Question about Gaggia 90901 Platinum Swing Up Automatic with Milk Island Platinum Espresso Machine
Gaggia swing up oversaturating coffee pucks
After brewing a coffee the pod which is ejected from machine is a muddy mess...it should come out as a puck in solid form? Is there something wrong with brew group or is there an adjustment?
  • 3 Answers
SOURCE: Gaggia Titanium integrated grinder not spinning, not grinding.
your grinding chamber is blocked, the same happened to me, did it struggle to grind before? try taking the black shoot out the top with the 2 screws( were you would put pre ground coffee in) take the brew unit out(along with the waste water and bean tray), and reach up to where there is a little spring, the spring controls a little door, if you open the door manually and clean out the shoot to the grinder( make sure the machine is unplugged for this), i used the end of a tea spoon and a little hoover. it should work after this
Posted on May 16, 2009
EsWorld
  • 1618 Answers
SOURCE: Gaggia baby espresso machine-Steam button is stuck
The only thing that comes to mind is that the machine is in steam/hot water mode. Unless you replace the switch and turn off the steam light so that it sends the water to the correct location. Also you might want to remove the shower screen and make sure it is clean.
Posted on Nov 26, 2009
Testimonial: "Thank you very much for your quick response. I've ordered the steam switch. "
EsWorld
  • 1618 Answers
SOURCE: Gaggia Platinum Swing
Sometimes if you, turn the machine on without the unit in place it will reset itself, and if on the brew unit the arrow is pointing to the N, then you should be fine, however if the arrow is doing its thing and the gears do not line up then you might have to take it in to get it reprogrammed.
Posted on Feb 07, 2010
  • 109 Answers
SOURCE: My gaggia titanium says it's brew unit is blocked
Try cleaning and relubing the brew unit.
If that fails you require a new main board.
Posted on Feb 22, 2010
  • 1089 Answers
SOURCE: We have a Gaggia Syncrony Logic that is just over
Hi
Check the drain behind the brew unit. There is a pocket below the injector that can plug up and cause water to drain under the drip tray. Check this first. Stick you finger in the pocket and see if there is water in it. If there is, the drain below and to the right is plugged and just needs to be cleaned.
Posted on Dec 11, 2010
Testimonial: "Indeed, it appears the pocket below the injector was plugged. Was able to clear it and it now drains properly. thank you!"
Why are my coffee pucks (dregs) coming out unformed and very wet
Bad grind, worn burrs in grinder (so a mixture of coffee particle sizes); not enough ground coffee for the size of filter basket.
- Adjust grinder so your brew time is in the 20-25seconds window, then take it from there.
Jul 24, 2014 | Gaggia Titanium Espresso Machine
We have a Gaggia Syncrony Logic that is just over two years old. After each brew cycle, the puck is successfully ejected but water and some grounds flow out under the drip tray instead of into it....
Hi
Dec 09, 2010 | Gaggia Syncrony Logic 74884 Espresso...
I have a gaggia platiniun bean to cup. i am using ground coffee at the moment but it keeps coming up brewing failed Why?
The grind might be too fine, and so the machine extract the coffee, try making the grind a little coarser.
May 30, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
Gaggia Platinum Swing Brew group will not relocate into position. I have checked all the alignments of the movable parts, but just will not relocate into position. Seems to be a problem with the alignment...
Feb 07, 2010 | Gaggia Platinum Swing 2-Cup Coffee Maker
Gaggia syncrony logic not dispensing water. Just drops pods and red light comes on. have cleaned brew unit shower screen and dispenser tube. still have the problem
Lubricate the brew unit with a food safe grease this should help.
The brew unit becomes stiff and fail to load up fully this stops the water being dispensed
Jan 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Why are my ejected coffee pucks very wet? Seems
You need to be sure the removeable grinding surface is clean and not clogged. If it is not clean, water has problems passing through the screen and the water cannot escape, staying in the puck...
Apr 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Gaggia Classic Espresso Machine
Are you tamping the coffee at all?
The ground coffee needs to be compressed, using a tamper, to form a hard puck that the water will then get squeezed through.
This has already happened to the ese pods so needs to be replicated in the portafilter when you place freshly ground coffee into it.
The plastic tampers provided with your machine are not fit for purpose and a metal tamper is highly recommended. The base of the tamper should be 58mm
Mar 30, 2008 | Gaggia Classic Espresso Machine
Gaggia 90901 Platinum Swing Up Automatic with Milk Island Platinum Espresso Machine Logo
52 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
