I've got a GE washer WCSE4160B1WW and I have to remove the agitator. This one has a nut to be removed, but I can't figure out hoe to get to it. Any suggestions?
How do I remove the agitator?
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
Remove the fabric softener cup, then the internal cap and you will see the screw.
Posted on Nov 06, 2012
huuum
  • 750 Answers
SOURCE: Maytag Atlantis black oil like residue and can't remove agitator
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
this is a very common happening and it means
This usually means that a seal is degrading or dissolving.
This washer is a top loader, Right!
I believe it calls for HE ( High Efficient) laundry detergent.
If we use to much of either it will cause this !
This usually happens due to using to much detergent or bleach.
You said, Black oil like residue discharged from washer during use. Stain clothes, almost impossible to remove. Loosened nut on agitator but it will not budge, and am afraid of damage if I try to pry between agitator and bottom of drum.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
onthejob5130
  • 640 Answers
SOURCE: GE topload washer Agitator
theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
Posted on Jan 23, 2009
  • 6 Answers
SOURCE: Agitator is slipping- GE model WJRR4170G top load washer
IF the agitator is like the ones in the older models, it will just pull straight up and off of the transmission shaft.
Inside the agitator there is a rubber splined insert with an aluminum center. The soft aluminum strips out causing the grinding sound. Very common to happen.
We used to use a special puller to remove that part and then press a new one back in.
Voila! Repaired agitator!!
Most any appliance parts store should be able to look up your model # and tell you if that agitator can be resplined.
Posted on Feb 20, 2009
SOURCE: Kenmore washer series 80-how do I remove the agitator
My Kenmore series 80 washer has sucked a shirt into the agitator and I cannot remove the agitator to free the shirt. How do I remove the agitator?. Do you have a diagram of the machine that I could look at to find it? The model is 238321000
Posted on Nov 24, 2009
SOURCE: GE Washer Hub Nut Removal
Spray the nut with PB Blaster. Use a ball peen hammer to break away the remaining thin part of the hub then chisel a trough from the radius up near the nut to the bottom broken edge of the hub. keep repeating this process until the chisel breaks thru and when the trough is deep enough you'll be able to insert the chisel thru the though where it broke thru and pry sideways which will crack the hub into two halves. Tap the two halves out from under the hub nut and you will be happy to find wrench flats on the shaft just below the nut. Two 10 inch adjustable wrenches should work for you now. Set the wrenches so that they are squeezed together while turning the nut in the loosening direction. If you still don't have enough hand strength attach two 3 foot pieces of 2 X 4 to a door hing and position the wrenches between the open "V" created by the 2 X 4 clamp. Good luck!
Posted on Apr 05, 2010
How do i remove the agitator
Top of agitator has a removable cap. Try to unscrew, if not pry off. You should find a hold down nut underneath. Remove nut, then pull evenly the agitator.
Sep 01, 2014 | GE GTWN2800DWW 3.9 cu. ft. capacity top...
How do I remove the agitator on my GE Spacemaker model GSLS1100?
Remove Pulsator (Blue) cap,Pulsator nut, Pulsator, and 2 washers and 1 nut. Pull up on the drum. But, 1st ask yourself WHY you want to remove the agitator!
Jul 02, 2014 | GE Spacemaker WSLP1100D Top Load Washer
I have a GE top load Model GTWN 4950L, there's a belt (cloth) that's stuck around the bottom of agitator. How do I remove it?
On the top of the agitator is a cap. Take it off, then there is a nut and a lock washer and you remove those and lift out the agitator. Then you can take the belt out.
Feb 28, 2013 | Washing Machines
I have a sheet stuck under the agitator of my GE gtwn3000mws. I've tried to use leverage to brute force the agitator out and it was a no go. Then I took off the top cup looking for the bolt to r
Remove the fabric softener cup, remove the plastic insert, then there is a 7/16th bolt you need to remove and the agitator will lift out.
Here is a diagram of the tub assembly.
Regards,
Richard Roth
http://appliancecafe.com
Nov 13, 2012 | GE GTWN3000MWS Washer
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    I received information about how to fix my agitator not working on my GE washer. But now I need info on how to get to the agitator. My model WWA8955 is different from any other GE top loading washers...
    Oops sorry about that my fault for not searching parts on your model befroe answering. What i wrote about is what ge has made for the past 10 years or so your washer is very old!
    to remove that agitator which doesnt use that part i talked about (sorry) so what you do it remove the bolt from top of inner agaitator and pull that agaitaor off. ITs been on thier for 15 or more years and will take some tugging perhaps and if lucky will come out right away after bolt removed. on the inside of the top of that inner agitator will be a coupler that works similar to the one if the vid. i showed you. that coupler needs to be knocked out and replace the spline coupler. Need to check though if center shaft of transmission is stripped before ordering and replacing that spline if the transmission is ground down the transmission would need to be replaced however since its so old the part is no longer available..
    The part number for that spilne is WH1X2641
    once again i apoligize for thinks it was less that 15 years old
    Aug 15, 2011 | GE WBSR3140DW Top Load Washer
    How do you remove the aggitater
    1- First you must determine the brand of washing machine you have. 2- To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
  • Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts. 3-Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
  • Read more: How to Remove an Agitator From a Washing Machine ' eHow.com http://www.ehow.com/how_4620771_remove-agitator-washing-machine.html#ixzz1IhUKY7OQ
    Apr 06, 2011 | GE WBSR3140DW Top Load Washer
    Coin stuck in agitator. how is agitator removed
    Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
    Nov 12, 2010 | GE Profile WPRE6100G Top Load Washer
    How to remove drum from any washing machine?
    with the agitator out look near the bottom for a large flat nut with notches in it. a correct spanner wrench will engage this notched nut so you can unscrew it and the tub should come right out.
    Aug 20, 2007 | GE WHRE5260E Top Load Washer
    Washing Machines Logo
    63 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
