Their is no pilot light. The system uses a glowbar
OPERATIONThe newer dryers use a silicone carbide ignitor for ignition. If the Fuse is ok
the gas assembly gets power from the control thermostat
. The flame sensor allows the ignitor to go cat go. The coils themselves
cannot open the gas because the ignitor is using a lot of power. When flame detect
gets warm enough then it shuts down the ignitor and power is redirected on the other side of the 3 prong coil. The ignitor is not finished. It now is hot enough to act as a path to the secondary coil which energizes and sends that raw gas to the
1800f screaming hot ignitor. Igniton occurs and keeps the ignitor hot. If ignition at this point were to fail the ignitor would cool down and shut off the power to the secondary coil. Clever ain't it? So what can go wrong? Worn out flame sensor takes longer to reset, ignitor open. Clogged vent
overheat fuse blown, bad thermostat, and faulty solenoids.If all is good it should continually shut on and off all during the cycle to regulate the heat
If you need further help, reach me via phone at
https://www.6ya.com/expert/dan_73bbd84fe1d95b61
