Question about Whirlpool Duet GHW9150P Front Load Washer
F 01 fault code on front load washer - Whirlpool Duet GHW9150P Front Load Washer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
ERROR CODE F01
The pump driver fails to activate/One of the main relays is not working properly/
A communication error between the Central Control Unit (CCU) and the EEPROM
onboard the CCU occurred.
Check for loose power outlet. A loose power plug in the wall can create
line noise and issues.
- Check if washer is on a dedicated circuit. Other devices on same circuit
can create line noise and cause this issue.
- Unplug washer or disconnect power.
- Make sure that wire harness connections from the CCU are not broken or with wires
detached, and that connector internal pins are visible.
- Make sure all green wires (ground harness system) are not broken or detached.
- Make sure the two ground switches are pressed correctly by the toe and rear panels.
- Make sure all connectors are fully seated.
- Plug in washer or reconnect power.
- Check for power going to Central Control Unit (CCU) by listening for a click in the
CCU when unit is plugged in washer or when reconnecting power.
- Verify unit operation by performing the Diagnostic Test.
- After the diagnostic test has finished, unplug washer or disconnect power
and wait for 15 seconds.
The CCU is located under the top panel which you already removed. Here is the part to order.
Posted on Nov 06, 2012
  • 1028 Answers
SOURCE: code F 01 come up
must be a duet sport ..change control module ..remove screws along rear of top panel remove panel by sliding back .control is white or gray box on right near front
Posted on Aug 29, 2008
rickzilla
  • 706 Answers
SOURCE: whirlpool duet front load washer
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Posted on Sep 28, 2008
  • 6 Answers
SOURCE: Washer displaying a fault code.
check your manual. it will tell you what it means and what to do
Posted on Apr 01, 2010
  • 5370 Answers
SOURCE: get the code F-01 on
Click this link directly:--- http://mymoremoney.blogspot.com/2011/01/whirlpool-duet-ghw9150p-front-load.html --------------- In this there is instructions and procedure mentioned to resolve the issue. If any part checked out faulty then you can get it from www.repairclinic.com .----------- Thanks.Helpmech.
Posted on Jan 14, 2011
TheMobilian
  • 8220 Answers
SOURCE: F-01 code on a whirlpool front load washer
Frontload failure code
F-1 EEprom error due to:
power glitch
remedy: unplug washer for 2 minutes
if error still exists replace CCU board
Causes:
Pump driver failure to activate on CCU.
Main Relay stuck on CCU.
Relay points welded or open on CCU.
Posted on Sep 30, 2011
Code f-01
Hi.
F01 is pointing at a fault of the motor triac. The motor triac is part of the control assembly and controls the motor.
Try disconnecting power cord. If the fault code comes back, then motor, motor brushes, wiring or control module may need replacement.
Aug 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
It won't drain and says F4 on display, I have checked the filter at the front and it is clear, it is plumed in into the sink and that is not blocked? Pls help I can't afford a new washing machine...
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump.
Hope helps.
May 11, 2011 | Bosch Exxcel WFO 2264 Front Load Washer
Get the code F-01 on the whirlpool duet front loading washer, not sure what this code means
Jan 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is fault code F 01
F01 - Short circuit motor triac. most of the time this means you need a new control board. thing to try is to reset machine by switching off at plug for 5 mins then plug in and try again. hope this helps.
Sep 24, 2010 | Hotpoint Ultima WF865 Front Load Washer
I have a F-01 fault code on my Kenmore HE2plus front load washer. model # 11047512601. Sears talked me thru the software resets and still had the F-01 error. do I need to replace the Main Control Unit?
The F01 fault code is indicating an EEPROM error or a PUMP DRIVER error. A communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Possible causes of an EEPROM error:
A power glitch may have caused this error. Unplug the power cord for 3 minutes then reconnect power.
Possible causes of PUMP DRIVER error:
The pump driver fails to activate. Replace the the CCU board.
Most likely the CCU board will need to be replaced.
Thank you !!
Jun 28, 2010 | Kenmore HE2 Plus Front Load Washer
Have a fault code show on washing machine f-01 hotpoint wd640 Thanks Paul
F01 - motor triac on main pcb. check motor connections/brushes etc if not will need new pcb.
Oct 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
F 01 code won't come off, washer won't start
you have to buy a new ccu unit in sears if you dont have warranty the cost is betwen 175 to 200 $$
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Front Load washer won't start
according to site an f-01 relates to a CCU issue, remove power for 2 min and try to reset, if not check wiring to CCU(central control uint) all in tact?? replace CCU
Mar 03, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Whirlpool Duet GHW9150P Front Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
