Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
I have a kenmore bottom freezer model 59671812101 that keeps freezingup
abhishek33
  • 1239 Answers
SOURCE: Kenmore Bottom Freezer Refrigerator
hi In some cases, a faulty thermostat may not be the cause of a warm refrigerator or freezer. A warm box may also be caused by a defective fan, a blocked fan, or broken or bent fan blades. If the blades are jammed, try to free them. If they're bent, straighten them with pliers. If this doesn't solve the problem, call a professional service person.
On some refrigerators, the door switch operates the evaporator fan. If the fan seems to be malfunctioning, the door switch could be faulty. Test the switch as detailed in the last page, and replace it if necessary.
Posted on Nov 06, 2008
  • 363 Answers
SOURCE: my kenmore bottom freezer refrigerator keeps icing
Sounds like the circulating fan is wearing out, this problem is very hard to diagnose because the fan still spins but not fast enough to circulate the chilled air thru the freezer and refrigerator. The minimum cost for labor and material is around $300.00
Posted on Aug 02, 2009
Sea Breeze
  • 4654 Answers
SOURCE: kenmore model 596.72253201. Bottom freezer works, fridge does not
The most likely reason is part number 12566102 Adaptive Defrost control board. The next likely are the defrost heater and the defrost thermostat,Sea Breeze I will send you photos. below
Posted on Sep 11, 2009
arikrom
  • 528 Answers
SOURCE: Icemaker not working on a Kenmore Bottom Freezer
if the volve behind the fridg for the ice get 120v for short time when the ice maker ask for water then the volve is bad but if there is no 120v to the volve then the command not coming from the ice unit and it need to be change , the wholl ice maker unit :(
Posted on Jan 02, 2010
blueextc3221
  • 15935 Answers
SOURCE: Bottom freezer works but top refrigerator doesn't. Kenmore Elite.
It appears your damper or damper solenoid has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore bottom freezer will not defrost
I would check the Freezer Fan as the main point. This fan is very hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and frig. The minimum cost for labor and parts is around $300.00
Aug 02, 2009 | Refrigerators
My kenmore bottom freezer refrigerator keeps icing up how do i defrost it? model # 596.7182101
Aug 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
Error Code Er FF
Replace the defrost heater and defrost thermostat in the freezer.
Mar 23, 2009 | Kenmore Refrigerators
Freezer not defrosting
Hello pumpguy2
Welcome
You said, you have a Kenmore bottom Freezer Model 596.73503201. It works fine but the freezer has stopped defrosting. Any suggestions?
It is supposed to be auto or self defrosting.
What do you mean you are getting ice forming in the freezer?
Waiting for your response and more detailed explanation.
Huuum
Oct 01, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore bottom freezer keep freezing up.
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Aug 13, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore freeze on the bottom.. model 596-72219200
Aug 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Jul 08, 2008 | Kenmore 62832 / 62834 / 62839 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
62 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
