Question about KitchenAid KSRS25IL Side by Side Refrigerator
I have a kitchenaid Superb refrigerator KSCS25INSS01 and the temps are warmer than normal.
For acouple of days the fridge temp read 57 and the freezer about 18. it was makinig a whirring noise followed a few seconds later by a low volume click. I had a repairman come out and say (without performing any real diagnostic work as far I'm coverned) that I need a new control panel. Does this seem reasonable? After he left, I fully removed the back panel, unplugged the fridge and plugged it back in again. the temps went down to the recommended values (37 and 0) and the frigde sounded okay. this morning, temps are still the same but the fridge is back to making the whirring/click noise.
  • Russ Bowman Jan 13, 2013
    did you figure out the problem?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I have a similar problem, I have the same model number, mine is too cold in the the refrigerator but has the same " whirring/click noise" .I have removed the back cover and observed the condenser fan motor cycling on and off in 10 second or so intervals. the compressor is not trying to start so my guess is the control board is bad. I was hoping you have solved your problem before I buy a $250.00 part or a new "Frig" this one is 8 years old.
Lil help?
Posted on Jan 13, 2013
ghappliances
  • 126 Answers
SOURCE: Defrost Mode
YOU MIGHT HAVE A GAS LEAK ON THE UNIT.OR THE COMPONENTS IN THE FREEZER COMPARTMENT ARE NOT WORKING WELL.BEST YOU GET AT TECHNICIAN TO HAVE A LOOK.GOODLUCK.MOHAMED
Posted on Sep 12, 2008
  • 409 Answers
SOURCE: No Cooling
hi there,
sounds like you may have a compressor problem. most compressors have a longer warranty on them, so i would recommend that you contact an authorized service center and have them come and take a look at it.
thanks
Posted on Sep 30, 2008
peyton32034
  • 410 Answers
SOURCE: Refrigerator is not getting cold
pull you refrig away from the wall and look behind the cardboard cover you will see the compressor (big black bowling ball looking thing). we need to determine if it is running you should here a low consistent hum. if the compressor is not running you will probably hear a humming and clicking noise about every 3-5 mins indicating the compressor is trying to start but shutting back down. the culprit is usually the start relay loated on the side of the compressor. this is a plug and play part and very easy to repace yourself get pt#8201786 from whirlpool the good instructions for replacing the part. good luck peyton
Posted on Jan 22, 2009
  • 16 Answers
SOURCE: Kitchenaid Fridge -- burnt rubber smell
sound like defrost timer going out slowly
Posted on Jun 02, 2009
heatman101
  • 43501 Answers
SOURCE: side by side kitchenaid freezer temperature indicator.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Aug 12, 2010
Kitchenaid side by side refrigerator/power is on/control panel display is lit up/Cooling is on/how do I reset the Temperature Display to get freezer at 0 degrees and fridge at 37 degrees
the temp you see are the temp valve inside, the set temp is only displayed while you are setting it. It maybe in defrost and you would see higher that set temp valves, if after an hour you do not see the temp come back down to normal operating values you should then see additional assistance.
Dec 29, 2017 | KitchenAid Refrigerators
I have Kitchen Aid french door fridge with large temp fluctuation. Please help
Clean your coils first, if they are dirty from dog hair or lint in general it will overheat compressor and cause temps to fluctuate
Oct 17, 2016 | Refrigerators
A kenmore side by side model 106 5661 2500 has warm refer and cold freezer
If the freezer temps are normal and the refrigerator is warmer than normal, the the air flow from freezer to refrigerator is being hampered either by ice on the evaporator or the freezer is stuff in such a way that normal airflow between freezer and fridge is hampered. If the auto defrost is not working properly you will have warmer freezer temps and a relatively warm refridge. Check the defrost timer and defrost heater element.
Nov 26, 2013 | Kenmore 56612 Side by Side Refrigerator
Hotpoint ffp187b
The temp sensors, or thermostat may not be correctly reading the temperature. if the temp sensor reads the wrong temp for example it'll think its warmer than it actually is and keep running to try and satisfy the tstat.
Aug 05, 2013 | Refrigerators
Freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Apr 01, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
Which way do you turn the temp. knob
loper the number on the thermostat dial, warmer the fridge. higher the number, colder the fridge. normal setting is about "3"
Apr 19, 2007 | Magic Chef MCBR170 Compact Refrigerator
KitchenAid KSRS25IL Side by Side Refrigerator Logo
225 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
