Question about ATI Mobility RADEON Graphic Card
Graphic card on sony pcg-gr15
This notebook feel to have a defective graphic card: image on internal lcd screen appears shadowed, but on external screen is good. I think is a fault of a grapic card, or not? I don't know wich card is mounted (i see only a chip: is "ATI mobility radeon" and some labels "K6210090" and "VIF-17 KS-112" SONY). Someone can give me info to find a fault and where to find (if there is a case) a replacement card?
  • giampietro gigoli May 22, 2007
    Oh, thanks, i see now i mistaken to write notebook code: this is PCG-GR315 Sony notebook (PIII) and i know it has a ATI RADEON card mounted in (i dismounted it).
    President:
  • 2,961 Answers
There is no replacement for this as the graphics controller is onboard, as in built into the motherboard and not a seperate dedicated graphics card. You can try updating the driver but i would firstly go to my computer>right click>properties>hardware tab>device manager>click '+' sign on display adapters, select the adapter and right click and select uninstall. Restart pc and the graphics driver will be reinstalled. If no change, then it could be that the lcd or the back lighting is faulty and requires a qualified repairer.
Posted on May 21, 2007
SONY VAIO PCG-61813M
I have the same problem, It works at an external display and the lcd and lcd cable work on another laptop.
The problem is that i have a sony vaio and it has no inverter, or at least i dont see one like an hp laptop for example. i tried to switch image from external monitor to lcd and it doesnt work. i tried everything. dont know what to do more, Hope you can help.
I have a Sony Vaio pcg-61813M.
Thanks.
Aug 29, 2012 | Sony VAIO Laptop Intel Core i3 Processor...
My laptop ( sony viao laptop) fell and now once turned on I have a black screen all lights and sounds are good. Could this be a led disconnect problem or a video card situation. What type of video card...
Unlikely to be a vga cable loose, but you can check by removing the switch panel cover and the screen to check it is still firmly housed.
test the laptop first in an external monitor, if you get an image, then the graphics chip is still ok
This then points to the screen, may appear undamaged, closer inspection with a torch, shone through the back of it will show any cracks you do not see straight away.
If the screen will not light up, fault is probably with a damaged backlight or inverter, you are then looking at a new (or 2nd hand) screen
Dec 30, 2010 | Sony VAIO PCG-K35 Notebook
I have a Sony VAIO PCG-K25 Notebook Problem. When I Push the Power on Button, A flickering white screen comes up. The system goes throught boot up just fine but the LCD screen remains white. When hooked...
Hello
These symptoms are not the inverter problem, What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following: 1. Loose connection between the video cable and the LCD screen. 2. Defective LCD screen. 3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Check these by yourself or get assistance from sony support.
Good Luck
Dec 22, 2010 | Sony VAIO PCG-K25 Notebook
Coloured squares appear on screen
Seems to me that the LCD cables are not properly atached.
Double check all the LCD connections.
Your problem will be solved.
Jul 05, 2010 | Sony VAIO VGN-NR220E/S Notebook PC
My sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 24, 2009 | Sony VAIO PCG-K23 Notebook
Sony vaio PCG-GRT30P Screen Problem
You could have a defective screen, either a faulty inverter or a CCFL lamp - follow this to determine the fault.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 15, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Dark screen
you may need either a new lcd, or a motherboard, or both..lcd is usually the first issue to resolve..does it work , by chance with an external monitor?
check your computer warranty here 4 FREE
Feb 29, 2008 | Sony VAIO PCG-K23 Notebook
Images Display 4 Times on Screen - replaced LCD, inverter, & video cable...
can you plug your computer to a regular monitor there is a video conector in the back of your computer so if the video is ok on the external monitor that means LCD inverter may not be the right one that you just did the replacement
Dec 27, 2007 | Sony VAIO PCG-K25 Notebook
Sony Viao Display Problem
Sounds like you have some internal issues going on with this Laptop! If you are getting the same response when you connect an external monitor, then you more than likely have a few things going on here: A bad VGA port for starters, Issues with the Data card, and your graphic card is cetainly not helping. In addition you may want to check appropriate drivers as they are sometimes updated! But my best guess is that you are having issues internally! That could be costly! Sorry!
Nov 26, 2007 | Sony PCG-FR130 Notebook
SONY PCG-GR315 graphic card
If it appears fine on an external monitor, it seems to me that the problem is most likely in the laptop's LCD panel rather than the video card. I did a google search and turned up exactly zero results regarding the SONY PCG-GR315 Are you sure you got that model number right? In any case, chances are your laptop's video device is not upgradeable. My advice is to go to a repair center or what-have-you and find out if it's the card or the panel; panels can be replaced more often than other integrated hardware.
May 22, 2007 | ATI Mobility RADEON Graphic Card
Computers & Internet Logo
119 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
