Sewer smell in the drum
A sewer smell is coming from the drum. The washer had stopped in the middle of a load back in June & when the repairman took it apart to fix it, the smell was horrible. He said that was common, and the smell would go away after he fixes it...and it did. But now (four months later) the smell is back & seems to be coming thru the drum.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Beat way to solve this problem is, Run your machine on the highest setting and add a cup of bleach, do the same again and add a cup of vinegar, this will clean the inside of your machine and give the water inlets a good clean out. Repeat as necessary.
Posted on Nov 06, 2012
57 varieties
  • 1653 Answers
SOURCE: sewer gas smell
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Posted on Sep 10, 2009
localwonder
  • 6784 Answers
SOURCE: Sewer smell when I use the front load washer
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
NOTE_ If the above suggested actions do not heel this, ungodly, fragrance, I would recommend to have the septic tank inspected for clogs, or ruptured lining. Have the septic lines inspected, as well.
Posted on Dec 15, 2009
SOURCE: I have a Kenmore washing machine and so far I
You are probably correct with the idea the sewer smell is not coming from the washer but rahter then drain line. Was this recently installed or has a slow drain down the pipe? There is suppose to be what is called a P-trap installed in the drain pipe to restrict the gases from coming back into your home. Check the drain line. If I can help further, I am here. Eric Campion
Posted on Mar 03, 2009
  • 21 Answers
SOURCE: LG washer (31 ESP4-Wash) has a very bad smell like
It could be several problems. Door gasket needs to be cleaned often with bleach. Door needs to be left open between washings. Clean and drain water filter on drain. Use a bleach and water solution on an empty drum and let it set. Then run it unloaded to rinse.
Posted on Dec 31, 2009
tiger56h
  • 176 Answers
SOURCE: Kenmore 90 series washer has
check the cunktin gaz
usde suop to testing cunkctin
Posted on Aug 23, 2010
I occasionally have a sewer gas smell near my washer. But after I run the washer, the smell will go away for a few days. What could the problem be?
Hi Joe
Is that pex pipe on the right your water supply to the washer?
Your sewer gas smell I believe can be eliminated by putting a P trap in the drain PVC line.
(EDIT)
Where the drain hose from the washer hooks into the PVC pipe is NOT airtight which would allow the sewer gas back into the laundry room!
(EDIT EDIT)
If there is a P-trap in your outflow pipe, the only place left for grey water to collect (and stink) would be between the washer and where the waste hose goes into the drain. We've had to use a little bit of bleach on occasion when we haven't used the washer for a bit.
Hope this helps
-Steve
May 02, 2015 | Maytag Neptune Washing Machines
We purchased a kenmore high efficiency washing machine. after the second load, we get a sewer smell in the other part of the house.do you have any suggestions?
There may be a venting problem with the sewer lines. These machines expel water very fast and at higher pressures than other types of machines. This can cause suctioning of water from drain traps if there is improper or clogged venting of the sewer lines. Have the sewer lines checked by someone knowledgeable about proper venting practices.
Aug 23, 2014 | Washing Machines
Sewer smell in clothes
The tub is probably pretty dirty. Try cleaning the washer with CLR.
Visit this information:
http://www.ehow.com/info_8053120_clr-clean-washing-machines.html
Mar 19, 2014 | Fisher and Paykel GWL11 Top Load Washer
I being plagued with sewer gas how can i stop this
sewer gas is stopped by water in the drain. often three drain I. the floor dries out. or your drain is not holding water. pour water into all your drains. .
Nov 01, 2013 | Plumbing
Dryer was flooded when we had a sewer back up.
water can damage alot of the parts on the washer and dryer the motor would have been completly under water on both units and the control on the dryer would have gottin wet as a repair man anything can be fixed but to what cost
Jun 02, 2010 | Kenmore 72982 Gas Dryer
When machine pumps out the smell comes through the sink
All plumbing drains whether under a sink or the stand pipe drain, for a washer, are required by LAW to have a trap to prevent the sewer gases from entering a home.
Sewer gases are dangerous in many ways, not the least of which is the terrible smell. Sewer gas can build up and if allowed to accumulate near an appliance that operates on gas (LP or natural) can combust and cause a fire and/or an explosion.
Yes, if you can do the installation youself, do it ASAP, or contact a licensed plumber and have installed a proper drain trap for the sink and also make sure the drain that the washer is draining into, also has a trap in it.
This will have a profound impact on the smell and will help alleviate foul odors from your sewer lines.
Hope you found this Very Helpful and best regards!
Sep 22, 2009 | Whirlpool AWM5145/2 Front Load Washer
Laundry room smells like rotten eggs
Does the sewer drain line have a trap at the bottom that prevents sewer gas from entering the room? If the smell seems to be coming from the washer itself, run a wash cycle empty with a cup of baking soda, detergent and hot water to clean the interior.
Sep 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
A strange smell is coming from the drum
go on espares and buy the limescale and detergent remover this should clean the machine out
Jun 28, 2009 | Hotpoint WMA54 Front Load Washer
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
roof.
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
home.
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
