Need to replace water inlet valve kenmore washer dryer combo
just need to find out how to get to the valve to replace it. My unit is a combo washer lower dryer upper. Model # 417.99370100
  • kenny more Jan 15, 2009
    I need to do the same thing...
    Same here
  • 15,935 Answers
If you suspect you have a defective Water Inlet valve (also known as a FILL valve or MIXING valve) it can easily be diagnosed by performing the following steps:
- First, make sure the water taps are turned on all the way, and the fill hoses are not kinked in anyway. If everything checks okay, proceed to the next step.
- Now, turn the water taps off, disconnect the fill hoses from the back of the washer and place them in the wash tub. Turn the taps back on and make sure you have proper and forceful water flow (minimum water pressure should be 10-25PSI).
- Check the sediment screens on the Water Inlet valve on the back of the washer. Sometimes these screens will clog with rust or sediment and prevent water flow. Cleaning with some distilled vinegar works well.
If you've attempted all the steps above, but still have no luck, more than likely the inlet valve is bad and requires replacement. Please, read all instructions thoroughly BEFORE attempting. This is a simple repair that any "Do-It-Yourselfer" can accomplish. Follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. The inlet valve is located on the back panel with two or more sets of electrical connectors attached to it. The connectors are usually color-coded to indicate which valve is HOT and which valve is COLD (In the case of a Mixing Valve, you may have additional electrical connectors). Remove the connectors and check the contacts for corrosion. Sometimes a good cleaning can restore a valve solenoid to working order. (You may want to label the connectors, if necessary, to ensure you know how they go back on).
8. Disconnect the small rubber water hose(s) attached to valve with a pair of pliers to release the hose clamps. Inspect the hose(s) for any evidence of cracking.
9. With the water hose(s) removed, loosen the mounting screw(s) and the inlet valve comes off.
10. Re-install new inlet valve following these steps in reverse order. Pay careful attention to make sure you correctly connect the HOT & COLD electrical connections (RED is usually the HOT water side). Make sure all hoses are fitted back in place and the hose clamps are snug.
11. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
12. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
13. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
14. Reinstall console.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
My stackable unit quit filling with water. It still spins and drains. I have cleaned the screens out for the water hoses. I have unplugged it for a few. What else can I do to fix my washer?
Use a meter to test the water valve solenoid coils, make sure nobody turned the supply hoses off without you knowing. Did you recently replace the fill hoses or have work done on the machine? Maytag Washer Dryer Combo Water Inlet Valve WP22001274
Jul 29, 2016 | Maytag LSE7806A Top Load Stacked...
Replace inlet valve
The water valve is only accessible within the washer itself. So depends on the model you have this could be a challenge to replace. Need more information as to the model of the units you have to direct you further. I don't want to give you the wrong information to the wrong units as not all washer and dryer are the same. Good Luck
Apr 18, 2016 | Kenmore Washing Machines
Water keep filling til machine overflow and need to turn of water inlet valve
if you have to shut off the water supply valve of the residence (water keeps flowing after turning off the washing machine or unplugging the washer), the failed component is definitely a stuck open water inlet valve (fill valve) of the appliance. If the water stopped by pushing the timer or unplugging the machine, another internal electrical control related problem exists, such as a faulty timer assembly or controller board, or a pressure system failure (water level detection/monitoring system) - failed pressure switch (rare), clogged air hose or tub air dome (common in GE top-load washers), disconnected air hose (common in frigidaire top load washers & GE/Frigidaire/Kenmore stacked washer/dryer combo units).
While a simple repair can be done by yourself for a failed inlet valve, usually for $25-$50 in parts/shipping (go to searspartsdirect.com or appliancepartspros.com to look up a replacement fill-valve using your washing machine model number), the water damage potentially caused by the flooding is more important to address.
I recommend contacting your insurance company if there's a bunch of water that flooded your home - the water can cause delayed warping of flooring or cause mold to grow in/beneath your carpets and walls if the water was not immediately noticed and cleaned up (within first few minutes of flooding) - they send out water remediation specialists to dry (if possible), or to repair the damage to your home.
Dec 26, 2011 | Whirlpool LSQ8243H
My stacking kenmore washer dryer will only run hot water.
That would be a problem with your water inlet valve. Before checking that make sure the screens in the hose is clear and when you disconnect it from the washer there is a screen inside the valve. Here is a video on checking the water inlet valve. Different unit but procedure is the same. www.appliancehelponline.com/servicemanual.html
Mar 03, 2010 | Kenmore 98702 Stacked Washer/Dryer
Miele wt945 fills with water when switched off
this sounds like a faulty inlet valve as they should only allow water to enter the unit when an electrical signal is sent to the valve. you would need to replace the inlet valve. As it is a washer/dryer make sure you replace the correct valve which is the one on the left
Jan 23, 2010 | Miele WT945 Front Load Washer / Dryer
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
It will make a beep sound with HF light blinks when it gets on Rinse and spin and stops
Hi
Thanks for using FixYa. Error HF on Kenmore washer means that a water inlet problem has occurred. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:-
  • Make sure that both valves at the water source(s) are turned on all the way.
  • Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
  • Check inlet valve operation.
If there is water in the unit:-
  • Check Drain pump operation
  • Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch.
However, it is also caused by a clogged drain filter.
Step One: Unplug Washer
Step Two: Remove front Panel from Washer
Step Three: Locate Filter Assembly(and be ready to soak up water with a towel)
Step Four: Remove Filter. It’s Gross. Check for some coins, socks, toothpicks,etc.
Step Five: Clean Filter
Step Six: Replace Clean Filter
Step Seven: Reinstall the Front Panel. Run load of clothes.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 20, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 4t
This what to check for F/H code from repair manual.
If the water is coming into machine, make sure drain hose is only sticking into drain pipe about 6 inches. Post back if you have any questions.
No water detected entering machine or Pressure switch trip not detected.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has
detected 10.5 gallons of water passing through it, but has not detected the pressure
switch trip, the valves will be turned off and the error code will flash.
Potential Causes
• If there is no water in the unit:
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Nov 07, 2007 | Kenmore Elite HE4 Electric Dryer
Washer
Check first the filters on the inlet water line (both sides). Then, if problem still exist - check that the inlet water valve works(it is an electromagnet valve, located at the pipe's entrance to the machine)). If it doesn't work, test that it get power. In case it get power and doesn't work - You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace it for a new one. Good luck !
Jun 26, 2006 | Kenmore 45081 Front Load Washer / Dryer
Washing Machines Logo
322 people viewed this question
Top Washing Machines Experts
