Question about Maytag Washing Machines
Front loader door hinge broken
Open the and hinge broken. Apears to be some light aluminum hinge. It just crumble to pieces. Is there a replacement for it?
    Top Expert:
  • Maytag Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 06, 2012
barkencoa
  • 3463 Answers
SOURCE: hotpoint wm63 door locked
The door lock has failed in the locked mode, only way to open door is to force it open.
Remove top cover, screws at rear , slide cover back away from you.
Down at the front right side you will see the lock, it is reddish brown in colour, with 3 wires attached.
Force a long handled screwdriver or similar between lock and cabinet front, and force the lock, you may have to break it, but it does not matter as it is faulty anyway.. The door will then open.
Remove the 2 screws holding the rest of the lock , and pull up with wires still attached, .
Transfer wires to new lock on the same connectios, and refit.
Test it, if it still does not work then you may have to fit a new door latch and or spring.
Plz rate this solution and if you have any further probs, plz let me know.
Posted on Dec 25, 2008
jsrock516
  • 5911 Answers
SOURCE: how do you open a locked kenmore elite front
You can use the manual release to open the door. The following link explains:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Posted on Jul 18, 2009
barkencoa
  • 3463 Answers
SOURCE: Front Loader Washer Door Hinge broken
There are a couple of sites you can try.
WWW.ESPARES.CO.UK/BOSCH
WWW.4BOSCH.CO.UK/SPARES
Please rate my solution.
Thankyou
Posted on Feb 06, 2010
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: How do you repair a leak that appears to be coming from the lower hinge of the front loader door?
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn't cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
http://media.fotki.com/1_p,wbwdbgtqbsqkfbgxgtqsskgwtqkq,vi/kdtfgttdqxkfqrdrrdq/1/1303472/5961857/image45926img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 17, 2010
I have a Simpson Ezy Loader. I need to replace the door hinge which I have purchased but I am unable to get the broken door hinge out of the door as the door wont come apart.
may i ask why are you replacing the hinge? the door is in two halves and held together by a few large screws, once you remove the screws you will need to put a flat blade screw driver in between the two halves of the door and pry it open, theres a heap of tiny clips that hold the two pieces together, it will be quite hard and may make a loud crack when you pop it open, dont worry you wont break anything.
Feb 04, 2017 | Simpson Washing Machines
How do I get my kelvinator stove's P 12 front door back
Without more information I can't be sure of your problem but I will make a guess that you removed the door without engaging the hinge locks. I am attaching a video that may help. All oven door hinges are not the same. Some require you to insert a screwdriver or pin in a hole to stop the hinge from retracting. My own oven door has retainers that snap onto the slot just above the hinge. When you remove the door these pieces are used to hold the hinge in the open position.
If the hinges are in the closed position you will have to figure out how to open them and hold them in the open position. Be Careful. The springs are very strong and can hurt you. I am including a link to a youtube video that may be the same as your oven door.
This free troubleshooting video shows step-by-step instructions on replacing the oven door hinge on Frigidaire, Electrolux, Gibson, Kelvinator, Tappan, and Kenmore gas ranges.
Door Hinge Replacement part 316456302 Frigidaire Gas Range Repair
Aug 15, 2014 | Kitchen Ranges
My side by side refrigerator door swings open (somewhat out of control). It appears that the door stop is no longer working How can I fix this?
There is a self closer stop mechanism under the door between the door and the hinge, The door must be removed by removing the top hinge and lifting off the lower hinge flip the door and you will see a plastic piece which is probably broken there is also a piece on the hinge . Both should be replaced
Feb 27, 2011 | GE Refrigerators
Thankyou
Feb 06, 2010 | Bosch Washing Machines
I have front loader dryer and the door is popping
Buy door latch kit from parts supplier. Comes with male and female parts of latch. Replace female part first and see if problem correct. Replace male if necessary. Don't worry if parts break off and fall inside while removing old pieces.
Kit is very inexpensive. If after replacing both parts your door still pops open check to make sure door is not sprung. To do this place a known straight edge across center of door from left to right and be sure there are no gaps between door panel and straight edge. If no gaps, replace hinges. They are likely bent.
Sep 30, 2009 | Kenmore Dryers
Similar problem...repairman said the bearings were gone though
The repairman is correct. The drum support(aluminum alloy) has deteriorated and is crumbling to pieces.
Aug 21, 2009 | Kenmore 43142 Front Load Washer
Door hinge is broke on Bosch Axxis+ Front loader
There are 4 screws in the door that hold a plastic hinge cover on
.The door will then set into the hinge just fine (PLENTY OF ROOM) and then you put the hinge cover back on and screw the screws in to hold the door onto the hinge.You will likely need a 2nd set of hands to keep from breaking the door.
Oct 10, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Door hinges broken and door fell off
yeah very easy and it should only cost at most about £10 undue the old hinge with the 2screws now the door will have two little covers that held the old hinge in place take these out and make sure u get the broken pieces out of them once u have the new 1 put it on the washer and screw down first and then place the covers on the ends of the hinges and put the door in place now redue the screws on the door
Jun 01, 2008 | Candy CN146 Front Load Washer
Washing Machines Logo
89 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
