I can not get logger to load on my vista windows del computer
  • 7,627 Answers
If your saying, You cannot log into your Vista OS, Try a "Cold-Start", Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and Start normally.
Posted on Nov 05, 2012
How do I get my k/bootstrap/logger.js to work so I can down load my pictures to my computer
.js file is a java script, make sure you have the latest java installed on your computer.
Also pay attention what version you have 32bit or 64bit and download accordingly.
May 16, 2014 | Microsoft Windows 7 Ultimate for PC
How do I check to see if there is a key logger on my computer?
The best way to find key loggers in the system is by simply running a scan by 'Windows Defender'. Simply type Windows Defender in start menu and run the scan. The scan will find suspicious softwares and key loggers.
You can also easily check for key loggers in your system by using these two ways:
1) By checking the Add/Remove Programs in Control Panel. For this, press 'Windows Key+R' > type 'control'. That will open control panel. Now go to Add/Remove Programs in Programs and Features.
Now, look for suspicious softwares or key loggers.
2) Open task manager by pressing 'CTRL+SHIFT+ESC' > Open 'Processes' tab. Search for programs that look suspicious. This method is needed in case of advanced key loggers like KGB, etc.
May 30, 2012 | Computers & Internet
Mycomputer says my bootmgr is missing and to press ctrl+alt+del to restart. When I do this it just restarts and come up with the same screen
Are you running Windows Vista. Do you have the original windows disk that came with your laptop.Insert the disk in the drive and reboot the computer.
  1. Boot from the Vista install disk
  2. Choose your language settings and click "Next"
  3. On the bottom of the screen click the link "Repair Your Computer"
  4. Select the Vista installation to repair and click "Next" and it will launch WinRE
    • The "Load Drivers" button will open a mini Windows Explorer, which can be used to search for drivers in case they are needed to access disk drives or other components. This mini Explorer is also very handy to perform file copy/move operations and change file-attributes.
The following options are available in WinRE:
Startup Repair - It will repair the boot manager files and restore critical files required for booting Windows Vista.
Jan 17, 2011 | Toshiba Computers & Internet
How to get to bios on windows xp and vista?
All you have to do is press the DEL or F2 key (depends on the motherboard) just at start up, before windows start up. Tip : shut down your computer and start it again. Press sometimes DEL key before the windows begin loading. During this you may have on your screen some logo (manufacturer) or black screen with white letters. If not success, try the same using F2.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer. Also post me your computer or motherboard manufacturer brand / model.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Sep 22, 2010 | Computers & Internet
Bootmgr is commpressed press ctr+alt+del to restart
Option #1:
Boot from your Windows Vista DVD and select Repair your Computer -> Startup Repair.
Option #2:
Boot from your Windows Vista DVD and select Repair your Computer -> Command Prompt, execute the following commands:
bootrec /fixboot
bootrec /fixmbr
Reboot.
Option #3:
At the prompt to select your OS installation, click the button that says ‘Load Drivers’. This should bring up a explorer-style drive browser.Then just right-click on the drive you tried to compress, and deselect ‘Compress this Drive’, which should still be ticked on. Hit apply, and apply to subfolders/files.
Reboot.
Option #4:
Boot from your Windows Vista DVD and select Repair your Computer -> Command Prompt, in the command prompt, execute the following commands by typing them and pressing enter for each line:
c:
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h
Reboot.(If the 2nd line fail, go back to 1st line and replace C with the drive letter of where your windows is installed.)
Apr 27, 2010 | Toshiba Satellite Pro L300 Notebook
My asus computer has just crashed, it wont open the vista it says windows could not start, a recent modification could be the cause of this problem, how do i get it started
press f8 key at early boot and choose "safe mode". if that boots, "last known good configuration" should get rid of bad added driver, if that won't work go to help and support in safe mode and pick an earlier restore point for when it did work.
Oct 14, 2009 | Microsoft Windows Vista Ultimate Edition
Installing XP on a vista pre-installed laptop
your harddisk is not detected in bios.reconnect your harddisk power cable and sata or ide cable again.then check in bios harddisk is detect or not.
u cna enter in bios with "del" key when u power up ther computer prerss "del" or F2 keyh to enter in bios.
Mar 25, 2009 | Acer Aspire 3680 Laptop
Os will not load, screen stays black but mouse pointer is visable
Hi nico,I'm assumming you are running vista since this seems to be a fairly common problem.  The problem is that a driver is not loading correctly.  You should be able to restart your computer and boot into safe mode.  Once in safe mode, delete and/or uninstall any files or programs/drivers you downloaded before the problem began.  Some users have blamed Roxio and MagicDisk as programs that have caused this error.  Then restart your computer back in normal mode.If you can not boot into safe mode, then unfortunately you need to begin looking at system repair options like reinstalling windows vista.
Hope this helps, and please don't forget to vote/rate!
Mar 12, 2009 | HP Compaq Presario c713nr 1.46GHz Intel...
New Motherboard Problem Pleasee help
Great info furnished, were you doing a VISTA UPGRADE or a separate full install to have a dual boot system.
For now-to get up and running reinstall XP via the CD
Jun 21, 2008 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
