Question about Pool & Spa
Pelpro pellet stove auger will not work
The cycle light comes on but the auger will not move
5 Suggested Answers
protek480
  • 1714 Answers
SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a manual reset on the back of it that you have to press on firmly to reset it. Open the side panel on the stove and find the wiring. You will see the thermostat on the back side of the combustion chamber. Look very closely and reset it.
good luck!
Posted on Jul 01, 2009
protek480
  • 1714 Answers
SOURCE: AUGER IN PELLET STOVE NOT CONSISTANTLY TURNING
The auger motor is fed through a high temp limit thermostat. It has to be manually reset if it activates but it could be causing your problem with a bad connection or intermittently bad. It deserves a look...
protek480
  • 1714 Answers
SOURCE: auger on pellet stove doesn't turn
The thermostat inside on the back of the combustion chamber has a manual rest that needs to be pushed and reset.
Posted on Jul 08, 2009
  • 3 Answers
SOURCE: We have The Earth Stove
you must have an auto ignition, when you start the stove the auto ignite starts too
Posted on Jan 21, 2011
Hopper auger will not stop
How to Repair a Pellet Stove Auger That Won't Turn ' Home ...
homeguides.sfgate.com > Outdoors > General Repair
Cleaning the hopper, removing and replacing the auger and installing a new motor and ... Most pellet stoves do not have a removable auger cover, but you can see a ... youcan hear the motor attempting to spin the auger, turn off the auger and ...
Why wont my Auger feed pellets? ' Hearth.com Forums Home
www.hearth.com > ... > The Pellet Mill - Pellet and Multifuel Stoves
Jan 6, 2008 - Two #1 reason auger motor will not operate is: PRESSURE ..... Hopperlid trip switches now used on some stove will stop the auger and on the ... Harman Auger will not stop.
Oct 11, 2015
auger won't turn on Lopi Leyden
Oct 14, 2013
harman accentra will not turn off
Dec 31, 2011
Harmon Accentra feeding continually but no ignite
Jan 14, 2008
More results from www.hearth.com
Whitfield pellet stove repair, pellet stove repair, auger re
Jan 10, 2016 | Pool & Spa
What is a 5 u code on a pellet stove
New Stove Auger not moving shows S U in display ' Hearth.com ...
Nov 25, 2010 - 25 posts - ‎6 authors The letters "S U" mean the stove is in "Start Up mode. ... At this point load the stove w/pellets and hit the start button again. ... Shows SU again and settings are at 5 and 5. still no auger movement, not even the slightest bit. ... The E-0 code is the no error errorcode and stove will enter normal operation which ...
Oct 03, 2015 | Pool & Spa
Jamming auger onmagnum countrysidepelletstove
The softwood pellets are not the problem. The problem is the quality of those pellets. Make sure you are not using last years fuel and it has not been stored outside. Also check the auger system for junk, gouging and bending of the auger.
Nov 26, 2013 | MagnuM Countryside Pedestal Corn Stove
Auger not working on Blaze King Pellet Stove
depending on how the manufacturer set up the system, there may be pellets wedging the auger. most augers are geared low enough to snap the pellet but if its something else blocking it (stick or rock etc) it may have blown a fuse for the auger drive or the drive mechanism itself. if you are going to work on the auger. UNPLUG THE STOVE AND USE TOOLS TO CLEAR BLOCKAGE as there may still be some pressure to spin auger
Aug 07, 2017 | Pool & Spa
Pelpro pellet stove will not start. Press the start button, igniter button lights up but nothing happens.
Is the auger light coming on to and dropping pellets into the burn pot? If the auger light is not coming on, you probably have an issue with the board controlling it. If the auger light is coming on, and pellets are dropping into the burn pot and it is still not lighting, then you have only a few other possible problems.
1. The air damper is not allowing enough air in, so pull the damper rod out 1/8" increments until it lights.
2. Your ignitor is faulty and not producing enough heat to light the stove. You can either contact a local dealer and get a replacement ignitor, or you can manually light the stove with a special firestarting gel made for pellete stoves. When you press the start button look into the burn pot. If the ignitor isn't bright orange, you aren't getting enough heat from it.
Hope this helps...good luck.
Oct 11, 2009 | Coleman Dryers
Purchased a used Earth stove mp240 pellet stove and the auger does not move. we are looking for a manual or information on this stove it is an older stove we just don't know how old. Thank You
good luck!
Jun 10, 2009 | Napoleon Auburn Pellet Stove Heater
Pellet stove
The buzzing is possibly your exhaust/combustion blower. This blower is the fan sound you hear as the stove starts up. If you ARE hearing a NORMAL fan sound, then the buzzing could be the auger motor. Do you have a Foxfire with an igniter? This tells me the series of model you have and what control system it uses.
Feb 24, 2008 | Heating & Cooling
Pellet stove
PRESS H THEN TROUBLE THEN START THEN HIGH 6 THEN LOW 1
THEN PRESS BLOWER & HIGH FOR 3 BEEPS
Sep 30, 2007 | Stoves Broan 40000 Series Hood - 36" Hood...
Pool & Spa Logo
763 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
