Question about Mitsubishi VS-60607 TV
Won't turn on, smelled smoke - Mitsubishi VS-60607 TV
  • 346 Answers
Unplug tv see. if there is any burnt part
Posted on Jan 05, 2009
2003 BMW 325 I won't start. Black smoke from exhaust and stalled
Hi. This is a common fault with m50/52/52tu engines. Engine is flooded because you did not warm it up. Must be out of blue on temp gauge be for you turn off.
Feb 11, 2013 | BMW X3 Series Cars & Trucks
Rear brake lights won't turn off
Check brake light switch (likely faulty). This issue may not be related to the engine issue.
If not the brake switch then check wiring for possible short circuit.
Nov 03, 2012 | 1999 Pontiac Sunfire
I have a 99 Saab 9-5 2.3L turbo. When I shifted it would blow white smoke for a second. Yesterday it started billowing smoke then died. Now it won't start and it turns over very rough. Please help.
Generally white smoke is a sign of coolant in the engine.
Its possible you have blown the head gasket and coolant is leaking into one or more of the cylinders.
You could pull the spark plugs and check for coolant - also run a compression test.
Sep 19, 2012 | Cars & Trucks
Won't pull in dirt
you need to change belt on brush and also check for locked up bearings on brush roller and or debris lodged between brush and guard dislodge if need be or replace bearings on brush roller if they are bad
Jul 24, 2012 | Dirt Devil 12 Amp HEPA Filter Vacuum...
There are few possibilities that can cause such problem.
I recommend you few help links related to your problem.Click the link below and follow the troubleshooting;-----Idles rough and quits when gas pedal is pressed less?
Brake pedal stuck?
Car only starts when gas pedal is pressed?
Car won't start without hitting the gas pedal?
emits whitish bluish smoke and bad fuel smell from exhaust
White smoke and Acrid Smell?
---------- Car stalls and throws white smoke from exhaust?
This will help.
Jul 20, 2012 | Cars & Trucks
42" MTD riding mower. Won't start. Had a tough
White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned.
Read more: Hope this helps
Sep 30, 2011 | Mtd Garden
Smoke coming through vents temp. gauge going up acting like its going 2 overheat turn heater on hot and smokes bad turn to cool and smokes a little my husband thinks it's the thermostat and wants to...
If the heater core is leaking, you would get a lot of steam that would smell "sweet". That would also leave you low on coolant, which could be a source of your overheating. If it's more of an electrical smell, you may have a blower motor or a blower motor resistor going bad, but won't cause the engine to overheat.
May 03, 2011 | Ford Ranger Cars & Trucks
Frigidaire window unit with heat and a/c smoke & burning smells
Hi, Anytime you turn a unit on like this and it smells and smokes, something is wrong. Did it smell as though it was electrical burning? Usually the blower motor is the first motor to go as they collect all of the return air and dust from the air and clog up the windings. They get hot and start to smoke, and you will know due to the smell of electrical wiring. I would turn it back on and see if it starts up and runs. If the motor hesitates in anyway, turn it off, or unplug it.If it is wired directly into a box, find out where the breaker is. If you are in fear of it catching on fire, call a air conditioning company out. I have seen them smoke like crazy but never had one catch on fire, never. I would turn it on, it will trip the breaker if the motor fails. Just watch it closely. If you can pull the front cover off and then turn it on, you may be able to see where the smoking is coming from, a motor ect.
Dec 30, 2009 | Heating & Cooling
Behringer europower pmh5000 turn it on big flash and smoke came out of vent no longer works did smell hot when it was last used
The output section has shorted output transistors. The increased load on the driver section probably smoked a few capacitors and resistors. Until the unit is repaired, you won;t get anything out of it. I would figure on $25-$50 in parts for the repair plus the local labor rate.
Oct 07, 2008 | Audio Players & Recorders
Mitsubishi VS-60607 TV Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
