Question about Ricoh Aficio Mp161 Copier Photocopier Copy Machine System Mp 161 Ricoh
Error code sc559
Sc551
WHAT IS THE CODE SC551?
Symptom]
SC551 (thermistor disconnect: thermistor2) or SC561 (thermistor disconnect: thermistor3) is displayed.
[Cause]
The drawer connector surface is partially corroded.
A foreign object or debris has adhered to the surface of the fusing unit drawer connector contact and, when the adhered moisture melts due to condensation, it causes part of the surface of the drawer connector to corrode. It becomes clear that SC551/SC561 occur because of faulty contact with the image fusing unit.
[Resolution]
Replace the drawer connector on the device.
Apr 25, 2016 | Office Equipment & Supplies
SC551 error on Infotec IS2220D same as aficio 2020D
it must be a small damage in capacitors in power supply
Mar 25, 2008 | Ricoh Aficio 2020D Copier
How can I correct error SC559?
Fusing Unit Third Jam Error (Fatal Error)
The exit sensor failed to detect the leading edge of the paper within the prescribed time and triggered a jam alert.
  • ? Afterthiserrorhasoccurredthreetimes,themachinewill shut down automatically and cannot be re-started until the machine has been serviced by a service technician.
  • ? Checkthepapertransportpathforanyphysicalobstructions (paper scraps, etc.)
  • ? Makesurethefusingunithasbeeninstalledcorrectly
  • ? Afterservicingthemachinetosolvetheproblem,theservice technician must execute a "Fuser SC Reset". Otherwise, the
    machine will continue to issue this SC code and cannot be operated. ( "Executing Fuser SC Reset")
Feb 19, 2016 | Ricoh Aficio SP 100SF e Laser...
Error sc551. Replaced the fuser, but still have the error. Need to know how to clear the error code. I have found reset methods for other models online, but they do not apply to the CL7200.
try this press clear mode button then press 107 then hold stop button for 5 seconds. should go into service mode. select 5 mode then 810 follow instruction and then turn copier off then back on .
May 07, 2015 | Ricoh Aficio CL7200 Laser Printer
Ricoh mp 2550 sc997
Sc551 high temperature error you need to replace both thermistors also check if fuser roller surface worn out then replace that too then just reset your error some cases you just need to clean thermistors and reset error
Nov 06, 2012 | Office Equipment & Supplies
Ricoh aficio 2060sp printer, is giving me error code sc551 what is that?
That error code generally indicates that there is an issue with the fuser unit, usually directly associated with the thermistor. Turn off the machine and wait 30 seconds, if it appears again, your only real option is to call Ricoh, or an authorized service company.
Sorry for the bad news, good luck!
May 05, 2011 | Office Equipment & Supplies
Sc551 error in Ricoh aficio 1013
SC551 - Standby overheat
Symptom: Temperature during standby or
low-power mode remained too
high for a specified interval (10
seconds or 25 seconds,
depending on the mode).
Possible Cause: TRIAC short
Mar 09, 2011 | Ricoh Aficio 2016 All-In-One Laser Printer
Service code 551
SC551 is an error with the fuser unit. The thermistor could be bad and need to be replaced or the press rollers are worn.
It should be looked at by an experienced technician to get problem repaired.
Jun 12, 2008 | Ricoh 6513 Copier
Ricoh Aficio Mp161 Copier Photocopier Copy Machine System Mp 161 Ricoh Logo
53 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
