Question about Whirlpool GD5SHAX Side by Side Refrigerator
Kitchenaid refrigerator/freezer Hello Noggin I have a kitchenaid side by side refrigerator (frost free) 4-5 years old, no longer under warranty. About a week or so ago the freezer stopped freezing, the refigerator seemed fine. So I turned the freezer temp control up a notch and when everything was frozen again I turned temp back down to normal. It was fine for another 3-4 days then it happened again. I pulled the grate off bottom and cleaned off the coils they had quite a bit of dust on them. Plugged it back in at normal temp and still wasn't freezing so I turned up a notch again then it froze but only lasted a day. This morning it was defrosting again. Do you have any idea what would cause this. Thanks Karene
  • doc phun Mar 06, 2008
    We are having exactly the same problem after 5 years and are awaiting a repair technician. We tried the same measures to correct the problem including cleaning the coils. Neal Swanson
  • Anonymous Mar 17, 2014
    Refrigerator is about 4 years old. Works well except it began making a clicking sound
We are on our second kitchenaid because of these types of problems and it is showing the same symptoms.
Posted on Jul 14, 2008
We are having the same problem with our Kitchenaid, we purchased it 5 years ago. Do you have any idea what the problem is? Thanks
Posted on Mar 28, 2008
  • Whirlpool Master
  • 909 Answers
SORRY, YOU NEED A TECHI. THERE. EITHER YOUR TH/STAT IS STICKING OR THERE IS AN ISSUE WITH YOUR AUTO DEFROST UNIT. ALL THINGS TOLD CHECK THAT THE FREEZER OR EVAPORATOR FAN IS RUNNING. IF NOT IT COULD ALSO CAUSE PROBLEMS.
Posted on Jul 20, 2007
KitchenAid KSBP25FJSS01 side-by-side refrigerator 9 years old. Refrigerator is freezing food in 2 bottom drawers and in back of 1 shelf toward the top. Is this potentially a major or minor repair? ...
Its not a major problem... It could be any of the following. The evaperator fan is not working in witch case the temps will rise soon and quickly you can check this by opening the freezer door and push the light switch if there is one and listen for the fan.
Next look at the back wall of the freezer and look fof FROST if you have frost then you have a defrost problem in withch case it could be a heater, limiter, timer, or control board.
or your thermostat is bad and is letting the compressor run longer than normal.
This should cover the most common problems.
Sep 05, 2010 | KitchenAid KSBP25IN Side by Side...
Refrigerator side not cooling
Defrost the freezer it may be iced up and not letting the cold air in to the fridge side.
Sep 03, 2009 | KitchenAid KSCS25FKSS Side by Side...
Right side stopped working (KPTT809)
I had the same problem with my Kitchenaid toaster which is 4 years old. I called Kitchenaid and they said that this model now has a 5 year warranty and they have replaced the toaster for a new one. What a fantastic company. Try giving them a call.
Jul 06, 2009 | KitchenAid KPTT890 Pro Line 4-Slice...
I suddenly have frost in my frost-free freezer?
usually this would be from a door seal or the door not getting closed all the way.
May 20, 2009 | KitchenAid KSCS23INSS Stainless Steel Side...
KA KSRS series lost cooling in refrig only
Check for frost accumulation in freezer or no freezer fan
Jan 27, 2009 | KitchenAid Superba Architect KSCS25INSS...
Side by side (KSRB25FHSS05) loosing cool in freezer
your compresor is hot but is it running at all or is it just humming trying to start and the just clicks off if it is just your overload that is tripp you need to replaced it that the box connected to the compressor on the left side that is why not is cooling if is running then is cheaper to buy a new one since the 5 year warranty on the compressor has expired
Nov 03, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid freezer will not stay frozen 5 years old
it might be your thermostat stucking up...the one your adjusting one notch higher...
Mar 28, 2008 | Refrigerators
Water filter
I don't think this model has a filter, I checked under the kickplate, no filter there.
Mar 26, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Failure
compressor is hot but is it running. one likely thing i would check is the start relay on the compressor.
Dec 09, 2007 | KitchenAid KSRS25IL Side by Side...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
160 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
