Question about Tech Solution TS-4500 Shredder
Power transformer broke
Class II transformer tdc power product Model No. DA-36-24. Input 120 VAC; Output 24 VAC. This transformer broke and won't stay in the wall. Can we get this transformer separately for the Tech Solutions Cross Cut shredder? Where can we order one from?
  • Anonymous Mar 07, 2009
    We have the same exact problem. The AC power prongs break from their mount internally and get pushed inside. JUNK!!!!!
  • 58 Answers
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
I have bose wave with input voltage 110 volts but i want to change it 220 volts where i can buy a transformer
Check the back or the bottom of the Wave unit for the input voltage rating. If it has a universal power supply, it will show something like "Input voltage 97-243 VAC 50-60 Hz," i. e., the input voltage rating spans the full range from 110 VAC US to 240VAC Europe. In that case, all you have to do is get a power cord suitable for the power in your area.
I checked the specification in the on-line owner's manual, but it wasn't helpful; it said the input power rating is "220V-240V
50/60Hz 60W max" We know it works on 120 V, so the 220V in manual may be a typographical error. Go with the information on the unit case. If it says "120 V 60Hz" and nothing about 240 V, then you would need a transformer rated for at least 70 Volt-Amps (60 Watts plus a reserve factor so you don't have to worry about overloading it).
I tried checking my favorite site for electronic products such as travel transformers and adapters (MCM Electronics), but as of this time they were having server problems. Note: they may have the 240 V version of the power cord, or you can check whether Bose sells it separately.
https://www.mcmelectronics.com/
Aug 05, 2017 | Bose Audio Players & Recorders
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
I need to replace the transformer inside my 12 volt charger. I can not find who makes the ES -66-287rev5 transformer. Need help.
If you have the skill to determine the transformer input is open, I would expect you have the skill to replace a transformer. Based on this assumption: determine the input voltage (120 vac?), determine the output voltage (14 vac?), determine the power requirements (output voltage times the charging current), find a transformer at www.digikey.com or www.mouser.com or www.newark.com.
Sep 15, 2014 | Drills
TDC low voltage transformer model DA 150 12 W reset button trips
There is a short circuit.
Copy following link to identify possible problem and download manual
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
May 02, 2012 | Hardware & Accessories
I have a customer that recently replaced his generator, problem is , he got a 120 VAC output. He has 2 SW 4024 for 240 VAC output. Can I hookup the 120VAC to the master inverter, or should I get a...
I will accept the second option which is getting transformer.
Go ahead and get a transformer in order to step up the voltage. This is better than hooking up the 120V AC to the master inverter.
In summary, get a transformer to step up the voltage.
I hope this is clear now....
Good luck.
Apr 01, 2011 | Xantrex Technology Xantrex SW Series...
I have some outdoor landscape lights that were working fine until a few days ago. The 120 vac power goes into the first transformer, and then out, and into a second, then a third, then a fourth, and...
Hi, to isolate the faulty transformer, one need to obtain a Multimeter and set it to Volts AC, then going to the Output of each transformer & see if there is the required 12V there. The one that's NOT providing an output is the faulty one.
In these setups you are correct there is little else it can be. However check at the connections to the lights also, see if there is Voltage there too.
A transformer will have the 120 V AC on the Primary, INPUT side, and 12 V AC on the Secondary OUTPUT side.
Try testing right on the transformers terminals. Also remove the "Load" too when making measurements as if there is a short etc, then that may give a false reading. Always measure Voltages first with NO load, then test again with the Load, they should both be the same, if NOT then you have a fault NOT in the transformer but elsewhere in the circuit.
Sep 26, 2010 | Garden
Adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Oct 17, 2009 | Audio Players & Recorders
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
Using battery charger overseas
it's alway suggested that you simply use plug adaptors to change shape of plugs for overseas-do not reduce voltage since most all chargers including yours support 220 or 110
Jun 07, 2008 | Cameras
Tech Solution TS-4500 Shredder Logo
328 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
