Question about Canon BJC-85 InkJet Printer
Comms failure message
I haven't used my Canon BJC-85 for printing in years, although it gets used for scanning quite a lot without any problems. But now my daughter wants to use it to print stuff, so I bought new cartridges replaced the old ones, but nothing works. It makes all the right start up noises when its switched on but then I get lots of beeps and two flashing lights. I've looked after it well so can't work out why its suddenly not working.
Running Win XP but I get the same thing when I plug it into my old Win 98 laptop
Gavin
  • elegav2001 Jan 09, 2009
    It went down to the service centre where it was diagnosed as dead, chip had gone, cable to cartridge carrige (spelling terrible this morning) not working, rubber band that moves carrige missing numerous teeth and frayed, taken out back and humanly put down.
  • 25 Answers
Good to excellent chance that by not using the ink jet for "years" that they are hopelessly clogged. You can try the cleaning procedure but I'd bet that your lack of use has ruined the ink jet portion.
I had this happen to me and went through (and wasted) a lot of time and money cleaning the printer and trying to get ink to come through.
On the bright side You have a lovely scanner. Time to go buy a printer. Sorry but I think your "printing in years" is probably a self imposed problem created by lack of use. Ink's pesky and clogs if it's not spit through at regular interfals.
Posted on Jan 05, 2009
My BJC-85 printer is only printing blank pages when i send stuff to the printer. I have tried cleaning and ink test etc.
I am having same trouble with my BJC 85, and my Canon i70 and i80 printers. It always starts that the ink gets weak on the paper, then stops printing. I have tried deep cleanings.....several dozens.....and doesn't do anything. So then, I have cleaned the print head by soaking in alcohol or merely dabbing with Qtip of alcohol, and old ink usually is dissolved. But then I have NEVER been able to get a cleaned print head to accept ink thru. I have even added ink to the print head itself, and just wont print anything.
Some other sites speak about soaking it in warm water to dissolve old ink, I'm going to try that as last resort, but after that, I really don't know what to do. I have NEVER had this problem with my 85's before. They've been extremely faithful workhorses, but since last year, getting cheap ink online made in China has clogged up the printers.
I do not have any error messages, so don't have to deal with that. But just perplexed why the print heads won't work, especially after cleaning with alcohol. They just seem to shut off.
Terry tlworkroom@lycos.com
Jun 30, 2010 | Canon BJC 85 InkJet Printer
BJC 85 not printing after head replacement
I have similar problem. Print head won't print, then I clean with alcohol, and get rid of old ink inside. But then head seems to just shut down. I have several print heads and printers that have plenty of ink, but head won't work. I refuse to think the print head will break so easily. I used my BJC 85 for YEARS with no problem whatsoever, and suddenly, since last winter, I have 4 printers that have stopped printing.
I usually end up just buying another used printer on ebay until that one stops printing.
Feb 28, 2010 | Canon BJC 85 InkJet Printer
BJC-85 Not printing. New BC-10 and BCI-10. Paper loads normally
The problem you are having is with the print head and not the printer. Unfortunately, with these canon print heads, they are not dated, so it is possible to install a print head that was bought new and sealed, but is still dried out because it is old.
Try running the print head through one deep cleaning cycle, this sometimes will start to get an old print head flowing.
Deep cleaning cycle can be found by going to PRINTERS , right clicking on the BJC icon, selecting PROPERTIES from the drop down menu, and then selecting the MAINTAINENCE tab.
Check to make sure that the ink tank in the print head isn't dry. Even a new print head can have a dry tank if it's old.
Jan 10, 2010 | Canon BJC-85 InkJet Printer
HOW TO GET THE SOFTWARE FOR INSTALLING canon bjc-85 BUBBLE JET PRINTER
Hi friend,
You need to visit canon web site then select your printer model no...then download your software...then it will work..
Dec 25, 2009 | Canon BJC 85 InkJet Printer
Beeps 3 times and power light flashes
I have not solved the problem. I just changed to a different printer. I had a bj50 printer and it use to do this and would change the printhead but they are expense and I have 3 different ones so believe it is something else that is wrong with this one.
Apr 18, 2009 | Canon BJC 85 InkJet Printer
What does disabling bidirectional support mean
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} USB to Parallel conversion requires translation by XP and Vista's 'hardware interleave' software as well as the USB device manufacturers driver. The software package just doesn't work well with older peripherals that use legacy parallel or serial com ports. Too many sloppy layers.
THE BEST WAY to add an LPT printer port to your laptop is to use a PCMCIA to Parallel adapter card.
The PC Card slot provides access to the laptop's data bus, and the PC Card adapter easily sets up as a native LPT port within almost any OS.
There is no delay, or connection problems as I've seen in so many complaints about USB to Parallel or Legacy Serial adapters. Printing is Instant.
PCMCIA is a mature standard, and works seamlessly with XP and Vista, and almost any other OS.
PARALLEL is the old standard fast data protocol. IEEE 1284 ECP mode up to 1.5 Mbps.
The BJC-80 and the BJC-85 have the same print speed. The BJC-85 just added USB.
INFRARED is ver 1.0 on the BJC-80, and printing is a bit slower at 115.2 kbps. Even the BJC-85 with its higher IRDA transfer rating and a laptop's built-in IR port, the XP print spooler has problems with it, and can hang if printing more than one page, and especially with more than one document. It will not scan.
I use IR for printing single pages only with either the BJC-80 or BJC-85.
USB to IRDA adapters work fine, and are less expensive $5-6 than
PCMCIA to Parallel adapters, $20-25.
I have tested and used several PCMCIA adapters from different manufacturers, and they all work perfectly as a hot-pluggable, instant LPT and/or Legacy Serial port for my laptops.
TIPS:
After installing the PC Card driver, check Device Manager for the LPT port number.
Install the printer manually from the list of printers, and select the proper LPT port.
Most laptops have two PCMCIA slots. If you change slots, the adapter card driver may reinstall, and assign the next available LPT port, LPT2.
To scan with the BJC-80, you must have an LPT port.
The PC Card adapter also allows the use of the IS-12 scanner cartridge within XP or Vista.
Within Vista, set the Canon ISScan software to run in Windows 98 compatibility mode, to allow use of the TWAIN driver.
Jun 12, 2008 | Canon BJC 80 InkJet Printer
Canon BJC 2000 question-1284 to usb
TIPS:
Jun 05, 2008 | Canon BJC 80 InkJet Printer
BJC 80 Won't Print
Try disable bidirectional support
Jun 02, 2008 | Canon BJC 80 InkJet Printer
Time consuming
Try installing the latest driver: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998
Aug 23, 2007 | Canon BJC 80 InkJet Printer
Canon BJC-85 InkJet Printer Logo
119 people viewed this question
old marine
old marine
