Question about TruTech LMD-5702RT Portable DVD Player
I cleaned the lens as recommended and now the audio is working & the main screen is lit but no video
After cleaning lens, now main screen lit and audio, but no video
One side not working
the 2230 is a fine unit! There could be several things causing this problem, more than likely it could be dirty front controls which will require cleaning. It could be more serious problems such as pre-amp or main amp failures, dried up output coupling cap for the right channel. I would recommend having the unit serviced. These older vintage Marantz units are really special and deserve proper attention.
Thanks
www.back2lifeelectronics.com
Jan 21, 2013 | Marantz 2230
What to use to clean B & O 9000
To clean externals: just as makers always recommend - soft, very slighlty damp lint-free cloth not of artificial fibre. After using this polish surfaces again with a completely dry, soft cloth.
On any awkward spots use soft breath close-up.
To clean CD deck use a lens cleaner CD kit.
Sep 23, 2011 | Audio Players & Recorders
Boss Audio System Model #BV8966B - will not play DVD or CD's anymore & keeps saying "No Disc"
Some DVD players cant read some DVD s and
then it shows either "loading" or " no disc"..
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Some DVD players are fine at the beginning but after some time later,it begins to have some problems as you have..This is mainly due to LASER eye problems..
Just in case,quick remedy ,
pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
if this remedy does not help and if your set has still under warranty ,consult to service they may replace the LASER Reader EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 11, 2011 | BOSS AUDIO SYSTEMS BV8966B Car Video...
The eyepiece lenses have something on the inside. Can they be removed for cleaning?
  1. Carefully clean your binoculars by firstly removing any dirt or dust from the main body and straps using a soft microfibre cloth. Avoid the lenses at this point using any form of cloth on the lenses before removing all dirt and dust particles first could destroy them.
  1. Gently remove all traces of grit, dirt or dust particles from the lenses using a soft lens brush or canned air specifically designed for the purpose.
  1. Waterproof binoculars can be rinsed gently under a tap but be sure to use on lightly running water, avoid high pressure water as it could damage your binoculars.
  1. Gently remove any remaining marks using lens cleaning tools such as a lens pen or lens cleaning fluid and lens tissue. Do not be tempted to use kitchen towel or anything else lying around that is slightly rough and may scratch the surface of the lens, only use a lens pen, lens tissue or a lens cloth. Gently wipe the lens using a circular motion working from the centre of the lens to the outer edge. NEVER apply lens cleaning fluid directly onto the glass (always apply to the cloth) and always ensure that the lens cleaning fluid you are using is recommended for the type of lens coatings that have been applied to your binoculars (Do not use general household glass cleaning products or products designed to clean computer screens or glasses. Such products could destroy the lens coatings of your binoculars if used).
May 15, 2011 | Tasco 7x50 Waterproof w/Imp. Compass...
Boss audio bv9150 screen strats to flick then says no video signal
Issue with Reader Carrier... Fail To Read Menu On DVD,
Due To Lens Obstruction... Try Magic DVD Cleaner., It a DVD you insert in Then it clean the lens for you... Sometime it Work Good Luck.
Oct 09, 2010 | BOSS AUDIO SYSTEMS BV9155B Car Video...
Wii will not read discs
clean the game disc. Nintendo recommends using a clean, lint-free cloth and water to clean game discs. Use short strokes and gently wipe from the center of the disc out to the edge. Do not use circular strokes, and do not use any cleaning solvents.
Nintendo also makes a lens cleaner tool. The lens cleaner is inserted into the console drive and cleans the disc reader lens. It is available through Nintendo's website.
Keep the console clean and dust free. Use a duster or a vacuum to keep dust out of the vents, and clean the exterior of the Wii console with a clean cloth dampened with window cleaner. Make sure that the Wii console is ventilated properly and that the vents are not obstructed.
Aug 30, 2010 | Nintendo Wii Console
I have a Toshiba DVD Video Player Model SD 260. I
Hello, The problem could be dirt on the surface of the lens, you can clean this by removing the cover of the dvd player . Gently use a dry cotton bud to clean the lens because the lens is fragile. Insert the disc plate into the dvd player and press play, if it does not play try the second method. Ensure the cover of the player is open, connect the power plug to the mains socket and observe the lens if it beam a red light, Also check the ribbon cable use to connect the lens to the printed circuit board, then gently clean the lens with a dry cotton bud , insert the disc plate and press play to see if it play. If it does not play the disc, then this require a change of the lens
May 20, 2010 | Televison & Video
Getting a red error screen.
Disc Read Errors are mainly due to weak lens or dirty lens.You must clean your PS3 lens.Watch this video it will guide you for cleaning lens.And read the precautions too.
This laser is super sensitive. Do not touch it with your finger or anything that could potentially damage it or leave a mark.
1) Canned Air. Get a can with a mini straw and blow it out pretty good. If it's giving you problems, blow out the ventilation ports as well.
2) Disc Cleaner. Best buy makes a disc cleaner that looks like a DVD. This is not the best way to go but it might work. Ask an employee what they recommend using.
3) Q-tip. If you have already opened it; or are past warranty and desperate to get it cleaned, open up the console and with a Q-tip dipped in a very small amount of rubbing alcohol (make sure it's not wet, just damp) SUPER LIGHTLY give the laser one good rub.
Please make sure you're giving it a good means of ventilation and ensure to never put it on carpet.
Good Luck!
Jan 26, 2010 | Sony Playstation 3 (PS3) Console
When you put in the dics, and on the screen says not reading disc
Disc read errors are mainly due to weak or dirty lens you should try cleaning lens first.
When your PS2 lens is covered by dust it wont allow laser to read disc so its better to clean your PS2 lens first,if problem still exists then your PS2 lens is weak and you will have to take it to Sony repairer for service.I recommend all of PS2 owners to keep their PS2 at dust free environment.
Watch this video it will help you to learn how to clean your PS2,its easy you can do it at home.
Wish you good luck and hope cleaning lens will solve your problem. Thank you!
Dec 05, 2009 | Sony PlayStation 2 (PS2) Console
About Plystation One
1.) You may have some loose connections within your psp. Check power cable if there is an led light emitting from your unit confirming that the console is already powered on...
2.) Audio & Video cable should be check if there is a display...
3.) Bad lens... Have your lens be cleaned by a lens cleaner...
Apr 16, 2009 | Sony PSone Console
TruTech LMD-5702RT Portable DVD Player Logo
26 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
