deluxe : ATX Socket A FSB400 DDR400 AGP8x SATA/RAID Wi-Fi w/audio 2xGb-LAN USB IEEE1394 Motherboard
  • ASUS Master
  • 5,660 Answers
HP XW4300 Workstation Desktop PC specs,
http://h18000.www1.hp.com/products/quickspecs/12260_na/12260_na.HTML
Scroll down to you come to the bold heading -
Standard Features - Specs
Go down the chart on the left side until you come to -
Interfaces Supported
1 SATA 3Gb/s interface (4 Serial-ATA connectors), 1 EIDE interface for optical drives
One EIDE interface. That is the Blue 40-pin connector, on the right side of the Ram Memory slots. (39-pin actually)
(Right next to the Black Floppy Drive 34-pin connector, and above the 4 SATA connectors)
Compaq Presario S6200cl Desktop PC >Main Support page,
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=390423
Product Information > Product Specifications > Product Specifications,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00056951&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=390423
Scroll down to the bold heading -
Hard drive
120GB Ultra DMA
It is an EIDE harddrive.
http://en.wikipedia.org/wiki/Parallel_ATA
HP XW4300 Workstation motherboard example,
http://www.ebay.com/itm/HP-XW4200-XW620-DDR2-MOTHERBOARD-358701-001-SOCKET-775-/110904128317?pt=Motherboards&hash=item19d266b33d
The answer is Yes.
Connect just the EIDE harddrive from the Compaq.
Make sure the correct jumper pins on the back of the harddrive, have a jumper cap on them to set them to Single;
OR,
The IDE harddrive model you have may Not use a jumper cap on any jumper pins, for some models of harddrives, to set the harddrive as Single.
Look up the harddrive jumper settings on the internet.
Start with the model number on the label of the harddrive.
Example; WD2500JB
Western Digital 250GB harddrive that is IDE. (EIDE)
Western Digital jumper settings for IDE (EIDE) harddrives,
http://wdc.custhelp.com/app/answers/detail/a_id/463/c/123/session/L3RpbWUvMTM1MjE4NDY3Ni9zaWQvQnoxcVF6YWw%3D
You will need a SATA optical drive now.
BIOS Setup > Boot Options > Set the first boot device to CDROM.
Install Windows disk.
Use IDE harddrive, and IDE optical drive on the same flat ribbon IDE cable?
Can be done, but usually is a HEADACHE, and MAY not work.
BIOS looks to see what drives are connected. It looks for the drive with the Operating System on it. (Windows)
Now put a disk in the optical drive. Time has to be divided between the harddrive, and the optical drive.
IF it does work; when you are using the computer, and the optical drive you will know the real meaning of Slow.
Have a SATA optical drive?
Regards,
joecoolvette
Posted on Nov 06, 2012
How many disk came with compaq presario s6200CL
Windows XP comes on a single DVD ROM. It should have been supplied with your laptop. This disk should include all the drivers for your laptop.
Jan 24, 2013 | Compaq Presario S6200CL-B PC Desktop
I forget pass word
simple solution firstly run your system in safe mode by pressing F8 in system laoading then select administrator account then create new user account.
Mar 22, 2011 | HP Compaq Presario S6200CL (B000649LKU) PC...
I have a seagate barrracuda hard drive model ST3160023A which came out of a working bootable Compaq Presario 6000. I would like to use this hard drive in a newer workstation HP xw4300. I being told this...
i have not heard of anything like that. the only thing that would make a difference is the connection. yours is sata i believe. here is a link that tells everything about that drive.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=Ultra_ATA_160_GB&vgnextoid=cd5cb1774aafd010VgnVCM100000dd04090aRCRD#tTabContentSupport
i do believe you would have to wipe the drive and format it and treat it like a brand new drive when you install it.
Feb 06, 2011 | Seagate Internal Hard Drives: ST3160023A...
I am replacing one drive in my Raid setup it is Raid 1 I have an HP xw4300. How do I rebuild the raid
Raid is supposed to self replicate, and you can hot swap drives when one fails, and the information is moved to the new drive..
Nov 03, 2010 | HP xw4300 PC Desktop
Does this model have a SATA Cable coming from the power supply?
According to the manufacturer's web-site:
http://h10025.www1.hp.com/ewfrf/wc/product?product=390423
this computer dates from 2003.
So, you'll have to buy a Molex-to-SATA power-adapter,
and a EIDE-to-SATA data-adapter,
if you want to use a SATA device.
Jan 01, 2010 | HP Compaq Presario S6200CL (B000649LKU) PC...
What battery does it use s6200cl compaq presario
Most motherboards use a lithium CR2032, CR2025 or similar. This is about the size of a quarter and in a holder on the motherboard. Turn off the AC plug and then ground yourself so you do not zap the PC. You could do this on a kitchen counter and touch the faucet before the PC. Or use a grounding strap. Remove the battery and replace with new. The BIOS will have to get its wits about it again, so be prepared for a couple of boot cycles. Start conservative default settings before venturing to more adventurous settings. Note if you have a separate video card or not. If so, select the setting to use the card not motherboard on boot. This is the only show stopper for a setting. Once you have it up and going again, resist the temptation to close it up before one last boot cycle shere you write settings on a piece of paper and tape it to the inside panel of the PC. Good Luck!
Dec 28, 2009 | HP Compaq Presario S6200CL (B000649LKU) PC...
Can't load xp on hp xw4300. Has sata hdd & ide dvd drive. Xp can't detect hard drive and if press f6 it says there is no floppy drive
replace your cables and try again. if unsuccessful locate your hardrives manufacturer ie: maxtor software MAXBLAST , download the hardrive software utility and ``0 fill`` your hardrive to factory default.
Nov 05, 2009 | Cars & Trucks
On how to restore factory setting on my pc
They may have reinstalled the OS (XP or Vista I don't know which one you have). If you have the HP disk...you should be able to install the software again. If not go to there site and download the software. Here is the link: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=390423
May 15, 2009 | HP Compaq Presario S6200CL (B000649LKU) PC...
How to restore factory settings on my pc
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph08097&cc=us&lc=en&dlc=en&product=390423
This explains how to: if you are WINXP and you computer was built after spring 2003...if not go back one page and select a different OS.
May 13, 2009 | Computers & Internet
ASUS A7N8X-E Deluxe : ATX Socket A FSB400 DDR400 AGP8x SATA/RAID Wi-Fi w/audio 2xGb-LAN USB IEEE1394 Motherboard Logo
67 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
