Question about HP Officejet 4315v All-In-One InkJet Printer
Printer will not print, it is stuck on FAX mode.
My printer will not print at all. It is stuck in the FAX mode and will not print anything from the computer. You can change the number of copies, but it will not do anything. We have only used the FAX part one or two times in the eight months that we have had it.
  • 300 Answers
Initially, I would suggest using the HP Printing Diagnostic Utility found here. Once you click that, you will see a Download Only button. If you need detailed installation instructions you will see a link below the Download Now that says View Directions which can be used to get step by step instructions for installation of the programs.
If that doesnt correct the issue, I would suggest removing and reinstalling the printer by following the directions below:
I would suggest that you disconnect the usb cable from the printer. Then, if the printer was previously installed, uninstall all programs related to the printer through Add/Remove Programs in the Control Panel.
After restarting the computer with the printer still disconnected you can follow the directions below to download the latest drivers.
To download the drivers you can go here. When the page opens you will need to choose your operating system. Then, from the Drivers section I would choose the full feature driver.
Once you click that, you will see a Install Now button that will allow you to immediately install the software and/or a Download Only button that will allow you to download the file for later installation.
Either option will have a link below them that says View Directions which can be used to get step by step instructions for installation of the drivers.
Hope this helps. Please rember to rate this information.
Thanks
Posted on Jan 08, 2009
I own officejet 4215v it is stuck in the fax mode and I can't get it to go to print.
Hello and Welcome to FixYa!
Sir this problem is due when by chance the Fax Mode is selected as default. To get to the print mode you need to change the mode to print. Try the following:
Click Start >> Print and Faxes (if you are using Win Xp) or Devices and Printers (if you are using Win 7) >> There will be the list of HP Office jet 4215 Fax and HP Office jet 4215 Printer. >> Right click on HP Office jet 4215 Printer ans Select as "Set as Default"
Now try to print again. If printer is still struck on the Fax Mode then possibility is that your printer is locked, In this case you need to Reset the printer: Follow the given steps to do this:-
  • Unplug the power supply from the rear of the product.
  • Unplug the power cord from the electrical outlet, power strip, or surge protector.
  • If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
  • Wait 15 seconds.
  • Reconnect the power cord to the power module.
  • Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
Now turn the printer On and now try to print again. I hope if first solution do not work then this will solve the problem. But if still it struck to Fax Mode then its may be a technical or hardware issue, You need to contact HP Support Center to solve your problem.
I hope this solution helps you and you have clear picture in your mind
Let me know if you have any confusion in your mind.
Sir, Your Rating as Five Stars for this solution and Words of appreciation as Feedback for me will be really esteemed
Thank You for taking my service
Concerned: Muhammad Uzair Team : FixYa
Nov 11, 2011 | HP Officejet 4215v All-in-One Printer
How to put printer in print mode
Actually, it does not matter what mode your printer is on when printing from your computer. Whenever your printer detects a print job sent to it, the printer will automatically acknowledge the signal and print the file - no matter if it's on Copy, Scan or Fax Mode.
Aug 26, 2011 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Printer does not print from computer. Is in fax mode and I cannot get it out of the fax mode Please help
When you go to print a document and your print window opens you need to change your printer name from Fax to the printer you want to print the document.
Mar 01, 2011 | Office Equipment & Supplies
Cannot get printer to print it is in fax mode
May be the default printer icon in printer and faxes (if the OS is XP) is the fax and not the printer...
Jan 23, 2010 | HP PSC 2410 All-In-One InkJet Printer
My HP 2610 defalt has changed to fax instead of print mode
follow this trouble shooting steps your issue should resolve.
On Computer:
Click on Start >> Control Panel >> Printer and Faxes >>
check which Icon is enabled if Fax is Enabled Just Disable it By right clicking on it and Disable.
Now Right Click on Printer Icon then select " Use Printer Online"
then set it as Default Printer.
Now try to print your issue should resolve..
I hope it helps ...raj 9866486995
Raj....
Feb 17, 2009 | HP Photosmart 2610 All-In-One InkJet...
Change from fax mode to printer mode
There is a scan mode, but not a print mode. If this is what you mean. You may have a stuck fax button or operation panel.
Feb 11, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Printing fax
take the paper tray out and shut the machine down also cancel out any printing in the cpu then reboot the printer good luck
Jan 01, 2009 | Brother MFC-5840CN All-In-One InkJet...
Says Printing & Online Stuck
when this happens, unplug machine, hold down the "stop/exit" key while plugging machine in. continue holding the stop/exit key for 5 seconds. display should return to the regular date and time screen. if it doesn't, contact brother customer support. this problem is caused by a fax stuck in memory.
hth,
razors
May 13, 2008 | Brother IntelliFAX 4100 Laser Fax
Fax report stuck in queue
try unpluging the power from the fax machine/
Jan 09, 2008 | HP Officejet 9110 All-In-One InkJet...
When I turn on the printer "Download Mode" appears on the lcd screen.
The machine might be trying to download the latest firmware wait a few minutes it may go if not it is it the user manual under on screen messages.
Thanks J
Sep 13, 2007 | Sharp AL-1661CS All-In-One Laser Printer
HP Officejet 4315v All-In-One InkJet Printer Logo
1,607 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
