Question about Home
Need to replace air switch push button on my Acer Swirlbath tub . Where can parts be purchased.
3 Suggested Answers
  • 659 Answers
SOURCE: jacuzzi tub on/off bezel wont hold switch down
I couldn't find the information you are asking for in the installation manual. I have included a link to the pdf page so you can print it out and look at it in print. On this particular question, I think I would give Jacuzzi a call. They can better answer you question without guessing.
http://jacuzzi.com/pdf/K272000.PDF?SELINSTMANS=K272000.PDF&goinst.x=15&goinst.y=8
Posted on Mar 22, 2009
snowghost1
  • 784 Answers
SOURCE: The jets on my aker
could be a few things ---
1. it could be the on/off switch.
2. it could be a loose wire.
3. it could be a bad motor.
4. it could be a blown fuse or a bad breaker at the panel.
c...
Posted on Dec 31, 2010
I have a swirlbath whirlpool tub and the air hose fell off the push button switch on the side of the tub. The tub is 19 years old and the switch is against the wall side of the tub. How do I hook it u
Yo Dennis,
When I had to replace a switch on my unit I had the same problem. Jacuzzi uses double sided tape to hold the switches in place and they are a bear to get off. Try some dental floss or fishing line under the switch body to "saw" through the tape and lift the switch out. Maybe use a hair dryer first to try to soften the adhesive, but at 19 years it may be rock ??.
You may have to pry the switch out (!!) with a screwdriver (rag underneath) and the old plastic may grenade. A new one may be needed.
Be prepared for very little slack in the air line. I had a hard time reconnecting mine and ended up having to add a couple inches of tubing with adapters. No fun. The switches are mounted from below at the factory, so slack is not an issue.
All the best.
Dec 05, 2014 | Whirlpool Home
Can't turn on Whirlpool
Air Switch Repair
It sounds like you have a bad air switch located in your motor.
The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub.
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off.
Rod
US Parts Center
Bath Spa Replacement Parts Hot Tub Bath Parts Accessories US Parts...
May 09, 2014 | Maax Home
Find air switch for aker swirlbath
Air Switch Repair
This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off. You need part # TBS-310
US Parts Center
Feb 14, 2014 | Balboa HydroAir Magna Series Spa Eyeball...
Mirolin jaccuzzi tubs
Air Switch Repair
US Parts Center
Jan 28, 2014 | Home
My Aker Swirlbath pump hums but ther is no water action when I turn it on
Air Switch Repair
US Parts Center
Jan 11, 2014 | Home
Kohler led lighting and jacuzzi motor + jets stopped working but automatic line clearing air still blows when tub is emptied.
Air Switch Repair
US Parts Center
Oct 06, 2013 | Kohler Home
Jacuzzi Asteria will not turn off
How do you turn this on? If it is an air button that you push, it may well be the air switch in the motor is bad. The air switch is latching so when you push the button on the tub it closes the switch and lets the power go to the motor. When the button is pushed a 2nd time the switch will open and shut off the power going to the motor.
An air switch will cost about $21 to purchase.
Rod
US Parts Center
Aug 23, 2013 | Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner...
Hytec Kohler Model LM34520 air jet swtich not working. 4 years old and last use, the push button stopped working. Cannot see connection detail at switch/button end but disconnected at motor and and can...
The problem you are experiencing tells me that the air switch in the motor most likely the problem.
This is a latching air switch that operates when the button on the side of the tub is pushed.
The replacement TBS-339 air switch is around $21
Rod
US Parts Center
Jan 06, 2013 | Jacuzzi Home
Purchased new home with a swirl-way avalon jetted tub dont know how to start it please help
is there an air button on the top of the tub? if so that is what you would turn the pump on/off with. give it a push and see. if you do have a button to push like that then make sure the air tubing is hooked up to the bottom of the air button and the other end is hooked to the air switch in the back of the motor.
if there is NO air button to push and just the logo on the top of the tub then you will need to fill the tub with water, get into the tub and then touch the logo. that would turn an older Swirlway tub on/off.
Feb 06, 2011 | Home
Power switch for whirlpool tub
the easiest thing (maybe) is to install an air switch kit on the side of your tub. Here is a link to the part. Basically you install an air button on the side of the tub, install the air tubing from the nipple on the underside of the air button to the nipple on the box that plugs into an outlet under the tub. The pump plugs into that same box and the air tubing from the air button pushing onto the nipple on the box. When you push the button on the tub it will turn the pump on/off. Air Switch Kit
Jan 17, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Home Logo
189 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
