Question about Sewing Machines
My Bernina Virtuosa 153 foot control LV1 won't work. Can I fix this foot control?
Foot control LV1 does not work.
SOURCE: Bernina Virtuosa 150 and uneven layers or bulk.
Hi I have a 15 year old Frister Rossmann serger which I got second hand 10 years ago. It has had one break down which was my fault for not getting it serviced for 8 years. Not sure where in world you are. They sell as Frister Rossmann in UK and Europe and Kenmore in the US. I've used it mainly for dressmaking and soft furnishing projects. One more thought on the Bernina have you tried leaving a query / searching on the US Bernina website www.berninausa.com I use them alot. Try and stick with getting the Bernina sorted, I love mine! Fiona
Posted on Apr 13, 2008
SOURCE: Bernina Virtuosa 153 QE is jammed.
Where do you live in China? I'm in Hong Kong and have visited that dealer.
Posted on Apr 04, 2009
  • 980 Answers
SOURCE: Old model Bernina 830, running ok, then kept
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Posted on Jun 27, 2009
calmeblondy
  • 33 Answers
SOURCE: loose pressure foot - how do I tighten on a Bernina 160 Virtuosa?
use small screwdriver provided, usually orange, streight edge,
Posted on Sep 28, 2009
  • 980 Answers
SOURCE: How do I service/oil my virtuosa 153
You can only oil the moving parts that you can see unless you want to take the machine apart which I do not recommend.
Posted on Mar 24, 2010
On the Bernina virtuosa 153 what does it mean when a symbol of a foot shows
Usually there is a number beside the foot symbol. That means the recommended foot for the stitch you are using
Jan 09, 2015 | Bernina Sewing Machines
Bernina Virtuosa 150 Presser Foot Loose
try increasing the presser with the adjuster
Feb 10, 2014 | Bernina Virtuosa 150
Bernina frozen, nothing moves
it's possible that something has broken or come loose inside the machine and the machine needs to be checked..
Jun 26, 2013 | Sewing Machines
430 aurora
Probably too thick to feed without dislodging the bobbin case, causing the error message.
May 07, 2013 | Bernina Activa 140
I have a Bernina Virtuosa 153 sewing machine that is skipping stitches while trying to shorten a pair of jeans. I changed the needle to a 100/16 and am using all purpose thread.
You may need to increase the foot pressure to cope with the heavy denim material. Look carefully at the material as the machine tries to stitch ... if the foot is not keeping the material firmly on the stitch plate, it might be riding up on the needle (denim tends to be rather 'grippy') which will prevent the thread loop being formed correctly below the stitch-plate and therefore not getting picked-up by the CB hook. Changing to a bigger diameter needle might actually make the situation worse in this case ... go back to an 80 and try again.
Sep 17, 2011 | Bernina Virtuosa 150
I turned off my machine to change the pressure foot on my Bernina Virtuosa 160. The pressure foot number does not change on the display. Is there something I need to do to change the number?
The machine Knows the foot number buy the small glass part of the foot just on the upper right side of the foot. Check to see if that is not damaged and clean. Also check the sensor on the machine just above the foot for not damage and clean. If that is good make sure your foot is paralel with the stitch plate. Do this buy putting a single hole foot on your machine and make sure the needle is right in the center. If this does not work you will need to take it in. May be a bad sensor or unpulged but that is rare.
Also not all bernina feed have this foot sensor, if this is the case it will not read it
hope this helps
Mar 27, 2011 | Bernina Virtuosa 160
Bernina Virtuosa 153 Quilter's Edition sewing machine jams
Bernina Virtuosa 150 pressure foot does not go down quite all the way. The stitches don't go straight and are not even. PrewettOE
Apr 07, 2009 | Bernina Sewing Machines
Bernina Buttonhole foot #3A
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
Aug 18, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
78 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
