Question about HP ProBook 4530s Notebook
My lptop computer
My problem is shutting down after 30 minitis even no heating and the fan is good Tanks
  • max carson
    max carson Nov 05, 2012
    A bit vague.Can you be more specific.To give an informed solution I need more information.
  • HP Master
  • 7,627 Answers
Where do you use the laptop? on a soft surface? Dirt, dust, no air flow?
Posted on Nov 05, 2012
My good man furnace model gmh80903bnca will not get to temp fan shuts off and burners keep burning then kicks off on high limit then starts process over but never gets to temp set at 655
If you have a switch that can manually turn on the fan, try it to verify the fan works. This is what I think is happening. The normal operation should be thermostat calls for heat, inducer fan comes on, pressure switch closes, igniter glows, main burner ignites and then in 30 or so seconds the fan comes on and stays on until the thermostat is satisfied. Once the thermostat is satisfied the burner shuts off and the fan runs for approx 120 seconds then shuts off. I think the control board that automatically turns your fan on is faulty. On most modern furnaces if the auto fan control fails and the furnace gets to hot and limits, when the limit opens and shuts off the burner it also energizes the fan motor to cool the heat exchanger.
Jan 13, 2018 | Heating & Cooling
6 cylinder ba Fairlane it runs ruff under load for the first 30 miutes then comes good.
Here is an idea, considering that symptom is common on many cars today.
Check the "engine temperature sensor" of the which there are two screwed into the engine block.
One of those sensors goes to the computer, one of them goes to the electric cooling fan in front of, (or behind) the radiator.
If the one to the computer fails, it can cause this symptom, because it is telling the computer the wrong engine temperature.
If the one to the radiator fan fails, the car will overheat.
God bless your efforts.l
Feb 21, 2017 | Cars & Trucks
The fan on ford escort van 51 plate continually runs even when the ignition off
Sounds like either a temp. sensor, or a timer malfunction. There are heat sensors that make the fan run after you shut it down, until it's cooler, usually doesn't run long. You didn't mention if it continually runs, or if it shuts down after awhile. Other than taking it to a shop, check your fuses, wires connecting the fan under the hood, look for any frayed wires and/or loose clips. Good Luck. Grimm
Apr 11, 2015 | Ford Escort Cars & Trucks
2007 Panasonic 50in Plasma shuts off after being on 30 min sleep timer off, is the problem the cooling fans out/ over heating
Yes, cooling fan could be a problem. Just see whether it goes off during before shut off. If yes, the TV might need service. To know whether the fan goes off first or the TV, stick one side of any thin vibrating membrane such as a silver paper (like the one you see in cigarette packets) on the fan outlet, without blocking it, so that you can see whether it stops before the TV shuts down. Alternatively you can hand an inflated balloon which keeps flying off from the area of the fan and shall stop when the fan stops. I suggest this, in order to save your time looking at the rear all the time until the TV stops. Even then, one is likely to overlook whether the fan stops or TV stops first.
Aug 29, 2012 | Panasonic Televison & Video
HP M7357c overheating problem
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 03, 2012 | HP m7357c PC Desktop
Hello, my Optiplex, whenI am playng, suddenly shuts down. I mean there isn't a SW crash, only the PC shuts down and I am obliged to reboot. May be a temperature problem? Tanks Marco (Rome Italy)
Gaming consumes more CPU/ Processor resources and due to the heavy processing the PC heats up. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heatsink.
1. Make sure the fan is running. (if not, it needs replacement)
2. Clean the fan and heat sink (thermal module).
Take out the fan and heat sink. clean them with the help of tooth brush and put it back.
3. Also, make sure that the PC is placed in a well ventilated environment and the air flow the the PC is correct.
The procedure is very simple and I believe immediate action is required to prevent any damage to your machine and data.
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
I run the computer for about 30 min. sudenly it will stop showing anything in the monitor i try it to open but there is no boot and no picture , and i check even the processor heat sink is not produce heat
hmm!! there is problem with your processor's heat sink only!!! your system is getting over heated so it shut downs automatically to prevent damage!! i have also gone through this problem!!! try changing the processor's fan!!
Oct 24, 2009 | ASUS A8N-SLI Deluxe Motherboard
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
Computer does not fire up. I do have steady green light on power supply. All motherboard connections appear to be tight.I have come home before to a beeping noise in the past. After resetting the machine...
That beeping noise may be due to over heating.
Most machines today have a temperature setting that will turn the machine off once the temperature reaches a certain point.
Safety feature to avoid damaging your cpu and components.
The shut down and restarting allows the CPU to cool down briefly.
Thus allowing you to start the machine again. Usually it will shut down again once the temperature threshold is again reached.
Good test is let the machine sit for 30 min. If it immediately starts up and shuts down a few minutes later. Heat build is usually the problem.
Typically this is due to heat sink or Fan on the computer CPU.
Check to be sure both are connected to the CPU and functioning.
If you have a fan on top of the heat sink above the CPU. Make sure it is working correctly. Dust build up over time will eventually kill the fan bearings or reduce airflow. Heat sink can and will become clogged with dust also. Replacement fans are easy to find. Heat sinks are even easier to clean.
Depending on your machine and CPU position replacing the fan can be a challenge. But can be done in a few minutes with minimum tools.
Each bios has different post codes and it is difficult to tell what is happening with out knowing the bios of your particular machine. Listen for the beeps and check your computer manual.
You can also google for this. Here is a web site that lists a few bios P.O.S.T codes.
http://www.computerhope.com/beep.htm
Once you know the beep sequence you can look it up. Usually points to the problem and you can go from there.
Oct 06, 2009 | Computers & Internet
HP ProBook 4530s Notebook Logo
66 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
