Question about Panasonic KX-T7425 Corded Phone
Storing #s on my extension
I have tried the instructions in the manual (for my model and every other one listed in it) but nothing works. Does anyone know why?
0 characters
1 Points
Forward to mobile
your mobile is not an extension to a land line .call your local phone company and ask them about call forwarding . it usually costs you more money
Feb 22, 2016 | Panasonic KX-T7630 Corded Phone
My message light is lit up, but when I press the button, the phone calls an extension instead. how do I retrieve my message and stop the transfer to another extension ?
Read the instructions that came with the cordless phone system or google the model number for an instruction manual.
Normally these phones just call your landline number and you input your code and the # character.
Perhaps you've already coded in the extension number on an arcane menu with the phone.
In which case it's back to the instruction manual!
Jun 25, 2015 | Phones
Uniden instruction manual
Since you didn't give the model of your Uniden 5.8GHz system, please select it from the list beginning at to download a copy of the manual.
Jun 30, 2014 | Phones
How do i forward calls to an outside line on Nortel M7324
You can forward an extension that is not used at all, and has the lines assigned to ring that you want to forward to an outside number. In programming have the extensions set to forward on busy to the external number using 9+ the number desired. When you leave for the afternoon, take the handset off the phone, and replace it when you return. NOTE THIS EXTENSION MUST NOT BE USED BY ANYONE -- IF THIS EXTENSION IS BEING USED AND A LINE RINGS IN IT WILL BE FORWARDED OUT.
Mar 19, 2013 | NorStar M7324 Telephone
I have an Lucent Avaya phone system and I am trying to find out how to change the extension list. I am not sure which extension is the system admin as well. Any help?
Asked under Partner. The Admin phones for they SYSTEM is 10 and 11. The VM can be administered from anyone with a password.
Comment back with whatever you mean about "extension list".
Nov 09, 2009 | Lucent PARTNER18 Corded Phone
Change extension ID
extension id is changed in system programming
May 05, 2008 | NEC DTU 8D-2 Corded Phone
How do i set the time setting for panasonic kxt7456 black digital super hybrid system anyone has the manual? or set of instructions?
ok, the link isn't working properly, so I'll try to explain:
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Oct 08, 2007 | Panasonic KX-T7456 Corded Phone
Need help with re-setting time, date etc - haven't got a user guide or manual
If your telephone system is an NEC IPK, Pro II, or Elite, you should be able to go to extension 100 or 101 and dial Feature 9 and enter the new time. To switch between am and pm, press the Recall key after you enter the new time. If your extension numbers do not include 100 or 101, this should work from the 2 lowest extension numbers. The type telephone you have can be used on other NEC systems, and these instructions will only work on the ones I listed above.
Dec 01, 2006 | NEC Dterm DTP 32D-1 Corded Phone
Panasonic KX-T7425 Corded Phone Logo
Top Panasonic Phones Experts
Are you a Panasonic Phone Expert? Answer questions, earn points and help others
