How to hook up becket oil furnace
I need to know how to wire and hook up becket oil furnace
  • 81 Answers
On the top right hand side of the burner is the controller, on the right side ther are 4 contact screws, closest to the fire are the thermostate wires dosn,t matter which one goes where, two from thermostate go on these two contact screws. The two contact screws far away from the flame are for the two wires from the cad cell dosn't matter which one where. All that is left is 120 volt ac power which shouldn't be hard to see where they go.
Dennis
Posted on Nov 05, 2012
How to install a return line for a oil furnance
Hey Clinton ,if you have a home style becket no return line is required if you have a carlin the return line will be on the right side of burner pump in coming oil will enter left side next to air bleeder on pump, im worried are you modifying something ? i'll be glad to help if I know what your doing or trying to do.
Woody
Dec 10, 2014 | Cars & Trucks
How do you hook up the thermostat to a Central Electric feh-017ha-04 furnace? Also, where do the A/C wires hook up to the furnace?
The standard color code for the HVAC is as follows....
Red=Hot or 24v
White=Heat
Green=Fan
Yellow=A/C
White 1=secondary heat.
Blue=Spare
Orange=Heat Pump
C=Common
The thermostat has the terminals marked R,Rh,W,G,Y.
The furnace should have a terminal strip with similar markings.
If you only have 1 control transformer this will be easy.
Hook the wires up using the colors I have listed. If you don't have the same color wires go with whats close to them....such as use Orange for Red etc. It really doesn't matter as long as they are landed on the same terminals on the thermostat and furnace. Two wires running to A.C unit outside put one on Y the other on C. If you need any more help let me know!
Jun 02, 2014 | Intertherm Heating & Cooling
Webster/becket oil furnace there is no bleeder valve on it does anyone no have to bleed it
Actually, there is a bleeder valve on the pump you are referencing. It's located directly on top of the pump and the air (with some oil) comes out the nipple looking part just below and to the left of the bleed off valve 1/2" nut.
Apr 10, 2012 | Heating & Cooling
What is the best oil furnace on the market today 2011?
Your question is quite wide open to interpretation,Size, venting option, space availability,,,,But, if i think you wish to install this in a ,,lets say 1500 sqare feet home,, i would say a oil furnace made by olsen. Burns clean, effeciency depends on model, but sometime i would sacrifice a half % of efficiency for reliability, ease of maintnance,(not enough good ,reliable technicians in this field) quietness, odor free,parts availability, life span, ect ect.Stick with a canadian or north american made oil burner. I aint too fancy on the riello burners or even worse, a burner made for 50 different furnace model. I like the becket or aero burners. Choose a dc fan motor, direct dive if available. Stick with a chimney versus a direct or power vent.
Nov 11, 2011 | Heating & Cooling
Wires got pulled out by mistake don't know what wire goes where the wire is old and discolored help!!!!
Is your wiring where it's hooked into the furnace still identifable as to color. If so one way to tell whats what is to remove wires from furnace one at a time and disconnect all wires from base of thermostat. Use a ohm meter and one very long test wire. Hook to known wire on one end and use test wire to check wires on t-stat end. When you read closed circuit reattach wire to furnace and lable t-stat end as to color. Connections on base of thermostat should be marked with R,W,G,and y. Check each wire one at a time and when you know what color each wire is hook t-stat base back up,put cover back on and check out. A much eaiser way if you can identify wire color and existing wire is accessible in basement or whever your furnace is . Discconect wires from furnace and see if you can pull wire back up to thermostat. If you're lucky they won't be stapeled inside wall. If you can move wire easily buy approximate length of new wire at hardware store. Most of them will sell wire by the foot. Strip about 3/4 inch of insulation from each wire and twist all wires from old to new and wrap all of it with electrical tape. Carefully pull new wire to t-stat and connect there and to furnace. Good luck. I hope this helps. Thanks
Nov 17, 2010 | Honeywell YCT87N1006 Heater
My Rheem oil furnace is coupled with Rhuud heat pump. Oil furnace runs on emergency mode only and heat pump doesn't work at all!! Now the oil furnace will not even fire up even on emode.
Try and jump it out by taking the wire hooked to R and W terminals on your thermostat and connecting them. It could be you have a bad thermostat.
Feb 11, 2010 | Ruud UBHC Air Conditioner
I WANT TO HOOK IT UP TO A FAN,BUT ARE NOT SURE WHICH CONNECTIONS TO ATTACH TO.
In order to hook this up to the fan on your furnace, you will need to either have or install a Fan center @ the furnace. (Unless it is gas, and has a circuit board that will simplify the process) All this is, is a transformer, a relay, and a set (or two) of NO and NC contacts. You will need to run 3 wires from the thermostat back to the furnace, if you do not have them already. If you have a gas furnace with a circuit board then all you have to do is connect the three wires from the thermostat to the board. (R to R; W to W; G to G. If you are using an older furnace, or a oil fired appliance, power should go out of the transformer (secondary side) to the thermostat on R. It should then come off W and another wire off G back to the furnace. Connect to the appriately marked terminals on the fan center. Hope this helps
Nov 19, 2009 | Honeywell International Honeywell&...
I am trying to wire a hunter 44550 to furnace. Old programable not much help. Hi have 5 wires comming from wall. Black, red, yellow, white, blue, Furnace has W, RH, RC, G, Y/Y1, and O/B terminal Any idea...
Depending on where the wires were connected on the old thermostat, would be the best place to start, but if that is not an option you could try to trace the wires back to your furnace and see where they connect to. It appears you have either an oil fired furnace, or a single stage heat pump. If you need more assistance please just provide type of heat used. Hope this helps
Mar 07, 2009 | Hunter Fan Company 7-day programmable...
Furnace blower motor dose not shut off.
Do you think it might be the relay switch
Feb 04, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
65 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
