Question about HP ProBook 4530s Notebook
My Laptop is shuttin down
Dear sirs, my problem is my laptop is shutting down the power after 30 minutes what I shall do Thanks.
  • 1 more comment
  • Ken Peebles
    Ken Peebles Nov 05, 2012
    Does the Blue screen appear before it shuts down?  If so, what info does it give?  What programs are you running, games/internet surfing, when it shuts down?  How long has it been since you have cleaned it(compressed air)?  Are you blocking the air vents, either on the back, sides or bottom of the computer?
  • Alikayse Omer
    Alikayse Omer Nov 05, 2012
    No Blue screen appear before it shuts down normally it shuts down after 30 minutes. I do all these with compressed Air
  • Ken Peebles
    Do you mean that it is going through the normal windows shut down procedure?
  • HP Master
  • 7,627 Answers
Clean fans of dirt,dust, any thing that is obstucting air flow. Are you using the laptop on a soft surface? Try a laptop cooler, it sounds like the components, CPU,Graphic card, PSU are getting to a temp that causes the laptop to auto shut down as not to damage the components
Posted on Nov 05, 2012
Benimur
  • 6966 Answers
SOURCE: Laptop shuts down often when using battery power
Often, this would be a battery problem given the age of the laptop. A way to verify is if the AC adapter/charger is plugged in and the problem persist, then it would be "something else".
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 27, 2008
  • 177 Answers
SOURCE: Laptop overheating and shutting down
CPU IS OVERHEATING AND OVERWORKING MIGHT BE A VIRUS OR A HANING PROGRAM
Posted on Jan 20, 2009
LaptopExpert
  • 458 Answers
SOURCE: Bought a HP Pavilion 17
Sounds Like Video Failure...
If you were Gaming On THat Laptop, You Probably Overstressed The Graphics Chip/GPU..
Other things that would cause the shut downs would be, Incorrect or Faulty AC Adapter, Make sure you use a 19.5v 90Watt.. Not the 65 Watt..
Failing or Bad Ram, Misseated RAM... Open port to RAM on underside of laptop, Pull The RAM and reseat it..
Make sure Hard Drive (s) are securely seated..
Posted on Nov 21, 2009
rytechcsltd
  • 83 Answers
When you say it shuts down, does it simply turn off straight away? If so I would say it has a faulty power connection. If it goes through the whole 'Windows is shutting down' processes then it maybe the motherboard which is faulty. Either way it sounds like quite a serious issue.
Posted on Nov 22, 2009
  • 21 Answers
SOURCE: hp laptop is not shutting down after i shut down
we need to change the power options from control pannel and change the sleep options to never and then restart the laptop
its going to work
Posted on Dec 15, 2009
A BEEPING NOISE WHEN YOU PUSH A KEY
It's more likely your laptop is frozen. You will need to completely shut down the laptop. Remove the battery and remove the power cable. Leave for 30 minutes off. Then restart the laptop with the power cable connected only (without the battery).
Feb 05, 2011 | Dell Computers & Internet
My hp laptop shuts down when its operating.what might be the problem?
i think due to virus corruption it is shuttin down please install a good antivirus and check for viruses
Jul 16, 2010 | HP Pavillion DV6227 Notebook
Laptop shuts down after 20 or 30 minutes with one
Please refer to manual and run system restore to system default settings as if it was from the package.
Cheers.
Jan 24, 2010 | Dell Inspiron® 1501 (N11157) PC Notebook
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Hp laptop is not shutting down after i shut down
its going to work
Dec 15, 2009 | HP Pavilion dv6000z Notebook
Acer laptop goes off after 30 minutes exactly. wont come if i try immediately but after about 5 mins comes on when I power it. help
you have set ur computer to sleep or hibernate after 30 minutes of inactivity. you can customize this in you power setting.
Control Panel-> Power Options
Sep 27, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
My hp dv 2000 shut down while working and then by pressing the power key it resumes to the same position. this problem repeats every 2-3 minute of working. Please solve this problem.
this problem can't be called as ur machine's shuttin down...This is called sleep mode...
Well this usually happens with laptop's.. This happens when ur laptop's battery run's out of power.. now if u think that u keep the power cord plugged in & still it happens, open the battery socket at the back of laptop, clean the battery terminals & the slot where its placed.. Now restart the system & go to control panel.. go to power options & check all ur settings.. There might be a setting named stand by time.. just change it to never..and the option, Turn Of Display... change it to never..
Now try it out
Hope this helps u out...and if doesn't then feel free to ask again
If u like my post, please rate me up.. i really need some good ratings..
Thanks !!!
Sep 09, 2009 | HP Pavilion dv2000t Notebook
No power acer aspire 5310 I left my laptop on charge and worked fine, then no power or lights, battery is full charged, trie reset and power down 30 secs on switch, nothing!! any ideas? thanks in advance
Sir,
It seems to me that your Processor of the Laptop has got effected to and unbalance current supply. As you know that replace processor would work i would suggest you to claim its waranty before replacing new processor.
Aug 31, 2009 | Computers & Internet
Battery and/or overheating or ?
It is possible that the battery is not charging at all and can't pass electricity to the board. But if its 3yo, its probably really dead.
Also, if you can see a fan not working at all, overheating is also possible.
It is also possible that there is a tiny foreign object capable of conducting electricity, such as human hair, that gets activated at the slightest movement of the laptop by shorting some pins on your board.
So I would suggest to observe more or clean the inside of your laptop if you know how to remove your keyboard.
Apr 28, 2009 | Computers & Internet
Shutting off
i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
Apr 22, 2008 | HP Pavilion dv1000 Notebook
HP ProBook 4530s Notebook Logo
127 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
