Question about Samsung NP-N110 Netbook
Screen is dim when power not plugged in
When the laptop is not plugged in to the mains the screen is dim. I can't find the solution in the settings
  • Samsung Master
  • 7,627 Answers
In power settings you will find the dim adjust, Your laptop has power settings you can adjust to your preference. That said, the default settings are usually set to a power saving that means when you unplug your laptop from th AC source your laptop will dim to the power savings settings and prolong battery life. Look in power settings by right clicking the power icon in the taskbar notification area and open the power options. There are many options to choose from I use High Preformance, but on battery it shorten battery life. If you need assistance just respond to this solution.
Posted on Nov 05, 2012
2 Suggested Answers
  • 5 Answers
SOURCE: black screen
Press the ESC or F2 button on start-up and go into the BIOS and check the display settings
Posted on Dec 15, 2011
Dell Latitude e5410...brightness changes from dim to bright on it's own. Not using battery powered. What could be going on?
You could be manually brighting it. Hitting the FN and UP arrow and Down Arrows Dim and brightens the screen, But if it does it on it own check your settings on Power Options in the control panel and on the left you will see Create a power plan sure setting are set to Balanced then click on next. You now get to pick to dim it when plugged in or on battery. I change it to "Never" becuase i like to see the screen brighter save your setting and your done.
Oct 02, 2014 | Dell LATITUDE Computers & Internet
Nc6000 multibay battery does not recharge
Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
(Will charge)
That is AC adapter (Charger) removed, then remove multi-bay battery.
Plug AC adapter back into laptop, THEN plug AC adapter into power.
[You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
(Then plug AC adapter into power)
Post back in a Comment.
Regards,
joecoolvette
Feb 28, 2013 | HP Computers & Internet
The LCD of my laptop brightens when the charger is plugged in, as the voltage from the mains is coming slightly higher than normal. i.e. 240v
What make and model laptop? What operating system? Many laptops default to a power-saving mode when running on batteries, dimming the screen slightly. When plugged in, there's no reason to save power so the screen is at full brightness. You probably have something like "Power Options" in your control panel that will let you adjust the power options so you can have the screen at full brightness even on batteries if you so wish.
Dec 15, 2012 | Computers & Internet
HP Envy display stays dimmed after waking from sleep mode
Hi, i made several searches on google for you problem but did't get a right answer except this link. They provide support for HP Envy Laptop. Why not you try to call them on mentioned toll-free number.
http://www.hptechsupportnumbers.com/hp-envy-laptop/
Jul 20, 2017 | HP Computers & Internet
Why does my screen dim when the power cable is not plugged in
This is done to conserve battery power so the laptop will work for a longer time at a reduced screen brightness when it is not plugged into the Mains supply.
Apr 18, 2012 | HEWLETT-PACKARD ProBook 140 Notebook
Dim light on lcd screen
Either you have a power setting on that has the screen dimmed, or it's dimmed manually, or your laptop inverter is in the process of failing.
Sep 24, 2011 | IBM ThinkPad T43 Notebook
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Very dim to no display.
You will possibly, will have to replace the Inverter board, and/or the backlight, and maybe even the screen, start with an inverter board, and backlight, and if they do not fix it try the actual screen, really the only way to test without instruments is by swapping thing in & out.
Apr 02, 2010 | HP Pavilion dv5120us Notebook
Laptop Screen goes dim when plugged in!!!!
Hold down the Fn key then press arrow key up or down.
Aug 10, 2009 | Gateway 450ROG Notebook
Screen is dim
Try looking for a function key (usually used by holding down the Fn key and then pressing one of the "F" key at the top) the key will be marked with a brightness indicator.
Is your screen only dim when running off the battery is it dim when running when the charger is plugged in as well. If it is only dim when the laptop is running on battery then this may be caused by a setting in Power Options which is located in Control Panel (that is if your running Windows). In Power Options look for settings about running on AC Power and running on Battery power.
Jan 07, 2008 | Dell Inspiron 8500 Notebook
Samsung NP-N110 Netbook Logo
264 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
