Question about Kitchen Ranges
Oven stuck on automatic timing for teka oven how to disengage
Teka freezer
need model number but most Teka models have integrated controls and a compressor system that is shared between freezer and fridge. so it looks like you cant isolate one or the other.
if you provide your model number then it might be a special case. here is user information on one model Teka.
http://www.fridge-manual.com/teka/teka-tki2-325.html
Oct 02, 2013 | Jenn-Air Refrigerators
Teka tkx 13wd manual
I`M Korean, I need a 'TEKA tkx 13Wd manual. Please, so hard usually to TEKA washing machin...
My E-mail is
key00519@naver.com
Thank you.
Aug 11, 2013 | Washing Machines
Teka ha 830 oven timer will not reset after power cut
I have a Teka HA830 oven I held the buttons down but it never resets. Would like to know if its possible to change the computer board, and where can i purchase it online?..
Jan 29, 2013 | Ovens
Instruction manual needed for teka oven profesional 518
http://uk.search.yahoo.com/r/_ylt=A7x9QV_W9RdP1TwAyj5LBQx.;_ylu=X3oDMTBybWpoN25zBHNlYwNzcgRwb3MDMgRjb2xvA2lyZAR2dGlkAw--/SIG=12dh9vsl5/EXP=1326999126/**http%3a//kitchen.manualsonline.com/manuals/device/oven.html
Jan 19, 2012 | Ovens
I have a Teka oven HI-595 that shows power, fan works and grill works but oven won't heat up. What should I do?
If the fan is working o/k, then it is probably the oven element that is faulty, usually located at the rear of the oven compartment behind a removeable cov er.
Oct 21, 2010 | Ovens
How to reset a dishwasher teka lp700
i have a problem with teka lp 700, dial gets stuck and water starts to spill out, also the motor after awhile ceases up.
Apr 19, 2010 | Dishwashers
Oven overheating ,even on very low degrees. Its a Teka
In most cases of ovens overheating, it is usually due to the oven thermostat being faulty.
The usual solution is to replace the thermostat.
Mar 10, 2010 | Ovens
Teka Model HC-595 - oven does not heat, fan working ok grill working ok
Sounds like the fan element has blown. I think access is from inside the oven at the back BUT the screws to undo the element are accessed by removing the rear cover. You will have to take the oven out of the cabinet to where is is fitted to do this and from memory there is an earth tag which is fixed to one of these screws
Oct 19, 2009 | Ovens
Kitchen Ranges Logo
82 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
