Question about ASUS X70 CPU Cooling fan heatsink Socket 754 939 AM2 (B994936)
Asus noisy fan - ASUS X70 CPU Cooling fan heatsink Socket 754 939 AM2 (B994936)
  • 1,087 Answers
Take a toothbrush and gently remove and dust collecting on the fan blades. That dont work a replacement heatsink fan is like $8
Posted on Jun 09, 2014
Cpu fan speed
1. Check if something like power supply wire have bangin in there.
2. Clean : Try to use lighter fluid to loosen and clean the dirt inside the processor fan but first disassemble the fan from the heat zinc of the processor. flip the fan and you will see the bearing and motor, drown it with fluid, and rotate the fan so the dirt will loose, after some spins, try to spill the fluid inside the fan. then assemble and test.
Dec 26, 2013 | ASUS P5P800-VM Motherboard
Tip
Fixing the noisy fan a8ne-fm
ok     i did this two days ago and it worked for me. 1  Turned off psu 2  Opened the case 3  remove graphics card from pci-e slot 4  unplug the small circular fan in the bottom corner of motherboard.  5  unscrew the cover on the top of the fan 6  clean in the fan/heatsink with scewdriver whatever 7  get your screwdriver under the plastic fan bit and raise it slightly from its heatsink     only a little tiny bit though.      8 leave the top cover OFF 9   plug fan back in and install graphics card 10 power on at psu
It worked for me no noise and have been playing cod4 quite a bit
on May 20, 2008 | ASUS A8N-E Motherboard
Asus essentio pc fan noise issue
The fans generally are not controlled by the user. If you post the model number, I can check, Noise means that it is either becoming dry on the spindle or it is becoming very dirty.
Jul 14, 2013 | Computers & Internet
Cooling fan intermittently noisy.
Most likely the fan bearing is worn out, yes it needs replacing.
Oct 17, 2012 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
My asus eeepc 1005 ha is generating noisy sound. How can I solve this?
It could be the CPU cooling fan. First try to blow the dust out of the case with compressed air. The fan could just be dirty. If that doesn't work, I would suggest that you get the fan replaced. You can do it yourself if you feel comfortable taking the computer apart. If you don't have the experience, though, take it into a shop.
Mar 16, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Why my motherboard did not start and have noisy sound coming from my processor what might be the problem?
If your processor fan is not functional at the correct RPM this could cause your system not to function.. The noise could be a cable rubbing against the fan...
Feb 11, 2011 | ASUS P4PE Motherboard
I have a laptop ASUS X59GL series, i am experiencing recently a sudden shut off of my pc even just in 30 minutes of using. especially when i'm playing video player on the net, it just shut off...
Hi, It may be because of the of the fan or heat sink might not be working . so ur pc is getting off. contact service centre.
regards sathyamoorthy
Nov 14, 2010 | Computers & Internet
Very noisy fan
Make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Oct 18, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Want to replace noisy fan for ASUS Intel 845 Chipset P4B Motherbo
This should give you time to find a new fan
Remove paper center from fan and put a small drop (I mean small) of light machine oil on the bearing then replace paper center.
This should get you out of trouble for a few months at least.
I have done this with at least 8 fans in the past some never needed a new fan
Dec 18, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
ASUS X70 CPU Cooling fan heatsink Socket 754 939 AM2 (B994936) Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
