Question about Ingersoll Rand SS5L5 Ir Electric Stationary Air Compressor 5HP. 60 Gallon Single Stage Vertical
I have an Ingersoll Rand SS5L5, and have trouble with the air pressure dropping to low before starting u back up. I have replaced the pressure switch already, but that does not seem to help much. Any
This is an 08 model.
  • 65 Answers
SOURCE: Ingersoll Rand M # 10T3NL Trouble
your problem seems to be that the non return valve is passing ,your local i/rand dealer can supply a new seal,there not expensive
Posted on Dec 03, 2008
  • 583 Answers
SOURCE: need to know how to adjust pressure regulator for low/high limits
sorry to be contradictory here, but better not to mislead or scare someone... Thepressure relief valve has absolutly nothing to do with cut in cut out pressure settings.the pressure relief valve is abrass fitting on the outside of the tank hexagonal fitting with a thin shaft coming out of the centre normaly with a ring on it not unlike akey ring .THAT is a blow off valve a safety device, that long before the air pressure is too great for the tank,will blow offthe air pressure in the tank ,try it, grab the ring and pull it out and it will dis charge any air in the tank ,that ios what it will do if thair is too great in the tank.. tanks are pressure tested and the appropriate valve fitted. NOW FOR YOUR ORIGINAL PROBLEM .you will find a control box ,useualy black or dark brown bakerlite cover,the electric cord goes into it ,also there will be another electric cord coming out and going to the electric motor that drives the compressor . If you take the cover off this you will find the cut in and cut out adjustments that allow you to set the cut in and cut out pressure as high or low as you want,that is whith in the capascity of the unit.It is self explanitory and there will be ( or should be ) instructions inside the cover .If you have any difficulty come back to me preferably with themotor and compressor sizes and i will walk you through it NOW AS MUCH AS THIS GOES AGAINST THE GRAIN, SHAG79 IT WOULD BE FAR BETTER IF YOU KNEW A BIT MORE ABOUT THE THINGS YOU ARE ADVISING THEM ABOUT EXPLOSIONS AND DEATH !!! WHAT ARE YOU-----A ******???
Posted on Aug 13, 2009
ollie reece
  • 1167 Answers
SOURCE: I have a ingersoll rand air compressor rand 4000
you dont torque it you can torque it ya self if you wont but wont make a change do it to 40-50nm ahd try this if no good replace the gasket they do wear out at times also when you take the head off thereshouldnt be oil in there only on the cyclinder not the head ??
Posted on Oct 08, 2009
compman66
  • 169 Answers
SOURCE: i have a ingersoll rand type-30,model#2475 7.5
from what you are describing it sounds like you are missing a couple wires somewhere or you do not know what you are looking for. The pressure switch, low oil switch motor starter coil, and overload relay should be wired in series to provide a control circuit for the motor starter. I would highly advise seeking the help of a certified electrician if you are not experienced in working with these machines. You can not only risk personal injury, but also damage a lot of expensive electrical item's real quick if it is not done correctly.
Posted on Dec 06, 2009
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
Ingersol rand 80 gal 5 hp manual
follow the link
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/SCD-877.pdf
Sep 07, 2014 | Ingersoll Rand SS5L5 Ir Electric...
Keeps tripping the reset button after done building up pressure, why?
Since I am not there and can't see what is happening this might just be a WAG, but when my air compressor does that, it is either the pressure has been set too high, and when it reaches the maximum rated setting it trips the over pressure switch that trips the reset button.
It has also happened when the pressure regulator whent out and did not sense the pressure that it was supposed to turn off on.
Sep 15, 2011 | Ingersoll Rand SS5L5 Ir Electric...
Large volume of air coming out of vent
If the are coming out the vent is located at the pressure switch you have a stuck or bad tank check valve. Take the small copper line off at the pressure switch. If it blows air. replace the check valve. The check valve is located in top of the receiver tank. The copper tube removed goes back to one side of the check valve. Just remove the small tube from the check valve. Make sure there is no air pressure on the tank. remove the copper tube frome the compressor head and from the top of the check valve. Using the proper size socket,wrench,etc. remove the check valve. Inspect. If it has some type foreign material in it clean. If you fell that will correct the problem install in reverse order. I usually replace them if I have gone to the trouble of removing. Good luck!
Jul 22, 2011 | Ingersoll Rand SS5L5 Ir Electric...
What could cause a piston to break inside the compressor
Bearing failure allowing piston to hit valves or a broken valve dropped into the motor but need to know if it's a piston type or a reciprocating compressor because they would have different problems.
Jun 16, 2010 | Ingersoll Rand SS5L5 Ir Electric...
My SS5 won't make any pressure. I drained the tank to around 10 psi to drain moisture out of the tank and it built the pressue back up to around 120 psi but won't build any higher. The shut-off point is...
Sounds like the pressure regulator has gone bad. That controls how much PSI your system is aloud to have. If this fails it will not fill to max capacity. I would replace that and all will work just fine.
Please rate
Jun 01, 2010 | Ingersoll Rand SS5L5 Ir Electric...
Cuts off with no reason
hi mate when the reach there working pressure e.g.150psi/10bar they shut off and then when the pressure drops to a pressure of e.g. 100 psi 7 bar they automatically start back up and pump back upto they working temperature or if it dont start at all it could either be a faulty pressure switch or a fualty star delta starter if its 3 phase 415 volts if its 240volt there are only a pressure switch which will be faulty get a sparky in to sort it out there buggers to mess with 415volts 240 volts easy
Jun 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
Wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
May 30, 2009 | Ingersoll Rand SS5L5 Ir Electric...
Ingersoll Rand  SS5L5 Ir Electric Stationary Air Compressor 5HP. 60 Gallon Single Stage Vertical  Logo
54 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
